查看: 2425|回復: 9
單片機源程序一直有兩個錯誤,求大家幫忙改正
ID:931449 發表于 2021-6-16 11:43 來自觸屏版 | 只看該作者 |只看大圖 回帖獎勵 |正序瀏覽 |閱讀模式
  1. #include<reg51.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. #define delayNOPX(){_nop_();_nop_();_nop_();_nop_();}
  6. sbit BEEP =P1^0;
  7. sbit LCD_RS =P2^0;
  8. sbit LCD_RW =P2^1;
  9. sbit LCD_EN =P2^2;
  10. void DelayMS(uint ms);
  11. bit LCD_Busy();
  12. void LCD_Pos(uchar);
  13. void LCD_Wcmd(uchar);
  14. void lcd_Wdat(uchar);
  15.   //標題字符串
  16.   char code Title_Text[]={"-phone code-"}
  17.   //鍵盤序號與鍵盤符號映射表
  18.   uchar code Key_Table[]={'1','2','3','4','5','6','7','8','9','0','#'};
  19.     //鍵盤撥號數字緩沖
  20.         uchar Dial_Code_Str[]={""};uchar KeyNo=0Xff;int tCount =0;
  21.         //延時
  22.         void DelayMS(uint x)
  23.         {
  24.         uchar i;
  25.         while(x--)
  26.         for(i=0;i<120;i++);
  27.         }
  28.         //在LCD指定的行上顯示字符串
  29.         Void display_string(uchar*str,uchar klineNo)
  30.         {
  31.         uchar k;
  32.         LCD_pos(lineNo);
  33.         for (k=0;k<16;k++)
  34.         LCD_wdat(str[k]);
  35.         }
  36.         //1602LCD顯示控制函數bit
  37. LCD_busy()void LCD_wcmd(uchar cmd)void
  38. LCD_wdat(uchar str)void LCD_init()void
  39. LCD_pos(uchar pos)
  40.     //T0控制按鍵聲音
  41.         Void T0_INT() interrupt 1
  42.         {
  43.         TH0 = -600/256;
  44.         TL0        = -600%256;
  45.         BEEP =~BEEP;
  46.         If (++tcount == 200)
  47.         {
  48.         Tcount 0;tr0 =0;
  49.         }
  50.         }
  51.         //鍵盤掃描
  52.         Uchar getkey()
  53.         {
  54.         Uchar i,j,k = 0;
  55.         Uchar keyscancode[]={0xef,0xdf,0xbf,0x7f};//鍵盤掃描碼
  56.         Uchar keyscancode[]={0xee,0xed,0xeb,0xde,0xdd,0xdb,0xbe,0xbd,0xbb,0x7e,0x7d,0x7b};//鍵盤特征碼
  57.         P3= 0x0f;
  58.         //掃描鍵盤獲取按鍵序號
  59.         If(p3!=0x0f)
  60.         {
  61.         For (i=0;i<4;i++)
  62.         {
  63.         p3 =keyscancode[i];
  64.         For (j=0;j<3;j++)
  65.         {
  66.         k =i*3+j;
  67.         If (p3==keycodetable[k])
  68.         return k;
  69.         }
  70.         }
  71.         }
  72.         else return oxff;
  73.         }
  74.         //主程序
  75.         Void main()
  76.         {
  77.         Uchar i =0,j;
  78.         p0 = p2 = p1 =0xff;
  79.         IE =0x82;TOMD =0x01;
  80.         LCD_init();//初始化LCD
  81.         Display_string(title_text,0x00);//在第一行顯示標題
  82.         While(1)
  83.         {
  84.         KeyNo =getkey();//獲取按鍵
  85.         If(keyNo ==0xff) cont inue;//無按鍵時繼續掃描
  86.         If(++i ==11)//超過11位時清空
  87.         {
  88.         for(j=0;j<16;j++) dial_code_str[j]=' ';i=0;
  89.         }
  90.         Dial_code_str[i]=key_table[keyNo];//講待顯示字符放入待顯示的撥號串中
  91.         Display_string(dial_code_str,0x40);//在第二行顯示號碼
  92.         Tr0 =1;//T0中斷控制按鍵聲音
  93.         While(getkey()!=0xff);//等待釋放
  94.         }
  95.         }
ID:964308 發表于 2021-10-17 21:02 來自觸屏版 | 只看該作者
一個地方少了個分號,一個地方定義出問題了,具體什么問題要發圖
ID:934353 發表于 2021-6-17 10:19 | 只看該作者
你的25行和16 行都少加了分號,編譯那里已經提醒的很明顯了
ID:592807 發表于 2021-6-16 18:13 | 只看該作者
你這if關鍵字有點意思
ID:931449 發表于 2021-6-16 15:35 來自觸屏版 | 只看該作者
這個是我的編譯顯示
Kxuan163 發表于 2021-6-16 14:58
應該如此。
以便于別人幫你找出錯誤原因。
這是編譯顯示
ID:938685 發表于 2021-6-16 15:20 | 只看該作者
那個標題字符串賦值后邊加上分號
參與人數 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:858964 發表于 2021-6-16 14:58 | 只看該作者
shumivan 發表于 2021-6-16 14:55
起碼吧提示的錯誤信息也發上來吧
應該如此。
以便于別人幫你找出錯誤原因。
ID:81196 發表于 2021-6-16 14:55 | 只看該作者
起碼吧提示的錯誤信息也發上來吧
ID:844772 發表于 2021-6-16 14:38 | 只看該作者
我理解是你在讓我練習肉眼編譯的能力。另外,你先把那個標題字符串賦值后邊加上分號。
