查看: 2398|回復: 4
如何合并一下這兩個單片機程序?我合了多次都不行,要么就是不會動
ID:922391 發表于 2021-5-21 22:03 | 顯示全部樓層 |閱讀模式
避障程序
#include"reg51.h"
#include <intrins.h>
#define uint  unsigned int
#define ulong  unsigned long
uint time=0,timer=0;
ulong S=0,T=0;
sbit RX1=P2^6;
sbit TX1=P2^7;
sbit RX2=P3^6;
sbit TX2=P3^7;
uint lf0=0,lf1=0;
uint lb0=0,lb1=0;
uint rf0=0,rf1=0;
uint rb0=0,rb1=0;
sbit inputL=P2^0;sbit inputR=P2^1;
sbit a1=P0^7;sbit a2=P0^6;
sbit b1=P0^5;sbit b2=P0^4;
sbit c1=P1^7;sbit c2=P1^6;
sbit d1=P1^5;sbit d2=P1^4;
void Delay(uint xms)
        uchar i, j;
        while(xms--)
                i = 2;
                j = 239;
                do
                        while (--j);
                } while (--i);
void forward(int pwm,int time)
        int a=0;
        while(a<time)
                        a1=0,a2=1;
                        b1=0,b2=1;
                        c1=0,c2=1;
                        d1=0,d2=1;
                        Delay(pwm);
                        a1=0,a2=0;
                        b1=0,b2=0;
                        c1=0,c2=0;
                        d1=0,d2=0;
                        Delay(10-pwm);
                        a++;
void turnleft(int pwm,int time)
        int a=0;
        while(a<time)
                        a1=1,a2=0;
                        b1=1,b2=0;
                        c1=0,c2=1;
                        d1=0,d2=1;
                        Delay(pwm);
                        a1=0,a2=0;
                        b1=0,b2=0;
                        c1=0,c2=0;
                        d1=0,d2=0;
                        Delay(10-pwm);
                        a++;
void turnright(int pwm,int time)
        int a=0;
        while(a<time)
                        a1=0,a2=1;
                        b1=0,b2=1;
                        c1=1,c2=0;
                        d1=1,d2=0;
                        Delay(pwm);
                        a1=0,a2=0;
                        b1=0,b2=0;
                        c1=0,c2=0;
                        d1=0,d2=0;
                        Delay(10-pwm);
                        a++;
void back(int pwm,int time)
        int a=0;
        while(a<time)
                        a1=1,a2=0;
                        b1=1,b2=0;
                        c1=1,c2=0;
                        d1=1,d2=0;
                        Delay(pwm);
                        a1=0,a2=0;
                        b1=0,b2=0;
                        c1=0,c2=0;
                        d1=0,d2=0;
                        Delay(10-pwm);
                        a++;
void maichong()
        _nop_();_nop_();_nop_();_nop_();_nop_();
        _nop_();
void qidong1()
        TX1=1;
        maichong();
        TX1=0;
void qidong2()
        TX2=1;
        maichong();
        TX2=0;
void Conut1()
        time=TH0*256+TL0;
        TH0=0;
        TL0=0;
        S=(long)(time*0.17);
void Conut2()
        timer=TH0*256+TL0;
        TH0=0;
        TL0=0;
        T=(long)(timer*0.17);
void kaishi()
        TMOD=0x01;
        TH0=0;
        TL0=0;
        ET0=1;
        EA=1;
void scan()
        if(S>200&&T>200)
                forward(5,5);
        if(S>200&&T<200)
                turnleft(5,5);
        if(S<200&&T>200)
                turnright(5,5);
        if(S<200&&T<200)
                back(5,5);
void  main()
        kaishi();
                qidong1();
                while(!RX1);                //當RX為零時等待
                TR0=1;                            //開啟計數
                while(RX1);                        //當RX為1計數并等待
                TR0=0;                                //關閉計算
                Conut1();                        //計算
                qidong2();
                while(!RX2);                //當RX為零時等待
                TR0=1;                            //開啟計數
                while(RX2);                        //當RX為1計數并等待
                TR0=0;                                //關閉計算
                Conut2();                        //計算
                scan();
循跡程序
#include"reg51.h"
        uchar i, j;
        while(xms--)
                i = 2;
                j = 239;
                do
                        while (--j);
                } while (--i);
        int a=0;
        while(a<time)
                        a1=0,a2=1;
                        b1=0,b2=1;
                        c1=0,c2=1;
                        d1=0,d2=1;
                        Delay(pwm);
                        a1=0,a2=0;
                        b1=0,b2=0;
                        c1=0,c2=0;
                        d1=0,d2=0;
                        Delay(10-pwm);
                        a++;
        int a=0;
        while(a<time)
                        a1=0,a2=1;
                        b1=0,b2=1;
                        c1=1,c2=0;
                        d1=1,d2=0;
                        Delay(pwm);
                        a1=0,a2=0;
                        b1=0,b2=0;
                        c1=0,c2=0;
                        d1=0,d2=0;
                        Delay(10-pwm);
                        a++;
        int a=0;
        while(a<time)
                        a1=1,a2=0;
                        b1=1,b2=0;
                        c1=0,c2=1;
                        d1=0,d2=1;
                        Delay(pwm);
                        a1=0,a2=0;
                        b1=0,b2=0;
                        c1=0,c2=0;
                        d1=0,d2=0;
                        Delay(10-pwm);
                        a++;
void scan()
        if(inputL==0&&inputR==0)
                forward(3,5);
        if(inputL==1&&inputR==1)
                forward(3,5);
        if(inputL==1&&inputR==0)
                turnleft(3,5);
        if(inputL==0&&inputR==1)
                turnright(3,5);
void kaishi()
        TMOD|=0X11;
        TH1=0xff;
        TL1=0x9c;
        ET1=1;
        TR1=1;
void  main()
        kaishi();
        EA=1;
                scan();
ID:824490 發表于 2021-5-22 10:22 | 顯示全部樓層
強烈要求畫個流程圖
ID:155507 發表于 2021-5-22 12:11 | 顯示全部樓層
為何你弄不出來呢,是你編程習慣不好。
建議:
1、先將各個程序畫成流程框圖。
2、將兩個流程框圖流程串聯起來。
3、重新整合框圖,走通各個分支。
4、在按框圖寫程序。
參與人數 1黑幣 +10 收起 理由
yyds0606 + 10 贊一個!
ID:922391 發表于 2021-5-22 12:18 | 顯示全部樓層
我知道了,謝謝
ID:390416 發表于 2021-5-22 18:09 | 顯示全部樓層
人人學會單片機 這套視頻的框架式編程思路,你按套路寫 多少個模塊都可以拼起來用一個程序
