怎樣才能實現(xiàn)數(shù)據(jù)加減,要有上下限,超過之后蜂鳴器會報警,各位前輩幫我看看要怎么改。
用OLED顯示兩個屏,第一個屏顯示個人信息,第二個屏顯示電機狀態(tài)、速度和溫度
#include <reg51.h>
#include "delay.h"
#include "oled12864.h"
#include "key.h"
#include "motor.h"
void screen1();
void screen2();
void key();
void motor();
void display();
void alarm();
unsigned char flag=0,speed=50,num=10,banji=1901,key_mode=0,wendu=30,key_num=0;
unsigned char code ch1[]={0,1,'#'};//名字
unsigned char code ch2[]={2,3,4,'#'};//
unsigned char code ch3[]={5,6,'#'};//班級
unsigned char code ch4[]={7,8,'#'};//學(xué)號
sbit bee=P3^6;
OLED_Init();
DC_Motor_Init();
// OLED_Clear();//顯示清屏
display();
// OLED_Clear();
key();
motor();
void display()
screen1();
screen2();
void screen1()
OLED_Show_stringChinese(0,0,ch1);//ch1姓名
OLED_Show_Char(0,32,':');
OLED_Show_stringChinese(0,37,ch2);//ch2
OLED_Show_stringChinese(2,0,ch4);//ch6學(xué)號
OLED_Show_Char(2,32,':');
OLED_Show_Num(2,36,num,4);
void screen2()
OLED_Show_String(0,0,"status:");
OLED_Show_String(2,0,"speed:");
OLED_Show_String(4,0,"wendu:");
OLED_Show_Num(2,8*8,speed,2);
OLED_Show_Num(4,8*8,wendu,2);
motor();
void key()
if(key1_scan()!=0)//key1_scan切換
key_mode++;
key_mode%=2;
// key_num=0;
OLED_Clear();
switch(key2_scan())
case 0:break;
case 1:OLED_Show_String(0,7*8,"runing ");break;
case 2:OLED_Show_String(0,7*8,"stop");break;
switch(key3_scan())//按鍵
case 0:break;
case 1:switch(key_mode)
case 0:switch(key_num)
case 0:break;
case 1:speed+=1;break;
case 2:speed+=10;break;
}break;
case 1:switch(key_num)
case 0:break;
case 1:wendu+=1;break;
case 2:wendu+=10;break;
}break;
}break;
switch(key4_scan())//按鍵
case 0:break;
case 0:break;
case 1:speed-=1;break;
case 2:speed-=10;break;
}break;
case 0:break;
case 1:wendu-=1;break;
case 2:wendu-=10;break;
}break;
}break;
void motor()
// flag=0,1,2;
switch(flag)
case 0:ENA=0;TR0=0;break;
case 1:TR0=1;DC_Motor_Run(1,speed);break;
void alarm()
if(wendu>50)
bee=1;
else if(wendu<20)
bee=1;
else bee=0;
