查看: 3650|回復: 1
STM32單片機ADC+DMA方式讀取到0值
ID:939055 發表于 2021-6-17 01:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
采用STM C8T6單片機,B1口作為輸入,對應ADC12_IN9,
現在的問題是,無論如何屏幕顯示的數字都為0,也就是ADC_ConvertedValue這個變量值為0,也不太清楚是DMA的代碼出了問題還是ADC的代碼出了問題
在main.c中代碼如下:
#define ADC1_DR_Address ((u32)0x40012400+0x4c)
__IO uint16_t ADC_ConvertedValue;
void ADC_init(void){
    // IO Config
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; // tie to B1
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    // ADC1_IN9
    // DMA
    DMA_InitTypeDef DMA_InitStructure;
    DMA_DeInit(DMA1_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;
    DMA_InitStructure.DMA_DIR = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
    DMA_Cmd(DMA1_Channel1, ENABLE);
    // ADC
    ADC_InitTypeDef ADC_InitStructure;
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_InitStructure.ADC_ScanConvMode = DISABLE;
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfChannel = 1;
    ADC_Init(ADC1, &ADC_InitStructure);
    RCC_ADCCLKConfig(RCC_PCLK2_Div8);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 1, ADC_SampleTime_55Cycles5);
    ADC_DMACmd(ADC1, ENABLE);
    ADC_Cmd(ADC1, ENABLE);
    ADC_ResetCalibration(ADC1);
    while(ADC_GetResetCalibrationStatus(ADC1));
    ADC_StartCalibration(ADC1);
    while(ADC_GetCalibrationStatus(ADC1));
    ADC_SoftwareStartConvCmd(ADC1, ENABLE);
int main(){
    readFlash4Byte(0,&bias);
    GPIO_init();
    ADC_init();
    i2c_io();
    i2c_config();
    EXTI_B3_Config();
    timer3_start(5);
    int weight;
    while(1){
        set_led_number(ADC_ConvertedValue);
ID:851495 發表于 2021-6-28 09:57 | 只看該作者
樓主解決了嗎?什么原因啊
