查看: 1434|回復: 1
請大神幫忙看看這是哪里出錯了,應該怎么修改啊?
ID:751294 發表于 2021-6-2 11:01 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
Build target 'iot-stock'
linking...
iot-stock\iot-stock.axf: Error: L6406E: No space in execution regions with .ANY selector matching vm_memory.o(.bss).
iot-stock\iot-stock.axf: Error: L6407E: Sections of aggregate size 0x24c04 bytes could not fit into .ANY selector(s).
Not enough information to list image symbols.
Not enough information to list the image map.
Finished: 2 information, 0 warning and 2 error messages.
"iot-stock\iot-stock.axf" - 2 Error(s), 0 Warning(s).
Target not created
ID:844772 發表于 2021-6-2 14:26 | 只看該作者
代碼太大,芯片空間不夠,你發的也夠精簡的,都不知用的啥芯片。最好就是你精簡一下程序,特別是數組的大小,存儲方式。如果是stm32呢,還可以調整設置試試。
