之前拿焊好的板燒程序一直燒不進去,之后拿最小系統(tǒng)那個模塊來燒程序也不行,期間換了好幾塊芯片來試都不行,一直顯示正在檢測目標(biāo)單片機。請問這是程序的問題嗎?還是其他原因?
- *********STC89C52**********
- **********12MHz晶振*********/
- #include "reg51.h"
- #include<stdio.h>
- #include<intrins.h>
- #define uint8 unsigned char
- #define uint16 unsigned int
- #define uchar unsigned char
- #define uint unsigned int
- uint16 cnt2ms; //10ms計時器
- uint8 cnt1s; //1秒計數(shù)器
- //電阻--------------------------------
- #define Z1 13700053.00
- #define Z2 3685279.00
- float RZ=0;
- unsigned long RX=0;
- unsigned long RX2=0;
- unsigned long RX3=0;
- unsigned long RX4=0;
- unsigned long RX5=0;
- unsigned long RX6=0;
- unsigned long RX7=0;
- unsigned long RX8=0;
- unsigned long RX9=0;
- //電感--------------------------------
- float LZ=0;
- #define C1 0.1461
- //電容--------------------------------
- float CZ=0;
- float CX=0;
- #define R1 42874
- uint8 KL=0; //
- unsigned int Pulsecnt=0; //脈沖個數(shù)
- unsigned int Pulsenum; //脈沖個數(shù)
- uint8 start=0; //
- uint16 PulseTime; //10ms計數(shù)器
- uint16 Pulse; //10ms計數(shù)器
- bit flag=0;
- uint8 CH=0; //
- unsigned long x;
- void Init_Extint(void);
- void TimerInitProc();
- void Init_System(void);
- void Display(uint8 chose_dat, uint8 dat);
- void ShowDisp(uint8 tPulsenum, uint8 tPulsecnt, uint8 tcnt1s);
- void DelayMs(uint8 Ms);
- uint8 Pulse_FLAG=0;
- uint8 Pulse_5=0;
- /********************************按鍵*****************************************/
- sbit K1=P1^3;
- sbit K2=P1^4;
- sbit K3=P1^5;
- sbit A0=P2^1;
- sbit A1=P2^0;
- sbit RED=P3^6;
- sbit YEW=P3^4;
- sbit GRE=P3^3;
- /********************************LCD液晶**************************************/
- #define LCD_Data P0 //LCD的數(shù)據(jù)口
- sbit LCD_BF=LCD_Data^7; //LCD的忙信號位
- sbit LCD_RS=P1^0;
- sbit LCD_RW=P1^1;
- sbit LCD_EN=P1^2;
- #define LCD_GO_HOME 0x02 //AC=0,光標(biāo)、畫面回HOME位
- //輸入方式設(shè)置
- #define LCD_AC_AUTO_INCREMENT 0x06 //數(shù)據(jù)讀、寫操作后,AC自動增一
- #define LCD_AC_AUTO_DECREASE 0x04 //數(shù)據(jù)讀、寫操作后,AC自動減一
- #define LCD_MOVE_ENABLE 0x05 //數(shù)據(jù)讀、寫操作,畫面平移
- #define LCD_MOVE_DISENABLE 0x04 //數(shù)據(jù)讀、寫操作,畫面不動
- //設(shè)置顯示、光標(biāo)及閃爍開、關(guān)
- #define LCD_DISPLAY_ON 0x0C //顯示開
- #define LCD_DISPLAY_OFF 0x08 //顯示關(guān)
- #define LCD_CURSOR_ON 0x0A //光標(biāo)顯示
- #define LCD_CURSOR_OFF 0x08 //光標(biāo)不顯示
- #define LCD_CURSOR_BLINK_ON 0x09 //光標(biāo)閃爍
- #define LCD_CURSOR_BLINK_OFF 0x08 //光標(biāo)不閃爍
- //光標(biāo)、畫面移動,不影響DDRAM
- #define LCD_LEFT_MOVE 0x18 //LCD顯示左移一位
- #define LCD_RIGHT_MOVE 0x1C //LCD顯示右移一位
