查看: 2058|回復: 0
單片機程序為什么時間有時快有時慢還有鬧鐘響了只會為什么秒數不會增加?
ID:924233 發表于 2021-5-20 08:47 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
能不能幫我看一下,先謝謝
#include<reg51.h>
#include<intrins.h>
#define LCD1602_DB  P0 //定義1602的DB口為P0口
uchar code table[]="CurrentTime"; //當前時間
uchar code table1[]="00:00:00";
uchar key1Flag = 0;//定義按鍵關閉符
uchar key2Flag = 0;
uchar key3Flag = 0;
uchar key4Flag = 0;
uchar count = 0;
uchar sec = 57;//秒
uchar min = 59;//分
uchar hour = 9;//小時
uchar clockHour = 0;//鬧鐘小時
uchar clockMin = 0;//分
uchar clockFlag = 0;// 定義鬧鐘關閉符
uchar beepNum = 0;//聲音
uchar temp=0;
uchar shijian=0;
sbit LCD1602_RS = P2^0;        //指令1/數據0選擇端
sbit LCD1602_RW = P2^1;        //讀1寫0選擇端
sbit LCD1602_E = P2^2;        //讀1寫0使能端
sbit Key1 = P1^0;//定義鍵位符
sbit Key2 = P1^1;
sbit Key3 = P1^2;
sbit Key4 = P1^3;
sbit Speaker = P2^5;//定義蜂鳴器
sbit LED=P2^4;
void Delay1ms()                //@12.000MHz
        uchar i, j;
        i = 12;
        j = 169;
        do
                while (--j);
        } while (--i);
void Delay20ms()                //@12.000MHz
        uchar i, j, k;
        _nop_();
        _nop_();
        i = 1;
        j = 234;
        k = 113;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
void delay()
    unsigned int a;
        while(a--);
void Beep()         //蜂鳴器警報
        Speaker = 0;
        Delay20ms();
        Speaker = 1;
void LcdWaitReady()         //檢查LCD忙函數
        uchar sta;
        LCD1602_DB = 0xFF;
        LCD1602_RS = 0;
        LCD1602_RW = 1;
        do        {
                LCD1602_E = 1;
                sta = LCD1602_DB;
                LCD1602_E = 0;
        }while(sta & 0x80);
void LcdWriteCmd(uchar cmd)        //寫命令函數
        LcdWaitReady();
        LCD1602_RS = 0;
        LCD1602_RW = 0;
        LCD1602_DB = cmd;
        LCD1602_E = 1;
        LCD1602_E = 0;
void LcdWriteDat(uchar dat)        //寫數據函數
        LcdWaitReady();
        LCD1602_RS = 1;
        LCD1602_RW = 0;
        LCD1602_DB = dat;
        LCD1602_E = 1;
        LCD1602_E = 0;
void LcdSetCursor(uchar x, uchar y)//時間設置
        uchar addr;
        if(y == 0)
                addr = 0x00 + x;
                addr = 0x40 + x;
        LcdWriteCmd(addr | 0x80);
void LcdShowStr(uchar x, uchar y, uchar *str)
        LcdSetCursor(x, y);
        while(*str != '\0')
                LcdWriteDat(*str++);
void InitLcd1602()//初始化LCD函數
        LcdWriteCmd(0x01);
        LcdWriteCmd(0x38);
        LcdWriteCmd(0x0c);
        LcdWriteCmd(0x06);
void WriteAddress(uchar x)
         LcdWriteCmd(0x80 + x);
void DisplayMinTens()   //顯示分十位
        WriteAddress(0x49);
        LcdWriteDat((min / 10) + '0');
        Delay1ms();
void DisplayMinUnits()          //顯示分個位
        WriteAddress(0x4A);
        LcdWriteDat((min % 10) + '0');
        Delay1ms();
void DisplayHourTens()   //顯示時十位
        WriteAddress(0x46);
        LcdWriteDat((hour / 10) + '0');
        Delay1ms();
void DisplayHourUnits()//顯示時個位
        WriteAddress(0x47);
        LcdWriteDat((hour % 10) + '0');
        Delay1ms();
void DisplayClkMinTens()  //顯示鬧鐘分十位
        WriteAddress(0x49);
        LcdWriteDat((clockMin / 10) + '0');
        Delay1ms();
void DisplayClkMinUnits() //顯示鬧鐘分個位
        WriteAddress(0x4A);
        LcdWriteDat((clockMin % 10) + '0');
        Delay1ms();
void DisplayClkHourTens()  //顯示鬧鐘時十位
        WriteAddress(0x46);
        LcdWriteDat((clockHour / 10) + '0');
        Delay1ms();
void DisplayClkHourUnits() //顯示鬧鐘時個位
        WriteAddress(0x47);
        LcdWriteDat((clockHour % 10) + '0');
        Delay1ms();
void DisplayClkSecTens() //顯示秒十位
        WriteAddress(0x4C);
        LcdWriteDat((sec / 10) + '0');
        Delay1ms();
void DisplayClkSecUnits() //顯示秒個位
        WriteAddress(0x4D);
        LcdWriteDat((sec % 10) + '0');
        Delay1ms();
void ScanKey4()
        if((Key4 == 0)&(clockFlag ==1))
                Delay20ms();
                        clockFlag = 0;
                        beepNum = 0;
                        key4Flag = 0;
void InitTimer0()//初始化定時器0
        TMOD = 0x11;
        TH0 = (65536 - 50000) / 256;
        TL0 = (65536 - 50000) % 256;
        TH1 = (65536 - 50000) / 256;
        TL1 = (65536 - 50000) % 256;
        ET1=1;
   ET0=1;
        EA = 1;
        PT0=1;
        TR0=1;
        TR1=1;
void main()//主函數
        InitLcd1602();
        LcdShowStr(0,0,table);
        LcdShowStr(6,1,table1);
