2021-5-11 12:07 上傳
- #include<modbus.h>
- bit Search_Counta;//首次尋優標志 1
- bit Search_Countb;//首次尋優標志 2
- unit8 Count; //尋優計數值 (錯誤在這里!!!!!!!!)
- unit8 ReceCount; //串行口1的接收數據計數值
- unit8 SendCount; //串行口1發送數據計數值
- unit16 Init_Value=0; //尋優初值
- uint16 Term_Value=50; //尋優終值
- uint8 Search_Steps=50;//尋優步數
- uint8 idata resvbuf[16],Sendbuf[64];//串行口 1 的接收緩沖區和發送緩沖區
- uint16 xdata Re Wrbuf[32]; //可讀寫緩沖區
- uint16 xdata Register[32]; //寄存器緩沖區
- uint16 D_Val; //占空比的數字量
- bit Error; //錯誤標志位
- uint8 bdata Coil1=0xff;//8 位線圈狀態
- sbit Coil1_bit0=Coil1^0;
- sbit Coil1_bit1=Coil1^1;
- sbit Coil1_bit2=Coil1^2;
- sbit Coil1_bit3=Coil1^3;
- sbit Coil1_bit4=Coil1^4;
- sbit Coil1_bit5=Coil1^5;
- sbit Coil1_bit6=Coil1^6;
- sbit Coil1_bit7=Coil1^7;
- void Init System(); //初始化函數
- void Delay(void); //延時函數
- void Check Message(void);//功能碼判斷函數
- void Send Data();//發送數據函數
- void Read Coil(void);//讀線圈函數
- void Read Registers(void);//讀寄存器函數
- void Force Singal Coil(void);//強置單線圈函數
- void Set One Register Val(void);//預置單寄存器函數
- uint8 Get SWVal(uint16 Address);
- bit Set Coil Val(uint16 Address,bit Val);
- bit Set Register Val(uint16 Address1,uint16 Val1);
- uint16 crccheck(uint8 *puch Msg, uint8 us Data Len);
- void Delay_us(uint8 t);
- void Write_TLC(uint16 dat);
- void Self_optimization();
- //CRC 校驗查表碼值
- const uint8 code auch CRCHi[] ={
- 0x00, 0x C1, 0x81, 0x40, 0x01, 0x C0, 0x80, 0x41, 0x01, 0x C0,
- 0x80, 0x41, 0x00, 0x C1, 0x81, 0x40, 0x01, 0x C0, 0x80, 0x41,
- 0x00, 0x C1, 0x81, 0x40, 0x00, 0x C1, 0x81, 0x40, 0x01, 0x C0,
- 0x80, 0x41, 0x01, 0x C0, 0x80, 0x41, 0x00, 0x C1, 0x81, 0x40,
- 0x00, 0x C1, 0x81, 0x40, 0x01, 0x C0, 0x80, 0x41, 0x00, 0x C1,
- 0x81, 0x40, 0x01, 0x C0, 0x80, 0x41, 0x01, 0x C0, 0x80, 0x41,
- 0x81, 0x40, 0x00, 0x C1, 0x81, 0x40, 0x01, 0x C0, 0x80, 0x41,
- 0x80, 0x41, 0x00, 0x C1, 0x81, 0x40, 0x00, 0x C1, 0x81, 0x40,
- 0x01, 0x C0, 0x80, 0x41, 0x01, 0x C0, 0x80, 0x41, 0x00, 0x C1,
- 0x81, 0x40, 0x01, 0x C0, 0x80, 0x41, 0x00, 0x C1, 0x81, 0x40,
- 0x01, 0x C0, 0x80, 0x41, 0x00, 0x C1, 0x81, 0x40, 0x01, 0x C0,
- 0x80, 0x41, 0x00, 0x C1, 0x81, 0x40};
- const uint8 code auch CRCLo[] = {
- 0x00, 0x C0, 0x C1, 0x01, 0x C3, 0x03, 0x02, 0x C2, 0x C6, 0x06,
- 0x07, 0x C7, 0x05, 0x C5, 0x C4, 0x04, 0x CC, 0x0C, 0x0D, 0x CD,
- 0x0F, 0x CF, 0x CE, 0x0E, 0x0A, 0x CA, 0x CB, 0x0B, 0x C9, 0x09,
- 0x08, 0x C8, 0x D8, 0x18, 0x19, 0x D9, 0x1B, 0x DB, 0x DA, 0x1A,
- 0x1E, 0x DE, 0x DF, 0x1F, 0x DD, 0x1D, 0x1C, 0x DC, 0x14, 0x D4,
- 0x D5, 0x15, 0x D7, 0x17, 0x16, 0x D6, 0x D2, 0x12, 0x13, 0x D3,
- 0x11, 0x D1, 0x D0, 0x10, 0x F0, 0x30, 0x31, 0x F1, 0x33, 0x F3,
