#include "stdio.h"
#include "math.h"
#include "macroconst.h"
#include "reg52.h"
#include "string.h"
#include "delay.h"
unsigned char code IC_DAT[];//----------------定義數(shù)組
unsigned char code pic1[];
unsigned char code pic2[];
unsigned char code pic3[];
sbit RS =P1^0;//------------------------定義接口信息
sbit WRD=P1^1;
sbit E= P1^2;
sbit PSB=P2^7;
sbit RES=P2^5;
void TransferData(char data1,bit DI); //-------------函數(shù)聲明
void display(void);
void display_grapic(void);
//void delayms(unsigned int n);
void DisplayLine(unsigned char line1,unsigned char line2);
void DisplayGraphic(unsigned char code *adder);
//void delay(unsigned int m);
void lcd_mesg(unsigned char code *adder1);
//unsigned char code IC_DAT[]={
//"就辭白帝彩云間,"
//"千里江陵一日還。"
//"兩岸猿聲啼不住,"
//"輕舟已三萬重山。"
//unsigned char code IC_DAT2[]={
//"海納百川寬容為先"
//"欲成大業(yè)誠(chéng)信為先"
//"游弋商海濟(jì)世為先"
//"人立于世守法為先"
void TransferData(char data1,bit DI) //------------傳送數(shù)據(jù)或者命令,當(dāng)DI=0是,傳送命令,當(dāng)DI=1,傳送數(shù)據(jù).
WRD=0;
RS=DI;
delay(1);
P0=data1;
E=1;
delay(1);
E=0;
//void delayms(unsigned int n)//--------------------延時(shí)10×n毫秒程序
// unsigned int i,j;
// for(i=0;i<n;i++)
// for(j=0;j<2000;j++);
//void delay(unsigned int m)//----------------------延時(shí)程序
// for(i=0;i<m;i++)
// for(j=0;j<20;j++);
void initina1(void) //------------LCD字庫初始化程序
delay(40); //大于40MS的延時(shí)程序
PSB=1; //設(shè)置為8BIT并口工作模式
delay(1); //延時(shí)
RES=0; //復(fù)位
delay(1); //延時(shí)
RES=1; //復(fù)位置高
delay(10);
TransferData(0x30,0); //Extended Function Set :8BIT設(shè)置,RE=0: basic instruction set, G=0 :graphic display OFF
delay(100); //大于100uS的延時(shí)程序
TransferData(0x30,0); //Function Set
delay(37); ////大于37uS的延時(shí)程序
TransferData(0x08,0); //Display on Control
TransferData(0x10,0); //Cursor Display Control光標(biāo)設(shè)置
TransferData(0x0C,0); //Display Control,D=1,顯示開
TransferData(0x01,0); //Display Clear
delay(10); //大于10mS的延時(shí)程序
TransferData(0x06,0); //Enry Mode Set,光標(biāo)從右向左加1位移動(dòng)
void initina2(void) //-------------LCD顯示圖片(擴(kuò)展)初始化程序
delay(1); //延時(shí)
RES=0; //復(fù)位
delay(1); //延時(shí)
RES=1; //復(fù)位置高
delay(10);
TransferData(0x36,0); //Extended Function Set RE=1: extended instruction
TransferData(0x36,0); //Extended Function Set:RE=1: extended instruction set
TransferData(0x3E,0); //EXFUNCTION(DL=8BITS,RE=1,G=1)
TransferData(0x01,0); //CLEAR SCREEN
void Lcd_Set_Post(uchar y,uchar x) //設(shè)置顯示位置
uchar Address;
if(y==1){Address = 0x80 + x;}
if(y==2){Address = 0x90 + x;}
if(y==3){Address = 0x88 + x;}
if(y==4){Address = 0x98 + x;}
TransferData(Address,0);
void LCD_WRITE_CHAR(uchar *Word)//------------------------寫字
while(*Word)
TransferData(*Word,1);
Word ++;
void DisplayGraphic(unsigned char code *adder)//-------畫數(shù)字 圖
int i,j;
//顯示上半屏內(nèi)容設(shè)置
for(i=16;i<32;i++) //
TransferData((0x80 + i),0); //SET 垂直地址 VERTICAL ADD
TransferData(0x80,0); //SET 水平地址 HORIZONTAL ADD
for(j=0;j<2;j++)
TransferData(*adder,1);
adder++;
//顯示下半屏內(nèi)容設(shè)置
for(i=0;i<16;i++) //
TransferData(0x88,0); //SET 水平地址 HORIZONTAL ADD
for(j=0;j<2;j++)
adder++;
void display() //為反白做準(zhǔn)備,目地是在圖形顯示時(shí)防止有噪點(diǎn)
uchar i,j;
TransferData(0x34,0); //寫數(shù)據(jù)時(shí),關(guān)閉圖形顯示
for(i=0;i<32;i++)
TransferData(0x80+i,0); //先寫入水平坐標(biāo)值
TransferData(0x80,0); //寫入垂直坐標(biāo)值
for(j=0;j<16;j++) //再寫入兩個(gè)8位元的數(shù)據(jù)
TransferData(0x00,1);
delay(1);
for(i=0;i<32;i++)
TransferData(0x88,0); //寫入垂直坐標(biāo)值
delay(1);
TransferData(0x36,0); //寫完數(shù)據(jù),開圖形顯示
void white(uchar x,uchar y,uchar width) //反白,X值為0-7,Y值為0-3,width為行反白格數(shù)
uchar i,j,flag=0x00;
display();
if(y>1)
flag=0x08;
y=y-2;
// TransferData(0x34,0); //寫數(shù)據(jù)時(shí),關(guān)閉圖形顯示,且打開擴(kuò)展指令集
for(i=0;i<16;i++)
TransferData((0x80+(y<<4)+i),0);
TransferData((0x80+flag+x),0);
for(j=0;j<width;j++)
TransferData(0xff,1);
delay(1);
// TransferData(0x36,0); //寫完數(shù)據(jù),開圖形顯示
// lcd_wcmd(0x30); //從擴(kuò)展指令到基本指令
51黑論壇_12864萬年歷.zip
2021-5-5 19:28 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
227.32 KB, 下載次數(shù): 30, 下載積分: 黑幣 -5
