查看: 2422|回復(fù): 0
單片機(jī)定時(shí)器鬧鐘1602顯示
ID:377166 發(fā)表于 2021-5-28 17:26 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include "main.h"
void delay(uint z)//延時(shí)函數(shù)
    uint x,y;
    for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void di() //蜂鳴器報(bào)警聲音
    beep=0;
    delay(500);
    beep=1;
void write_com(uchar com)
{//寫液晶命令函數(shù)
    rs=0;
        rd=0;
    lcden=0;
    P0=com;
    delay(3);
    lcden=1;
    delay(3);
    lcden=0;
void write_date(uchar date)
{//寫液晶數(shù)據(jù)函數(shù)
    rs=1;
        rd=0;
    lcden=0;
    P0=date;
    delay(3);
    lcden=1;
    delay(3);
    lcden=0;
void init()
{//初始化函數(shù)
    uchar num;
    EA=1;//打開總中斷
    EX1=1;//開外部中斷1
    IT1=1;//設(shè)置負(fù)跳變沿觸發(fā)中斷
    flag1=0;//變量初始化
    t0_num=0;
    s1num=0;
    week=1;
//    dula=0;
        LSA=0;
        LSB=0;
        LSC=0;//關(guān)閉數(shù)碼管顯示
//    wela=0;
    lcden=0;
    rd=0;
/*以下幾行在首次設(shè)置DS12C887時(shí)使用,以后不必再寫入*/
    write_ds(0x0A,0x20);//打開振蕩器
    write_ds(0x0B,0x26);//設(shè)置24小時(shí)模式,數(shù)據(jù)二進(jìn)制格式
                        //開啟鬧鈴中斷
    set_time();//設(shè)置上電默認(rèn)時(shí)間
    write_com(0x38);//1602液晶初始化
    write_com(0x0c);
    write_com(0x06);
    write_com(0x01);
    write_com(0x80);
    for(num=0;num<15;num++)//寫入液晶固定部分顯示
            write_date(table[num]);
            delay(1);
    write_com(0x80+0x40);
    for(num=0;num<11;num++)
            write_date(table1[num]);
            delay(1);
void write_sfm(uchar add,char date)
{//1602液晶刷新時(shí)分秒函數(shù)4為時(shí),7為分,10為秒
    char shi,ge;
    shi=date/10;
    ge=date%10;
    write_com(0x80+0x40+add);
    write_date(0x30+shi);
    write_date(0x30+ge);
void write_nyr(uchar add,char date)
{//1602液晶刷新年月日函數(shù)3為年,6為分,9為秒
    char shi,ge;
    shi=date/10;
    ge=date%10;
    write_com(0x80+add);
void write_week(char we)
{//寫液晶星期顯示函數(shù)
    write_com(0x80+12);
    switch(we)
        case 1: write_date('M');delay(5);
                write_date('O');delay(5);
                write_date('N');
                break;
        case 2: write_date('T');delay(5);
                write_date('U');delay(5);
                write_date('E');
                break;
        case 3: write_date('W');delay(5);
                write_date('E');delay(5);
                write_date('D');
                break;
        case 4: write_date('T');delay(5);
                write_date('H');delay(5);
                write_date('U');
                break;
        case 5: write_date('F');delay(5);
                write_date('R');delay(5);
                write_date('I');
                break;
        case 6: write_date('S');delay(5);
                write_date('A');delay(5);
                write_date('T');
                break;
        case 7: write_date('S');delay(5);
                write_date('N');
                break;
void keyscan()
    if(flag_ri==1)
    {//這里用來(lái)取消鬧鐘報(bào)警,任一鍵取消報(bào)警
        if((s1==0)||(s2==0)||(s3==0)||(s4==0))
            delay(5);
                while(!(s1&&s2&&s3&&s4));
                di();
                flag_ri=0;//清除報(bào)警標(biāo)志
    if(s1==0)//檢測(cè)S1
        delay(5);
        if(s1==0)
            s1num++;//記錄按下次數(shù)
            if(flag1==1)
                if(s1num==4)
                    s1num=1;
            flag=1;
            while(!s1);
                        di();
            switch(s1num)
            {//光標(biāo)閃爍點(diǎn)定位
                case 1: write_com(0x80+0x40+10);
                        write_com(0x0f);
                        break;
                case 2: write_com(0x80+0x40+7);
                        break;
                case 3: write_com(0x80+0x40+4);
                        break;
                case 4: write_com(0x80+12);
                        break;
                case 5: write_com(0x80+9);
                        break;
                case 6: write_com(0x80+6);
                        break;
                case 7: write_com(0x80+3);
                        break;
                case 8: s1num=0;
                        write_com(0x0c);
                        flag=0;
                        write_ds(0,miao);
                        write_ds(2,fen);
                        write_ds(4,shi);
                        write_ds(6,week);
                        write_ds(7,day);
                        write_ds(8,month);
                        write_ds(9,year);
                        break;
    if(s1num!=0)//只有當(dāng)S1按下后,才檢測(cè)S2和S3
        if(s2==0)
            delay(1);
            if(s2==0)
                while(!s2);
                                di();
                switch(s1num)
                {//根據(jù)功能鍵次數(shù)調(diào)節(jié)相應(yīng)數(shù)值
                    case 1: miao++;
                            if(miao==60)
                                miao=0;
                            write_sfm(10,miao);
                            break;
                    case 2: fen++;
                            if(fen==60)
                                fen=0;
                            write_sfm(7,fen);
                            break;
                    case 3: shi++;
                            if(shi==24)
                                shi=0;
                            write_sfm(4,shi);
                            break;
                    case 4: week++;
                            if(week==8)
                                week=1;
