void DAC02_Mode_sin(void)
uint32_t Idx = 0;
DAC_sin02_init();
sin02.sin_frequency=char_change_num(Command01.command_number5,4);
sin02.sin_range=char_change_num(Command01.command_number6,4);
if(sin02.sin_frequency>5000)
sin02.sin_frequency=5000;
if( sin02.sin_range>3300)
sin02.sin_range=3300;
if(sin02.sin_frequency>1000)
sin_frequency=50000/sin02.sin_frequency;
sin02.point_num=point_num_sin2;
DAC02_sin_Config();
DAC02_TIM_Config();
TIM3_NVIC_Config();
for (Idx = 0; Idx < point_num_sin2; Idx++)
DualSine02bit[Idx]=(Sine12bit[Idx*(1000/point_num_sin2)])*(sin02.sin_range/100)/33;
sin_frequency=10000/sin02.sin_frequency;
sin02.point_num=point_num_sin;
DAC02_sin_Config();
DAC02_TIM_Config();
TIM3_NVIC_Config();
for (Idx = 0; Idx < point_num_sin; Idx++)
DualSine02bit[Idx]=(Sine12bit[Idx*(1000/point_num_sin)])*(sin02.sin_range/100)/33;
sin02.sin_runflag=1;
IAP_APP.7z
2021-6-11 16:00 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
928.83 KB, 下載次數(shù): 58, 下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