- #define LCD_CURSOR_LEFT_MOVE 0x10 //光標(biāo)左移一位
- #define LCD_CURSOR_RIGHT_MOVE 0x14 //光標(biāo)右移一位
- //工作方式設(shè)置
- #define LCD_DISPLAY_DOUBLE_LINE 0x38 //兩行顯示
- #define LCD_DISPLAY_SINGLE_LINE 0x30 //單行顯示
- /*定義子程序*/
- void LCD_ClrAll(void); //清屏
- void Judge_LCD_busy(void); //檢測是否忙碌
- void LCD_Write(uchar WriteData); //寫控制字
- void LCD_write_data(uchar LCD_data); //寫數(shù)據(jù)顯示
- void LCD_cursor(uchar x); //光標(biāo)起始地址
- void LCD_printc(unsigned char lcd_data) ; //輸出一個字符
- void LCD_prints(unsigned char *lcd_string);//輸出一個字符串
- /*LCD1602忙碌判斷子程序*/
- void Judge_LCD_busy(void) //判斷LCD1602是否忙狀態(tài)
- while(1)
- LCD_EN=0;
- LCD_RS=0;
- LCD_RW=1;
- LCD_Data=0xff;
- LCD_EN=1; //EN 是1-0 使能
- if(!LCD_BF)break; //LCD_BF=1表示忙碌,需要等待
- LCD_EN=0;
- /******LCD清屏***************/
- Judge_LCD_busy(); //判斷是否忙碌
- LCD_RS=0;
- LCD_RW=0;
- LCD_Data=0x01;
- LCD_EN=1;
- LCD_EN=0;
- /*******LCD寫數(shù)據(jù)定義各種模式*********/
- void LCD_Write(uchar WriteData) //寫指令到LCD
- Judge_LCD_busy();
- LCD_RS=0;
- LCD_RW=0;
- P0=WriteData; //把WriteDate的數(shù)據(jù)送到數(shù)據(jù)口
- LCD_EN=1;
- LCD_EN=0;
- /********LCD顯示數(shù)據(jù)***********/
- void LCD_write_data(uchar LCD_data) //輸入一個字節(jié)數(shù)據(jù)到LCD
- Judge_LCD_busy();
- LCD_RS=1;
- LCD_RW=0;
- P0=LCD_data;
- LCD_EN=1;
- LCD_EN=0;
- /****光標(biāo)位置的確定***/
- void LCD_cursor(uchar x) //LCD光標(biāo)定位到x處
- LCD_Write(0x80+x); //第一行地址是0x80
- /*輸入一個字符*/
- LCD_write_data(lcd_data);
- /*輸出字符串*/
- unsigned char i=0;
- while(lcd_string[i]!=0x00)
- LCD_write_data(lcd_string[i]);
- i++;
- /*初始化程序*/
- void LCD_initial(void) //初始化LCD
- LCD_Write(LCD_AC_AUTO_INCREMENT|LCD_MOVE_DISENABLE);
- LCD_Write(LCD_DISPLAY_ON|LCD_CURSOR_OFF);
- LCD_Write(LCD_DISPLAY_DOUBLE_LINE);
- LCD_ClrAll();
- /****延時******/
- void delay_1ms(uint x)
- uint j;
- uchar i;
- for(j=0;j<x;j++)
- for(i=0;i<120;i++);
- void Key_SM(void){
- if(K3==0){
- delay_1ms(5);
- if(K3==0){
- YEW=1;RED=0;
- GRE=1;
- LCD_cursor(0x00);
- LCD_prints(" MEASURE Lx ");
- //----電感檔-------
- A0=0;
- A1=1;
- CH=2;//電感檔
- while(K3==0){}
- if(K2==0){
- delay_1ms(5);
- if(K2==0){
- GRE=1;YEW=0;
- RED=1;
- LCD_cursor(0x00);
- LCD_prints(" MEASURE Rx ");
- //----電阻檔-------
- A0=1;
- A1=0;
- CH=1;//電阻檔
- while(K2==0){}
- if(K1==0){
- delay_1ms(5);
- if(K1==0){
- YEW=1;GRE=0;RED=1;
- LCD_cursor(0x00);
- LCD_prints(" MEASURE Cx ");
- //----電容檔-------
- A0=0;
- A1=0;
- CH=3;//電容檔
- while(K1==0){}
- void Value_to_ASCII(unsigned long value,uchar add)
- unsigned char temp[] = "0000.000K ";
