查看: 3517|回復: 0
使用單片機定時器實現時鐘顯示
ID:884109 發表于 2021-5-30 17:44 | 顯示全部樓層 |閱讀模式
方法一:利用定時器溢出查詢實現
#include <reg51.h>
#include <intrins.h>
//共陰數碼管段選表0-9
uchar  code tabel[]= {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F,0x40};
uchar hour,minute,second;
void delay();
void display();
void timerInit();
void main(void)
        uchar i;
        timerInit();
        i = 0;
        hour = 12;
        minute = 34;
        second = 56;
        while(1){
                if( 1 == TF0 ){
                        TF0 = 0;
                        TH0 = 0x4B;
                        TL0 = 0xFC;
                        i++;
                        if( 20 == i ){
                                second++;
                                i = 0;
                        if( 60 == second ){
                                second = 0;
                                minute++;
                        if( 60 == minute ){
                                minute = 0;
                                hour++;
                        if( 24 == hour ){
                                hour = 0;
                display();
void timerInit()
        TMOD = 0x01;
        TH0 = 0x4B;
        TL0 = 0xFC;
        TR0 = 1;
void delay()
        uchar i;
        for( i = 0; i < 111; i++ ) ;
void display()
        P0 = tabel[ hour / 10 ];
        P1 = 0x80;
        delay();
        P0 = tabel[ hour % 10 ];
        P1 = 0x40;
        delay();
        P0 = tabel[ 10 ];
        P1 = 0x20;
        delay();
        P0 = tabel[ minute / 10 ];
        P1 = 0x10;
        delay();
        P0 = tabel[ minute % 10 ];
        P1 = 0x08;
        delay();
        P0 = tabel[ 10 ];
        P1 = 0x04;
        delay();
        P0 = tabel[ second / 10 ];
        P1 = 0x02;
        delay();
        P0 = tabel[ second % 10 ];
        P1 = 0x01;
        delay();
方法二:利用定時器中斷實現
#include <reg51.h>
//共陰數碼管段選表0~9和-
uchar  code wei[]= {0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80};
uchar hour,minute,second,i;
void delay();
void display();
void timerInit();
void main(void)
        timerInit();
        hour = 12;
        minute = 34;
        second = 56;
        while(1){
                display();
void timerInit()
        TMOD = 0x01;
        TH0 = 0x4B;
        TL0 = 0xFC;
        TR0 = 1;
        EA = 1;
        ET0 = 1;
void delay()
        uchar i;
void display()
        P1 = wei[ 7 ];
        delay();
        P1 = wei[ 6 ];
        delay();
        P0 = tabel[ 10 ];
        P1 = wei[ 5 ];
        delay();
        P1 = wei[ 4 ];
        delay();
        P1 = wei[ 3 ];
        delay();
        P0 = tabel[ 10 ];
        P1 = wei[ 2 ];
        delay();
        P1 = wei[ 1 ];
        delay();
        P1 = wei[ 0 ];
        delay();
void timer0Int() interrupt 1
        i++;
        if( 20 == i ){
                second++;
                i = 0;
        if( 60 == second ){
                second = 0;
                minute++;
        if( 60 == minute ){
                minute = 0;
                hour++;
        if( 24 == hour ){
                hour = 0;
        TH0 = 0x4B;
        TL0 = 0xFC;
參與人數 1黑幣 +20 收起 理由
admin + 20 共享資料的黑幣獎勵!