- 0x F2, 0x32, 0x36, 0x F6, 0x F7, 0x37, 0x F5, 0x35, 0x34, 0x F4,
- 0x3C, 0x FC, 0x FD, 0x3D, 0x FF, 0x3F, 0x3E, 0x FE, 0x FA, 0x3A,
- 0x3B, 0x FB, 0x39, 0x F9, 0x F8, 0x38, 0x28, 0x E8, 0x E9, 0x29,
- 0x EB, 0x2B, 0x2A, 0x EA, 0x EE, 0x2E, 0x2F, 0x EF, 0x2D, 0x ED,
- 0x EC, 0x2C, 0x E4, 0x24, 0x25, 0x E5, 0x27, 0x E7, 0x E6, 0x26,
- 0x22, 0x E2, 0x E3, 0x23, 0x E1, 0x21, 0x20, 0x E0, 0x A0, 0x60,
- 0x61, 0x A1, 0x63, 0x A3, 0x A2, 0x62, 0x66, 0x A6, 0x A7, 0x67,
- 0x A5, 0x65, 0x64, 0x A4, 0x6C, 0x AC, 0x AD, 0x6D, 0x AF, 0x6F,
- 0x6E, 0x AE, 0x AA, 0x6A, 0x6B, 0x AB, 0x69, 0x A9, 0x A8, 0x68,
- 0x78, 0x B8, 0x B9, 0x79, 0x BB, 0x7B, 0x7A, 0x BA, 0x BE, 0x7E,
- 0x7F, 0x BF, 0x7D, 0x BD, 0x BC, 0x7C, 0x B4, 0x74, 0x75, 0x B5,
- 0x77, 0x B7, 0x B6, 0x76, 0x72, 0x B2, 0x B3, 0x73, 0x B1, 0x71,
- 0x70, 0x B0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
- 0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
- 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
- 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
- 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
- 0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
- 0x43, 0x83, 0x41, 0x81, 0x80, 0x40};
- void timer0_INT(void) interrupt 1 using 1 //定時/計數器 0 中斷
- TR0=0;
- Error=1;
- if((resvbuf[0]==IN_Address)&&(Rece Count>=8))// 判斷接收到的設備地址是否與上位機的地址相等,并成功接收上位機發送的指令
- Error=0;
- void Uart1_INT(void) interrupt 4 using 3 //串口 1 中斷
- if(RI) //RI 為接收中斷標志位,為 1 表示一個數據已經收到。
- RI=0;
- resvbuf[Rece Count++]=SBUF;
- TR0=0;
- TH0=(65536-3688)/256;
- TL0=(65536-3688)%256; //定時器 0 定時 4ms
- TR0=1;
- if(TI) ////TI 為發送中斷標志位,為 1 表示一個數據已經發送完畢。
- TI=0;
- Function:CRC 校驗子函數
- uint8 uch CRCHi = 0x FF ;
- uint8 uch CRCLo = 0x FF ;
- uint8 uIndex ;
- while (usDataLen--)
- uIndex = uchCRCHi^*puchMsg++ ;
- uchCRCHi = uch CRCLo ^ auch CRCHi[u Index] ;
- uchCRCLo = auch CRCLo[u Index] ;
- return (uch CRCHi << 8 | uch CRCLo) ; //生成校驗碼,高位在前,低位在后。
- Function
- :延時子函數
- void Delay(void)
- uint16 i;
- for(i=0;i<3600;i++)
- _nop_();
- //初始化函數
- Rece Count=0;
- Rece2Count=0;
- Count = 0;
- Search_Counta = 0;
- Search_Countb = 0;
- DA_Val = 0;
- Register[9] = 0;//初始化時占空比輸出為 0
- Re Wrbuf[21] = 0;//初始工作時控制信號為 0
- Re Wrbuf[22] = 0;//初始工作時電流為 0
- Re Wrbuf[23] = 0;//初始工作時電流為 0
- TMOD=0x21;//定時器 1 工作方式 2,作為波特率發生器,定時器 0 工作方式1
- SCON=0x50;//串行口 1 工作方式 1,允許接收
- BRT=0xfd; //串行口 2 波特率 [url=mailto:9600@11.0592MHz]9600@11.0592MHz[/url]
- TH1=0xfd;
- TL1=0xfd;//串行口 1 波特率 [url=mailto:9600@11.0592MHz]9600@11.0592MHz[/url]
- IT0 = 0; //設置外部中斷 0 為低電平觸發
- IE=0x93;//EA=1,ES=1,ET0=1,EX0 = 1
- AUXR=0x10;//AUXR:輔助寄存器。BRTR=1,允許獨立波特率發生器運行。
- S2SMOD=0,串口 2 的波特率不加倍.
