我想讓檢測(cè)的溫度n和設(shè)定的溫度m相等時(shí)舵機(jī)轉(zhuǎn)動(dòng)停止該如何去做(只貼了舵機(jī)程序和主程序,顯示程序和檢測(cè)程序沒(méi)貼應(yīng)該不影響)
我試了
if(m=n)
Servo0PwmDuty0=Servo0PwmDuty0;Servo0PwmDuty1=Servo0PwmDuty1;
DelayMs(1000);
但是效果不太理想,還是仿真有問(wèn)題希望幫忙解答
單片機(jī)程序:
- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit SERVO0=P3^6; //控制舵機(jī)的PWM輸出口
- sbit SERVO1=P3^5;
- sbit kaishi=P1^1;
- sbit jieshu=P1^2;
- sbit jiare=P3^3;
- sbit jianre=P3^4;
- uint Servo0PwmDuty0=1500; //PWM脈沖寬度 1.5ms脈沖寬度
- uint Servo0PwmDuty1=1500;
- void DelayMs(uint ms)
- uint i,j;
- for(i=0;i<85;i++) //89單片機(jī)用85,12系列單片機(jī)用800
- for(j=0;j<ms;j++);
- //時(shí)鐘初始化
- void InitTimer0(void)
- TMOD = 0x11; //設(shè)置定時(shí)器模式
- TL0 = 0x00; //設(shè)置定時(shí)初值
- TH0 = 0x00; //設(shè)置定時(shí)初值
- TF0 = 0; //清除TF0標(biāo)志
- TR0 = 1; //定時(shí)器0開始計(jì)時(shí)
- ET0 = 1;
- TL1 = 0x00; //設(shè)置定時(shí)初值
- TH1 = 0x00; //設(shè)置定時(shí)初值
- TF1 = 0; //清除TF0標(biāo)志
- TR1 = 1; //定時(shí)器0開始計(jì)時(shí)
- ET1 = 1; //開定時(shí)器0中斷
- //給定時(shí)器0計(jì)數(shù)器賦值產(chǎn)生定時(shí)中斷秒的中斷
- //因?yàn)槎〞r(shí)器是TH0,TL0都要全部計(jì)數(shù)到0xFF后在計(jì)1個(gè)數(shù)就會(huì)產(chǎn)生中斷,所以要想產(chǎn)生pwm毫秒的中斷,那么TH0,TL0就應(yīng)該賦值(0xFFFF-pwm) 從這個(gè)值開始計(jì)數(shù)產(chǎn)生定時(shí)中斷
- void Timer0Value(uint pwm)
- uint value;
- value=0xffff-pwm;
- TR0 = 0;
- TL0=value; //16位數(shù)據(jù)給8位數(shù)據(jù)賦值默認(rèn)將16位數(shù)據(jù)的低八位直接賦給八位數(shù)據(jù)
- TH0=value>>8; //將16位數(shù)據(jù)右移8位,也就是將高8位移到低八位,再賦值給8位數(shù)據(jù)
- TR0 = 1;
- void Timer1Value(uint pwm)
- uint value;
- value=0xffff-pwm;
- TR1 = 0;
- TL1=value; //16位數(shù)據(jù)給8位數(shù)據(jù)賦值默認(rèn)將16位數(shù)據(jù)的低八位直接賦給八位數(shù)據(jù)
- TH1=value>>8; //將16位數(shù)據(jù)右移8位,也就是將高8位移到低八位,再賦值給8位數(shù)據(jù)
- TR1 = 1;
- void main(void)
- float m=0,n;
- InitTimer0(); //定時(shí)器0初始化
- EA = 1;
- LCD_init();//lcd初始化
- while(1)
- n=ds18b20readwendu();//檢測(cè)到的溫度
- LCD_Putstring(1,1, "當(dāng)前溫度");//顯示
- lcd_putint(1,5, n);//顯示
- LCD_Putstring(2,1, "預(yù)設(shè)溫度");
- lcd_putint(2,5, m);
- if(kaishi==0)
- Servo0PwmDuty0 = 1500;Servo0PwmDuty1 = 1500;
- DelayMs(1000);
- if(jieshu==0)
- Servo0PwmDuty0 = 500;Servo0PwmDuty1 = 500;
- DelayMs(1000);
- if(jiare==0)
- m=m+1;
- if(jianre==0)
- m=m-1;
- if(m>n)
- Servo0PwmDuty0=Servo0PwmDuty0+50;Servo0PwmDuty1=Servo0PwmDuty1-50;
- DelayMs(1000);
- if(Servo0PwmDuty0>=2500){Servo0PwmDuty0=2500;Servo0PwmDuty1=500;}
- if(m<n)
- Servo0PwmDuty0=Servo0PwmDuty0-50;Servo0PwmDuty1=Servo0PwmDuty1+50;
- DelayMs(1000);
- if(Servo0PwmDuty1>=2500){Servo0PwmDuty1=2500;Servo0PwmDuty0=500;}
- void Timer_0(void) interrupt 1 using 1
- static uint i = 1; //靜態(tài)變量:每次調(diào)用函數(shù)時(shí)保持上一次所賦的值,
- //跟全局變量類似,不同是它只能用于此函數(shù)內(nèi)部
- switch(i)
- case 1:
- SERVO0 = 1; //PWM控制腳高電平
- //給定時(shí)器0賦值,計(jì)數(shù)Pwm0Duty個(gè)脈沖后產(chǎn)生中斷,下次中斷會(huì)進(jìn)入下一個(gè)case語(yǔ)句
- Timer0Value(Servo0PwmDuty0);
- break;
- case 2:
- SERVO0 = 0; //PWM控制腳低電平
- //高脈沖結(jié)束后剩下的時(shí)間(20000-Pwm0Duty)全是低電平了,Pwm0Duty + (20000-Pwm0Duty) = 20000個(gè)脈沖正好為一個(gè)周期20毫秒
- Timer0Value(20000-Servo0PwmDuty0);
- i = 0;
- break;
- i++;
- void Timer_1(void) interrupt 3 using 1
- static uint j = 1; //靜態(tài)變量:每次調(diào)用函數(shù)時(shí)保持上一次所賦的值,
- switch(j)
- case 1:
- SERVO1 = 1; //PWM控制腳高電平
- Timer1Value(Servo0PwmDuty1);
- break;
- case 2:
- SERVO1 = 0; //PWM控制腳低電平
- Timer1Value(20000-Servo0PwmDuty1);
- j = 0;
- break;
- j++;
復(fù)制代碼 |