        InitTimer0();
                if(sec == 60)
                sec = 0;
                min++;
                if(min == 60)
                        min = 0;
                        hour++;
                if(hour == 24)
                        hour = 0;
                DisplayHourTens();
                DisplayHourUnits();
                LcdShowStr(8,1,":");
                DisplayMinTens();
                DisplayMinUnits();
                LcdShowStr(11,1,":");
                DisplayClkSecUnits();
                DisplayClkSecTens();
                if((Key1 == 0)&(key1Flag == 0)) {              //設置當前時間
                        Delay20ms();
                                TR0 = 0;
                                InitLcd1602();
                                LcdShowStr(0,0,"SetCurrentTime");
                                DisplayHourTens();
                                DisplayHourUnits();
                                DisplayMinTens();
                                DisplayMinUnits();
                                key1Flag = 1;
                while(key1Flag == 1)
                        if(Key1 == 0) {
                                Delay20ms();
                                if(Key1 == 0)
                                        hour++;
                                        if(hour == 24)
                                                hour = 0;
                                        DisplayHourTens();
                                        DisplayHourUnits();
                                        DisplayMinTens();
                                        DisplayMinUnits();
                        if(Key2 == 0)
                                Delay20ms();
                                if(Key2 == 0)
                                        min++;
                                        if(min == 60)
                                                min = 0;
                                                hour++;
                                        DisplayHourTens();
                                        DisplayHourUnits();
                                        DisplayMinTens();
                                        DisplayMinUnits();
                        if((Key3 == 0)&(key1Flag == 1)) {                 //退出設置當前時間
                                Delay20ms();
                                        InitLcd1602();
                                        DisplayHourTens();
                                        DisplayHourUnits();
                                        DisplayMinTens();
                                        DisplayMinUnits();
                                        key1Flag = 0;
                                        TR0 = 1;
                if((min==0)&(sec<5)) //時間到整點
                         LED=0;
                        delay();
                         Beep();
                         Beep();
                         Delay20ms();
                if((min==0)&(sec>=5))
                LED=1;
                if((Key2 == 0)&(key2Flag == 0))
                {                        //顯示鬧鐘時間
                        Delay20ms();
                                key2Flag = 1;
                                InitLcd1602();
                                while(key2Flag == 1)
                                        LcdShowStr(0,0,"Clock Time");
                                        DisplayClkHourTens();
                                        DisplayClkHourUnits();
                                        DisplayClkMinTens();
                                        DisplayClkMinUnits();
                                        if(Key2 == 0)
                                                Delay20ms();
                                                if(Key2 == 0)
                                                        key2Flag = 0;
                                                        InitLcd1602();
                                                        DisplayHourTens();
                                                        DisplayHourUnits();
                                                        DisplayMinTens();
                                                        DisplayMinUnits();
                if((Key3 == 0)&(key3Flag == 0))         //設置鬧鐘時間
                        Delay20ms();
