查看: 4269|回復: 1
如何把DAC0832轉換PCF8591但是功能不變
ID:928334 發表于 2021-5-27 20:10 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<intrins.h>
sbit s1=P1^0;
sbit s2=P1^1;
sbit s3=P1^2;
sbit s4=P1^3;
sbit lcdrs=P1^6;
sbit lcden=P1^7;
char num,boxing,u;
int pinlv=50,bujin=10,bujin1=10;
uchar geshu=1;
uchar code table[]="0123456789";
uchar code table1[]="pinlv:boxing:";
unsigned long int m;
int n=0;
float hc=0;
int a,b,h,num1;
uchar code sin[64]={
135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
uchar code juxing[64]={
255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
uchar code juchi[64]={
0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142,
146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255
uchar code sanjiao[64]={
0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
void delay(uint xms)
        int a,b;
        for(a=xms;a>0;a--)
                for(b=110;b>0;b--);
void write_com(uchar com)
        lcdrs=0;
        P0=com;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
void write_date(uchar date)
        lcdrs=1;
        P0=date;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
void init_lcd()
        lcden=0;
        write_com(0x0f);
        write_com(0x38);
        write_com(0x01);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x80);
void initclock()
        uint i;
        TMOD=0x01;
        TH0=a;
        TL0=b;
        EA=1;
        ET0=1;
        TR0=1;
        for(i=6;i<13;i++)
                write_date(table1[i]);
                delay(2);
        write_com(0x80+0x40);
        for(i=0;i<6;i++)
                delay(2);
        write_com(0x80+7);
                write_date('s');
                write_date('i');
                write_date('n');
                write_date(' ');
                write_date(' ');
                write_date(' ');
                write_date(' ');
                write_com(0x80+0x40+0xa);
                write_date(' ');
                write_date('1');
                write_date('0');
                write_date('H');
                delay(2);
                write_date('Z');
                delay(2);
void display()
        uchar wan,qian,bai,shi,ge;
        uint a=0;
        a=pinlv;
        wan=a/10000;
        qian=a/1000%10;
        bai=a/100%10;
        shi=a%100/10;
        ge=a%100%10;
        write_com(0x80+0x40+8);
        write_date(table[wan]);
        delay(2);
        write_date(table[qian]);
        delay(2);
        write_date(table[bai]);
        delay(2);
        write_date(table[shi]);
        delay(2);
        write_date(table[ge]);
        delay(2);
        write_date('H');
        delay(2);
        write_date('Z');
        delay(2);
        if(boxing==0)
                write_com(0x80+7);
                write_date('s');
                write_date('i');
                write_date('n');
                write_date(' ');
                write_date(' ');
                write_date(' ');
                write_date(' ');
        if(boxing==1)
                write_com(0x80+7);
                write_date('j');
                write_date('u');
                write_date('x');
                write_date('i');
                write_date('n');
                write_date('g');
        if(boxing==2)
                write_com(0x80+7);
                write_date('s');
                write_date('a');
                write_date('n');
                write_date('j');
                write_date('i');
                write_date('a');
                write_date('o');
        if(boxing==3)
                write_com(0x80+7);
                write_date('j');
                write_date('u');
                write_date('c');
                write_date('h');
                write_date('i');
                write_date(' ');
                write_date(' ');
uchar keyscan()
//        if(P1&0x0F==0x0F) return 0;
        if(s1==0)
                EA=0;
                delay(1);
                if(s1==0)
                        while(!s1);
                        pinlv+=bujin;
                        if(pinlv>30000)
                                pinlv=30000;
                        geshu=pinlv/120+1;
                        if(pinlv>960)
                                geshu=8;
                                bujin=100;
                                bujin1=100;
                        if(pinlv>1080) geshu=10;
                        if(pinlv>2000) geshu=11;
                        hc=15625/pinlv;
                        m=hc*geshu;
                        m-=54;
                        m/=15;
                        EA=1;
                        display();
        if(s2==0)
                delay(1);
                if(s2==0)
                        EA=0;
                        while(!s2);
                        pinlv-=bujin;
                        if(pinlv<0)
                                pinlv=0;
                        geshu=pinlv/120+1;
                        if(pinlv>960)
                                geshu=8;
                                bujin=100;
                                bujin1=100;
                        if(pinlv<=3100)
                                {hc=15625/pinlv;
                                m=hc*geshu;
                                m-=54;
                                m/=15;}
                                m=65276+(pinlv-480);
                        display();
                        EA=1;
        if(s3==0)
                delay(1);
                if(s3==0)
                        EA=0;
                        while(!s3);
                        boxing++;
                        if(boxing==4)
                                boxing=0;
                        display();
                        EA=1;
        return 1;
void bujindisplay()
        uint bai,shi,ge;
        bai=bujin1/100;
        shi=bujin1%100/10;
        ge=bujin1%100%10;
        write_com(0x80+6);
        delay(1);
        delay(1);
        delay(1);
void bujinjiance()
        if(s4==0)
                delay(3);
                if(s4==0)
                         while(!s4);
                         h++;
                         if(h==1)
                                  write_com(0x01);
                                 write_com(0x80);
                                 write_date('b');delay(1);
                                 write_date('u');delay(1);
                                 write_date('j');delay(1);
                                 write_date('i');delay(1);
                                 write_date('n');delay(1);
                                 write_date(':');delay(1);
                                 bujin1=bujin;
                                 bujindisplay();
                         if(h==2)
                                 h=0;
                                bujin=bujin1;
                                init_lcd();
                                initclock();
                                display();
        if(h==1)
                if(s1==0)
                        delay(5);
                        if(s1==0)
                                while(!s1);
                                bujin1++;
                                if(bujin1==101)
                                        bujin1=100;
                                bujindisplay();
                if(s2==0)
                        delay(5);
                        if(s2==0)
                                while(!s2);
                                bujin1--;
                                if(bujin1==0)
                                        bujin1=100;
                                bujindisplay();
        init_lcd();
        hc=15625/pinlv;
        m=hc*geshu;
        m-=54;
        m/=15;
        initclock();
        display();
//        csda=0;
//        wr=0;
                 switch(boxing)
                         case 0:        P2=sin[u];
                                break;
                        case 1:         P2=juxing[u];
                                break;
                        case 2:                 P2=sanjiao[u];
                                break;
                        case 3:                 P2=juchi[u];
                                break;
                u+=geshu;
                n=m;
                if(u>=64)
                        u=0;
                while(n-->0);
void T0_time()interrupt 1
//                TH0=a;
//                TL0=b;
                TH0=0;
                TL0=0;
                if(h==0)
                          keyscan();
                 bujinjiance();
這是代碼,功能是基于51單片機的多功能信號發射器
ID:94031 發表于 2021-5-28 09:16 | 顯示全部樓層