- //EXTRAM=0,允許使用內部擴展的 1024 字節擴展 RAM。
- TR1=1;//啟動定時器 1
- CJ();
- Function
- :單片機應答(發送數據)子函數
- void Send Data()
- uint8 i;
- uint16 crctemp;
- Sendbuf[0]=resvbuf[0]; //發送數據的第一個字節為上位機的地址
- Sendbuf[1]=resvbuf[1]; //發送數據的第二個字節為功能碼
- crctemp=crccheck(Sendbuf,Send Count-2);//計算發送的校驗碼
- Sendbuf[Send Count-2]=crctemp&0xff;
- Sendbuf[Send Count-1]=crctemp>>8; //發送消息時,CRC 低位在前、高位在后
- for(i=0;i<Send Count;i++)
- SBUF=Sendbuf[i];
- Delay();
- 函數功能:Modbus 功能判斷函數
- uint16 crctemp,temp;
- crctemp=crccheck(resvbuf,Rece Count-2); //生成校驗碼
- temp=resvbuf[Rece Count-1];//接收到的校驗碼的高字節
- temp=temp<<8|resvbuf[Rece Count-2];
- if(temp!=crctemp) //判斷接收到的校驗碼和生成的校驗碼是否一致
- Error=1; //校驗碼不一致,錯誤標志位置 1.
- Rece Count=0; //單片機接收數據(上位機發送的數據)無效,接收字節變量清零。
- if(!Error)//校驗碼一致
- ES=0;//關串口 1 中斷
- ET0=0;//關定時器 0 中斷
- switch(resvbuf[1]) //判斷功能碼
- case 2: Read Coil();break;
- case 3: Read Registers();break;
- case 5: Force Singal Coil();break;
- case 6: Set One Register Val();break;
- default: Error=1;
- ET0=1;
- ES=1;
- 函數功能:讀取位函數
- Sendbuf[i+3]表示 P0.0-P0.7 的開關狀態
- 若為高電平,則表明端口對應的開關斷開;
- 若為低電平,則表明端口對應的開關閉合;
- uint16 Start Address;//寄存器起始地址
- uint16 temp Address;
- uint8 Coil Num,i,Byte Num,j;
- uint8 Coil Val;
- bit exit=0; //是否讀完輸入開關狀態標志位(exit=1 表示讀完了)
- Start Address=resvbuf[2]; //起始地址高 8 位
- Start Address=Start Address|resvbuf[3];//起始地址低 8 位
- temp Address=Start Address;
- Coil Num=resvbuf[5];//讀取的位數
- Byte Num=Coil Num/8; //折算成字節
- if(Coil Num%8!=0)
- Byte Num++;
- Sendbuf[2]=Byte Num;//返回的字節數
- for(i=0;i<Byte Num;i++)
- Sendbuf[i+3]=0;//返回的數據 1 初始值為 0
- for(j=0;j<8;j++)
- Coil Val=Get SWVal(Start Address);
- Sendbuf[i+3]|=Coil Val<<j;//讀取每一位的狀態
- Start Address++;
- if(Start Address>=temp Address+Coil Num)//判斷是否讀完 Coil Num個線圈狀態
- exit=1;
- break;//讀完退出
- if(exit==1)
- break;
- Send Count=5+Byte Num;//發送的字節數(發送的地址碼、功能碼、從機返回的字節數、CRC 校驗碼共占 5 個字節)
- Send Data();
- 函數功能:獲取開關狀態函數。8 路數字量輸入 Address1=上位機中設置的寄存
- 器地址減 1.在上位機中增加通道:寄存器類型設置成【1 區】輸入繼電器,寄存
- 器地址依次設置成 1-8
- uint8 Get SWVal(uint16 Address1)
- uint8 Coil Val,Switch=0xff;
- Switch=P0;
- switch(Address1&0x0f)
- case 0: Coil Val=Switch>>1&0x01;break; // P0.0 的開關狀態
- case 1: Coil Val=Switch>>2&0x01;break; // P0.1 的開關狀態
- case 2: Coil Val=Switch>>3&0x01;break; // P0.2 的開關狀態
- case 3: Coil Val=Switch>>4&0x01;break; // P0.3 的開關狀態
- case 4: Coil Val=Switch>>5&0x01;break; // P0.4 的開關狀態
- case 5: Coil Val=Switch>>6&0x01;break; // P0.5 的開關狀態
- case 6: Coil Val=Switch>>7&0x01;break; // P0.6 的開關狀態
- case 7: Coil Val=Switch>>8&0x01;break; // P0.7 的開關狀態
- default: break;
- return Coil Val;
- 函數功能:讀取寄存器函數
- uint8 Byte Count,i;
- Start Address=Start Address<<8|resvbuf[3];
- Byte Count=resvbuf[5]*2; //一個寄存器數據占 2 個字節
- Sendbuf[2]=resvbuf[5]*2; //上位機寄存器為 16 位占用兩個字節 ?