                                TR0 = 0;
                                InitLcd1602();
                                LcdShowStr(0,0,"SetClockTime");
                                key3Flag = 1;
                while(key3Flag == 1)
                        if(Key1 == 0)
                                Delay20ms();
                                if(Key1 == 0)
                                         clockHour++;
                                         if(clockHour == 24)
                                                 clockHour = 0;
                        if(Key2 == 0)
                                Delay20ms();
                                if(Key2 == 0)
                                        clockMin++;
                                        if(clockMin == 60)
                                                clockHour++;
                                                clockMin = 0;
                        if(Key3 == 0)
                        {                                                         //退出設置鬧鐘時間
                                Delay20ms();
                                if(Key3 == 0)
                                        key3Flag = 0;
                                        InitLcd1602();
                                        TR0 = 1;
                                        DisplayHourTens();
                                        DisplayHourUnits();
                                        DisplayMinTens();
                                        DisplayMinUnits();
                if((Key4 == 0)&(key4Flag == 0)) //鬧鐘ON/OFF位設置
                        Delay20ms();
                                key4Flag = 1;
                                InitLcd1602();
                                LcdShowStr(0,0,"Clock ON");
                                Delay20ms();
                                Delay20ms();
                                Delay20ms();
                                Delay20ms();
                                Delay20ms();
                if((Key4 == 0)&(key4Flag == 1))         //鬧鐘ON/OFF位設置
                        Delay20ms();
                                key4Flag = 0;
                                InitLcd1602();
                                LcdShowStr(0,0,"Clock OFF");
                                Delay20ms();
                                Delay20ms();
                                Delay20ms();
                                Delay20ms();
        if((key4Flag == 1)&(hour == clockHour)&(min == clockMin))
                        clockFlag = 1;                                                         //鬧鐘時間到
                        InitLcd1602();
                        LcdShowStr(0,0,"Time's up");
                                        DisplayHourTens();
                                        DisplayHourUnits();
                                        DisplayMinTens();
                                        DisplayMinUnits();
                        while(clockFlag == 1)
                            LED=!LED;
                                Beep();
                                ScanKey4();
                                Delay20ms();
                                ScanKey4();
                                Delay20ms();
                                ScanKey4();
                                Delay20ms();
                                ScanKey4();
                                Delay20ms();
                                ScanKey4();
                                        Delay20ms();
                                ScanKey4();
                                        Delay20ms();
                                ScanKey4();
                                Delay20ms();
                                ScanKey4();
                                Delay20ms();
                                ScanKey4();
                                beepNum++;
                                if(beepNum == 20)
                                        clockFlag = 0;
                                        beepNum = 0;
                                        key4Flag = 0;
                                        LED=1;
void Timer0() interrupt 1
        temp++;
        if(temp == 20)
                sec++;
                temp = 0;
void Timer1() interrupt 3
TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