- temp[0] = value/1000000 + 0x30;//數(shù)值改成字符,液晶顯示需要ASCII碼
- value = value%1000000;
- temp[1] = value/100000 + 0x30;
- value = value%100000;
- temp[2] = value/10000 + 0x30;
- value = value%10000;
- temp[3] = value/1000 + 0x30;
- value = value%1000;
- temp[5] = value/100 + 0x30;
- value = value%100;
- temp[6] = value/10 + 0x30;
- value = value%10;
- temp[7] = value + 0x30;
- LCD_cursor(add); //光標(biāo)起始地址,第一行地址是0x00~0x0F,第二行地址是0x40~0x4f
- LCD_prints(temp);
- void Value_to_ASCIIL(unsigned long value,uchar add)
- unsigned char temp[] = "000000uH ";
- temp[0] = value/100000 + 0x30;
- temp[1] = value/10000 + 0x30;
- temp[2] = value/1000 + 0x30;
- temp[3] = value/100 + 0x30;
- temp[4] = value/10 + 0x30;
- value = value%10;
- temp[5] = value + 0x30;
- LCD_prints(temp);
- void Value_to_ASCIIC(unsigned long value,uchar add)
- unsigned char temp[] = "00000.0pF ";
- value = value%10;
- temp[6] = value + 0x30;
- LCD_prints(temp);
- //--------------------主程序--------------------------------
- void main()
- TMOD=0x51; //設(shè)置定時器0,方式1::1位定時器
- TH1=0;
- TL1=0;
- TH0=(65536-2100)/256; //設(shè)定定時周期
- TL0=(65536-2100)%256;
- TR0=1;
- TR1=1;
- ET1=1;
- ET0=1;
- EA=1;
- //----電阻檔-------
- A0=1;
- A1=0;
- LCD_initial();
- delay_1ms(50);
- LCD_initial();
- delay_1ms(50);
- LCD_cursor(0x00);
- GRE=1;
- YEW=0;
- RED=1;
- LCD_cursor(0x45);
- CH=1;
- while(1)
- Key_SM();
- if(flag==1){
- flag=0;
- x=Pulsenum*65536+TL1;//計算1s內(nèi)的脈沖個數(shù),頻率=脈沖個數(shù)
- if(CH==1){
- RZ=(Z1/x);//測量100到1000
- RX=RZ-1000;
- RX=RX>>1;
- if(RX>=100){
- RX=RX+100;
- }else{RX=0;}
- if(x==0){RX=0;RX2=0;RX3=0;RX4=0;RX5=0;RX6=0;RX7=0;RX8=0;RX9=0;}
- if(RX>1000000){RX=1000000; }
- RX2=(RX+RX3+RX4+RX5+RX6+RX7+RX8+RX9)>>3;//求平均提高精度
- RX9=RX8;RX8=RX7;RX7=RX6;RX6=RX5;RX5=RX4;RX4=RX3;RX3=RX;
- //保存上一次的阻值
- Value_to_ASCII(RX2,0x44);//更新阻值顯示
- if(CH==2){
- LZ=(x*39*C1)/100000;
- LZ=LZ*x;
- LZ=1000000/LZ;
- if(x==0)LZ=0;
- if(LZ>999999)LZ=999999; //限制最高值
- Value_to_ASCIIL(LZ,0x44);//更新電感值顯示
- if(CH==3){
- CZ=660000/x;
- if(x==0||x>30500)CZ=0;
- if(CZ>999999)CZ=999999; //限制最高值
- Value_to_ASCIIC(CZ,0x44);//更新電容值顯示
- cnt2ms=0;
- Pulsenum=0;
- TH1=0;
- TL1=0;
- TR1=1;
- * 函數(shù)名:Extio interrupt
- * 函數(shù)功能:/TO引腳下降沿進入中斷
- * 入口參數(shù):無
- * 返 回:無
- void T1_interrupt(void) interrupt 3 using 0
- Pulsenum++; //保存測得脈沖值
- 函數(shù)功能:定時器/計時器1中斷處理
- 入口參數(shù):null
- 返 回:null
- 備 注:null
- void Timer0IntProc() interrupt 1 using 0 //2ms
- TH0=(65536-2000)/256;
- TL0=(65536-2000)%256;
- cnt2ms++;
- if(cnt2ms==500) //1s計時到
- cnt2ms = 0;
- flag=1;
