查看: 1746|回復: 3
單片機數組模塊化問題
ID:837401 發表于 2021-5-21 20:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
想把數組單獨放到一個文件但是怎么編譯都出錯,主要是我現在不知道怎么定義外部數組
all.H文件
#include <STC8.H>
#include <intrins.H>
#include "Chinese.H"
typedef unsigned char u8;
typedef unsigned short u16;
main文件
#include "all.H"
void main
  u8 i,j;
      P1=Chinese[ i][j]      //假如這么寫[ i]
Chinese.c文件
#include "all.H"
u8 code Chinese[3][32]=
{{0x00,0x00,0x3F,0xF0,0x20,0x20,0x20,0x20,0x3F,0xF0,0x00,0x01,0x00,0x06,0x3F,0xF8,0x22,0x00,0x22,0x00,0x22,0x00,0x43,0xFF,0xC2,0x00,0x42,0x00,0x02,0x00,0x00,0x00},/* (16 X 16 ) */{0x02,0x08,0x02,0x30,0x02,0x02,0x02,0x01,0xFE,0xFE,0x22,0x00,0x22,0x20,0x02,0x19,0x20,0x02,0x3E,0x04,0x21,0xC8,0x20,0x30,0x21,0xCC,0x3E,0x02,0x00,0x01,0x00,0x00},/* (16 X 16 ) */{0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x00,0x00},/* (16 X 16 ) *
Chinese.H 文件
#ifndef __Chinese_H_#define __Chinese_H_extern u8 code Chinese[3][32]#endif
ID:213173 發表于 2021-5-22 08:40 | 只看該作者
  1. //main.c
  2. #include "all.H"
  3. void main()
  4. {
  5.   u8 i,j;
  6.    while(1)
  7.    {
  8.       P1=Chinese[i][j];      //假如這么寫[ i]
  9.    }
  10. }
  1. //all.H文件
  2. #ifndef _ALL_H_
  3. #define _ALL_H_
  4.         #include <STC8.H>
  5.         #include <intrins.H>
  6.         #include "Chinese.H"
  7.         #define u8 unsigned char
  8.         #define u16 unsigned int
  9. #endif
  1. //Chinese.c
  2. #include "all.H"
  3. u8 code Chinese[3][32]={
  4. {0x00,0x00,0x3F,0xF0,0x20,0x20,0x20,0x20,0x3F,0xF0,0x00,0x01,0x00,0x06,0x3F,0xF8,
  5. 0x22,0x00,0x22,0x00,0x22,0x00,0x43,0xFF,0xC2,0x00,0x42,0x00,0x02,0x00,0x00,0x00},/* (16 X 16 ) */
  6. {0x02,0x08,0x02,0x30,0x02,0x02,0x02,0x01,0xFE,0xFE,0x22,0x00,0x22,0x20,0x02,0x19,
  7. 0x20,0x02,0x3E,0x04,0x21,0xC8,0x20,0x30,0x21,0xCC,0x3E,0x02,0x00,0x01,0x00,0x00},/* (16 X 16 ) */
  8. {0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,
  9. 0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x00,0x00},/* (16 X 16 ) */
  10. };
  1. //Chinese.H 文件
  2. #ifndef __Chinese_H_
  3. #define __Chinese_H_
  4.         extern unsigned char code Chinese[3][32];
  5. #endif
ID:837401 發表于 2021-5-22 11:23 | 只看該作者
謝謝大佬,已經過編譯了
ID:802198 發表于 2021-5-22 11:36 | 只看該作者
數組定義問題
