查看: 1924|回復: 2
單片機交通燈怎么讓黃燈全亮的同時讓他們一直閃爍?
ID:925300 發表于 2021-5-22 10:51 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
請問怎么讓黃燈全亮的同時讓他們一直閃爍
  1. #include <reg51.h>
  2. #define uchar  unsigned char
  3. uchar  a[10]={0x3F,0x06,0x5B,0x4F,0x66,
  4. 0x6D,0x7D,0x07,0x7F,0x6F};
  5. uchar  b[4]={0x0D,0x0E,0x07,0x0B};
  6. uchar  c[4]={0x3A,0x36,0x5C,0x6C};
  7. uchar NS=25,EW=30;
  8. uchar NS_G=25,EW_G=15,Y=5;
  9. uchar i,k=0,count=0;
  10. void   delay(uchar);
  11. void trafic_light();
  12. void led_display();
  13. sbit  key_end=P3^5;
  14. sbit nt=P3^2;
  15. void init(void)
  16. {
  17.         TMOD=0x01;
  18.         TH0=(65536-50000)/256;
  19.         TL0=(65536-50000)%256;
  20.         ET0=1;
  21.         TR0=1;
  22.         EX1=1;
  23.         EA=1;
  24.         EX0=1;
  25. }
  26. //ò1???£ê?ía2??D??0£?P3
  27. void int0(void) interrupt 0
  28. {
  29.         while(1)
  30.         {
  31.                 P1=0xE7,P0=a[9];
  32.
  33.                 EA=0;
  34.                 TR0=!TR0;
  35.                 while(1)
  36.                 {
  37.                         for(i=0;i<4;i++)
  38.                         {
  39.                                 P2=b[i];
  40.                                 delay(1);
  41.                         }
  42.                         if(key_end==0)
  43.                         {
  44.                                 delay(10);
  45.                                 if(key_end==0)
  46.                                 {
  47.                                         while(!key_end)
  48.                                         {
  49.                                                 for(i=0;i<4;i++)
  50.                                                 {
  51.                                                         P2=b[i];
  52.                                                         delay(1);
  53.                                                 }
  54.                                         }
  55.                                         EA=1;
  56.                                         TR0=!TR0;
  57.                                         break;
  58.                                 }
  59.                         }
  60.           }
  61. }
  62. }
  63. void int1(void) interrupt 2
  64. {
  65.         P1=0x3C,P0=a[9];
  66.         EA=0;
  67.         TR0=!TR0;
  68.         while(1)
  69.         {
  70.                 for(i=0;i<4;i++)
  71.                 {
  72.                         P2=b[i];
  73.                         delay(1);
  74.                 }
  75.                 if(key_end==0)
  76.                 {
  77.                         delay(10);
  78.                         if(key_end==0)
  79.                         {
  80.                                 while(!key_end)
  81.                                 {
  82.                                         for(i=0;i<4;i++)
  83.                                         {
  84.                                                 P2=b[i];
  85.                                                 delay(1);
  86.                                         }
  87.                                 }
  88.                                 EA=1;
  89.                                 TR0=!TR0;
  90.                                 break;
  91.                         }
  92.                 }
  93.         }
  94. }
  95. void time1(void) interrupt 1
  96. {
  97.         TH0=(65536-50000)/256;
  98.         TL0=(65536-50000)%256;
  99.         count++;
  100.         if(count>=20)
  101.         {
  102.                 NS--;
  103.                 EW--;
  104.                 count=0;
  105.                 if(NS==0||EW==0)
  106.                 {
  107.                         k++;
  108.                         if(k>3)
  109.                         k=0;
  110.                         switch(k)
  111.                         {
  112.                                 case 0:NS=NS_G;
  113.                                 EW=NS_G+Y;
  114.                                 break;
  115.                                 case 1:NS=Y;
  116.                                 EW=Y;
  117.                                 break;
  118.                                 case 2:NS=EW_G+Y;
  119.                                 EW=EW_G;
  120.                                 break;
  121.                                 case 3:NS=Y;
  122.                                 EW=Y;
  123.                                 break;
  124.                         }
  125.                 }
  126.         }
  127. }
  128. void  delay(uchar t )
  129. {
  130.         uchar j,k;
  131.         for(j=0;j<t;j++)
  132.         {
  133.           for(k=0;k<255;k++){}
  134.         }
  135. }
  136. void  trafic_light()
  137. {
  138.         P1=c[k];
  139.         if(P1==c[1]&&count==0)
  140.         {
  141.          P1=0x3E;
  142.         }
  143.         else
  144.         if(P1==c[3]&&count==0)
  145.         {
  146.           P1=0x7C;
  147.         }
  148. }
  149. void led_display()
  150. {
  151.         P2=b[0];
  152.         P0=a[NS%10];
  153.         delay(5);
  154.         P2=b[1];
  155.         P0=a[NS/10];
  156.         delay(5);
  157.         P2=b[2];
  158.         P0=a[EW%10];
  159.         delay(5);
  160.         P2=b[3];
  161.         P0=a[EW/10];
  162.         delay(5);
  163. }
  164. void main(void)
  165. {
  166.         init();
  167.         while(1)
  168.         {
  169.                 trafic_light();
  170.                 led_display();
  171.         }
  172. }
ID:332444 發表于 2021-5-22 17:28 | 只看該作者
ID:332444 發表于 2021-5-22 17:29 | 只看該作者
