仿真可以,但是實物接的時候就不行
//函數(shù)聲明
void Read_Busy(); //忙檢測函數(shù)
void Lcd1602_Write_Cmd(unsigned char cmd); //寫命令
void Lcd1602_Write_Data(unsigned char dat); //寫數(shù)據(jù)
void LcdSetCursor(unsigned char x,unsigned char y); //坐標顯示
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData); //顯示字符
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str); //顯示字符串
void InitLcd1602(); //初始化
#include"lcd.h"
void Read_Busy() //忙檢測函數(shù),判斷bit7是0,允許執(zhí)行;1禁止
unsigned char sta;
LCD1602_DB = 0xff;
LCD1602_RS = 0;
LCD1602_RW = 1;
do
LCD1602_EN = 1;
sta = LCD1602_DB;
LCD1602_EN = 0; //使能,用完就拉低,釋放總線
}while(sta & 0x80);
/*void delay(uint n)
uint x,y;
for(x=n;x>0;x--)
for(y=110;y>0;y--);
void Lcd1602_Write_Cmd(unsigned char cmd) //寫命令
Read_Busy();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_EN = 1;
delay(5);
LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat) //寫數(shù)據(jù)
Read_Busy();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_EN = 1;
delay(5);
LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y) //坐標顯示
unsigned char addr;
if(y == 0)
addr = 0x00 + x;
addr = 0x40 + x;
Lcd1602_Write_Cmd(addr|0x80);
//按指定位置顯示一個字符
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
X |= 0x80; //算出指令碼
Lcd1602_Write_Cmd(X); //發(fā)命令字
Lcd1602_Write_Data(DData); //發(fā)數(shù)據(jù)
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str) //顯示字符串
LcdSetCursor(x,y); //當前字符的坐標
while(*str != '\0')
Lcd1602_Write_Data(*str++);
void InitLcd1602() //1602初始化
Lcd1602_Write_Cmd(0x38); //打開,5*8,8位數(shù)據(jù)
Lcd1602_Write_Cmd(0x0c);
Lcd1602_Write_Cmd(0x06);
Lcd1602_Write_Cmd(0x01); //清屏