- for(i=0;i<Byte Count;i+=2)//一個寄存器數據占 2 個字節
- Sendbuf[i+4]=Re Wrbuf[Start Address]&0xff;
- Sendbuf[i+3]=Re Wrbuf[Start Address]>>8; //高位在前、低位在后
- Start Address++;
- Send Count=Byte Count+5;
- Send Data();
- if(resvbuf[3] == 0x00)
- CJ(); //讀電能采集模塊數據
- 函數功能:強制單線圈函數
- uint16 Address,On Off;
- bit temp,Coil Val;
- Address=resvbuf[2]<<8|resvbuf[3];
- On Off=resvbuf[4]<<8|resvbuf[5];
- if(On Off==0x0000)
- Coil Val=0;
- temp=Set Coil Val(Address,Coil Val);
- else if(On Off==0x FF00)
- Coil Val=1;
- if(temp==1) //成功返回原命令
- Sendbuf[2]=resvbuf[2];
- Sendbuf[3]=resvbuf[3];
- Sendbuf[4]=resvbuf[4];
- Sendbuf[5]=resvbuf[5];
- Send Count=8;
- Send Data();
- else
- Error=1;
- 函數功能:設置位值函數
- 6 路數字量輸出,Address=上位機中設置的寄存器地址減 1.
- 上位機中增加通道:寄存器類型設置成【0 區】輸出繼電器,操作方式設置成只
- 寫 , 寄 存 器 地 址 依 次 設 置 成 1-6 , 即 可 強 制 Q55-Q0(P2.0-P2.5)
- 的 狀 態 。
- bit result=1;
- switch(Address&0x0f)
- case 0: Coil1_bit0=Val;break; //強制 P2.0(Q5)的狀態
- case 1: Coil1_bit1=Val;break; //強制 P2.1(Q4)的狀態
- case 2: Coil1_bit2=Val;break; //強制 P2.2(Q3)的狀態
- case 3: Coil1_bit3=Val;break; //強制 P2.3(Q2)的狀態
- case 4: Coil1_bit4=Val;break; //強制 P2.4(Q1)的狀態
- case 5: Coil1_bit5=Val;break; //強制 P2.5(Q0)的狀態
- case 6: Self_optimization();break; //自尋優開始
- default: result=0;break;
- return result;
- 函數功能:設置單寄存器函數
- uint16 R_Address,Register Val;
- bit temp1;
- R_Address=resvbuf[2];
- R_Address=R_Address<<8|resvbuf[3];
- R_Address=R_Address-90; //要設置的寄存器地址
- Register Val=resvbuf[4];
- Register Val=Register Val<<8|resvbuf[5];//要設置的寄存器值
- temp1=Set Register Val(R_Address,Register Val);
- if((temp1 == 1)&&(R_Address == 9)) //成功返回原命令
- Send Count = 8;
- Send Data();
- D_Val = Register[9];
- Write_TLC(D_Val); //輸出 D 值
- else if((temp1 == 1)&&(R_Address == 10))
- Send Count = 8;
- Send Data();
- Harm_Times = Register[10]&0x FF;
- else if((temp1 == 1)&&(R_Address == 11))
- Send Count = 8;
- Send Data();
- Init_Value = Register[11];
- else if((temp1 == 1)&&(R_Address == 12))
- Send Count = 8;
- Send Data();
- Term_Value = Register[12];
- else if((temp1 == 1)&&(R_Address == 13))
- Send Count = 8;
- Send Data();
- Search_Steps = Register[13]&0x FF;
- else //否則置錯誤位
- Error=1;
- 函數功能:設置寄存器值函數
- uint8 Addr;
- bit result1=1;
- Addr=Address1&0xff; //Register[]數組的大小為 32 個字節
- Register[Addr]=Val1;
- return result1;
- uint8 i;
- for(i=0;i<12*t;i++)
- _nop_();
