查看: 2523|回復: 0
Proteus仿真 具有開始、暫停、清零功能秒表相關
仿真圖如下 代碼如下
#include <reg52.h>
#define T0HIGH 0xec
#define T0LOWW 0x8a
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
typedef bit  BOOL;
sbit KEY_PIN = P3^3;
#define true 1
#define false 0
#define KEY_NULL 0
#define KEY_DOWN  0x80
#define KEY_LONG  0x40
#define KEY_UP   0x20
#define KEY_STATE_INIT  0
#define KEY_STATE_WOBBLE 1
#define KEY_STATE_PRESS  2
#define KEY_STATE_LONG  3
#define KEY_STATE_RELEASE 4
#define COUNT_INIT  0
#define COUNT_START  1
#define COUNT_STOP  2
code u8 DisCode[] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0xff};
u8 CouNum[4] = {0x00, 0x00, 0x00, 0x00};
u8 DisNum[4] = {0x0a, 0x0a, 0x00, 0x00};
u8 DisPosition = 0;
u8 SecCount = 0;
BOOL b10msEvent = false;
BOOL b100msEvent = false;
BOOL CountStart = false;
void Key_Prosess(void);
void Counter(void);
main()
TMOD = 0x01;
TH0 = T0HIGH;
TL0 = T0LOWW;
TR0 = 1;
ET0 = 1;
EA = 1;
P1 = 0x00;
  Key_Prosess();  //按鍵掃描
  if(b10msEvent == true)
   b10msEvent = false;
   LCD_Display();  //動態顯示
  if(b100msEvent == true)
   if(CountStart == true)
    Counter();  //計時
void Num_Clear(void)
u8 i;
for(i=0; i<4; i++)
  CouNum = 0;
DisNum[0] = DisNum[1] = 0x0a;
DisNum[2] = DisNum[3] = 0x00;
u8 Key_Scan(void)
if(KEY_PIN == false)
  return (1);
return KEY_NULL;
u8 GetKey(void)
static u8 KeyState = KEY_STATE_INIT;
static u8 KeyTimeCount = 0;
static u8 LastKey = KEY_NULL; //保存按鍵釋放時候的鍵值
u8 KeyTemp = KEY_NULL ;
KeyTemp = Key_Scan();
switch(KeyState)
  case KEY_STATE_INIT: //初始狀態
   if(KEY_NULL != KeyTemp) //有鍵按下
    KeyState = KEY_STATE_WOBBLE; //進入消抖
   break;
  case KEY_STATE_WOBBLE: //消抖
   KeyState = KEY_STATE_PRESS;
   break;
  case KEY_STATE_PRESS:
    LastKey = KeyTemp; //保存鍵值,以便在釋放按鍵狀態返回鍵值
    KeyTemp |= KEY_DOWN; //按鍵按下
    KeyState = KEY_STATE_LONG;
   break;
  case KEY_STATE_LONG:
    if(++KeyTimeCount >= 100)
     KeyTimeCount = 0;
     LastKey |= KEY_LONG;
    KeyState = KEY_STATE_RELEASE;
   break;
  case KEY_STATE_RELEASE:
   LastKey |= KEY_UP; //按鍵釋放
   KeyTemp = LastKey;
   break;
  default:
   break;
return KeyTemp;
u8 KeyData;
static u8 CountState = COUNT_INIT;
KeyData = GetKey();
if(KeyData == 0x81)
  switch(CountState)
   case COUNT_INIT: //開始計時
    SecCount = 0;
    TH0 = T0HIGH;
    TL0 = T0LOWW;
    CountStart = true;
    CountState = COUNT_START;
    break;
   case COUNT_START: //停止計時
    CountStart = false;
    CountState = COUNT_STOP;
    break;
   case COUNT_STOP: //清零
    Num_Clear();
    break;
   default:
    break;
void Counter(void)
u8 i;
if(++CouNum[3] == 10) //0.1秒
  CouNum[3] = 0;
  CouNum[2] += 1;
  if(CouNum[2] == 10)  //1秒
   CouNum[2] = 0;
   CouNum[1] += 1;
   if(CouNum[1] == 10)  //10秒
    CouNum[1] = 0;
    CouNum[0] += 1;
    if(CouNum[0] == 10)  //100秒
     CouNum[0] = 0;
for(i=0; i<2; i++)
  if(CouNum != 0)
   break;
for(; i<4; i++)
  DisNum = CouNum;
void LCD_Display(void)
static u8 DisPinOn = 0x01;
DisPinOn <<= 1;
if(DisPinOn == 0x10)
  DisPosition = 0;
  DisPinOn = 0x01;
P0 = 0xff;
P1 = DisPinOn;
P0 = DisCode[DisNum[DisPosition++]];
if(DisPinOn == 0x04)
  P0 &= 0x7f;
void timer0(void) interrupt 1
TH0 = T0HIGH;
TL0 = T0LOWW;
b10msEvent = true;
if(++SecCount == 10)
  SecCount = 0;
  b100msEvent = true;
keil報錯如下
1.c(63): error C213: left side of asn-op not an lvalue
1.c(160): error C187: not an lvalue
1.c(188): error C231: 'LCD_Display': redefinition
1.c(201): error C231: 'LCD_Display': redefinition