                            write_week(week);
                            write_com(0x80+12);
                            break;
                    case 5: day++;
                            if(day==32)
                                day=1;
                            write_nyr(9,day);
                            write_com(0x80+9);
                            break;
                    case 6: month++;
                            if(month==13)
                                month=1;
                            write_nyr(6,month);
                            write_com(0x80+6);
                            break;
                    case 7: year++;
                            if(year==100)
                                year=0;
                            write_nyr(3,year);
                            write_com(0x80+3);
                            break;
        if(s3==0)
            delay(1);
            if(s3==0)
                while(!s3);
                                di();
                switch(s1num)
                    case 1: miao--;
                            if(miao==-1)
                                miao=59;
                            write_sfm(10,miao);
                            break;
                    case 2: fen--;
                            if(fen==-1)
                                fen=59;
                            write_sfm(7,fen);
                            break;
                    case 3: shi--;
                            if(shi==-1)
                                shi=23;
                            write_sfm(4,shi);
                            break;
                    case 4: week--;
                            if(week==0)
                                week=7;
                            write_week(week);
                            write_com(0x80+12);
                            break;
                    case 5: day--;
                            if(day==0)
                                day=31;
                            write_nyr(9,day);
                            write_com(0x80+9);
                            break;
                    case 6: month--;
                            if(month==0)
                                month=12;
                            write_nyr(6,month);
                            write_com(0x80+6);
                            break;
                    case 7: year--;
                            if(year==-1)
                                year=99;
                            write_nyr(3,year);
                            write_com(0x80+3);
                            break;
    if(s4==0)//檢測(cè)S4
        delay(5);
        if(s4==0)
            flag1=~flag1;
            while(!s4);di();
            if(flag1==0)
            {//退出鬧鐘設(shè)置時(shí)保存數(shù)值
                flag=0;
                write_date(' ');
                write_date(' ');
                write_com(0x0c);
                write_ds(1,miao);
                write_ds(3,fen);
                write_ds(5,shi);
            {//進(jìn)入鬧鐘設(shè)置
                read_alarm();//讀取原始數(shù)據(jù)
                miao=amiao;//重新賦值用以按鍵調(diào)節(jié)
                fen=afen;
                shi=ashi;
                write_date('R');//顯示標(biāo)志
                write_date('i');
                write_com(0x80+0x40+3);
                write_sfm(4,ashi);//送液晶顯示鬧鐘時(shí)間
                write_sfm(7,afen);
                write_sfm(10,amiao);
void write_ds(uchar add,uchar date)
{//寫12C887函數(shù)
    dscs=0;
    dsas=1;
    dsds=1;
    dsrw=1;
    P0=add;//先寫地址
    dsas=0;
    dsrw=0;
    P0=date;//再寫數(shù)據(jù)
    dsrw=1;
    dsas=1;
    dscs=1;
uchar read_ds(uchar add)
{//讀12C887函數(shù)
    uchar ds_date;
    dsas=1;
    dsds=1;
    dsrw=1;
    dscs=0;
    P0=add;//先寫地址
    dsas=0;
    dsds=0;
    P0=0xff;
    ds_date=P0;//再讀數(shù)據(jù)
    dsds=1;
    dsas=1;
    dscs=1;
    return ds_date;
/*---首次操作12C887時(shí)給予寄存器初始化---*/
void set_time()
{//首次上電初始化時(shí)間函數(shù)
//    write_ds(4, 0);
//    write_ds(2, 0);
    write_ds(0,0);
    write_ds(1,0);
    write_ds(2,0);
    write_ds(3,0);
    write_ds(4,0);
    write_ds(5,0);
    write_ds(6,0);
    write_ds(7,0);
    write_ds(8,0);
    write_ds(9,0);
void read_alarm()
{//讀取12C887鬧鐘值
    amiao=read_ds(1);
    afen=read_ds(3);
    ashi=read_ds(5);
void main()//主函數(shù)
    init();//調(diào)用初始化函數(shù)
        keyscan();//按鍵掃描
        if(flag_ri==1)//當(dāng)鬧鐘中斷時(shí)進(jìn)入這里
            di();
            delay(100);
            di();
            delay(500);
        if(flag==0&&flag1==0)//正常工作時(shí)進(jìn)入這里
            keyscan();//按鍵掃描
            year=read_ds(9);//讀取12C887數(shù)據(jù)
            month=read_ds(8);
            day=read_ds(7);
            week=read_ds(6);
            shi=read_ds(4);
            fen=read_ds(2);
            miao=read_ds(0);
            write_sfm(10,miao);//送液晶顯示
            write_sfm(7,fen);
            write_sfm(4,shi);
            write_week(week);
            write_nyr(3,year);
            write_nyr(6,month);
            write_nyr(9,day);
void exter() interrupt 2//外部中斷1服務(wù)程序
{   uchar c; //進(jìn)入中斷表示鬧鐘時(shí)間到,
    flag_ri=1; //設(shè)置標(biāo)志位,用以大程序中報(bào)警提示
    c=read_ds(0x0c);//讀取12C887的C寄存器表示響應(yīng)了中斷
以上代碼下載: 定時(shí)器時(shí)鐘鬧鐘1602顯示.7z (29.77 KB, 下載次數(shù): 12)
評(píng)分
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 共享資料的黑幣獎(jiǎng)勵(lì)!
查看全部評(píng)分
無(wú)效樓層,該帖已經(jīng)被刪除
