查看: 2444|回復: 1
單片機+74hc164驅動數碼管顯示 亂碼
ID:5501 發表于 2021-4-23 16:52 | 顯示全部樓層 |閱讀模式
請交下師傅們 我寫的這個代碼164發送函數 放到主函數了就不能正常顯示了  但是在中斷函數里是可以正常顯示秒表的 謝謝
STC12C5406AD  12M CRYSTAL
Relay                P22
Display1        P25
Display2        P24
DATA_164        P23
CLK_164                P21
MR_164                P20
K1                P32
K2    P33
K3                P34
LED_Flash        P37
#include "STC12C5630AD.H"
#include <intrins.h>
#define uint  unsigned int
sbit MR_164                        = P2^0;                        //Pin9
sbit CLK_164                = P2^1;                 //Pin8 clk
sbit DATA_164                = P2^3;
sbit Relay                        = P2^2;                 //relay
sbit GRID1                        = P2^4;
sbit GRID2                        = P2^5;
sbit Key_start  = P3^2;
sbit Key_Set          = P3^3;
sbit Key_Down          = P3^4;
sbit LED_Flash        = P3^7;
bit led_flag;
const unsigned char code  Led_data[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0xfb};
unsigned int nCnt;
unsigned char sec=24,Cnt[2]={0xff,0xff};
void delayms (uint ms)
        unsigned int i;
        while( ms -- )
                for (i = 0; i < 600; i ++);//600 1T   125 12T
void IO_Mode_Setup (void)
        P2M1 = 0x00;        //0000 0000
        P2M0 = 0x00;
        P3M1 = 0x00;        //0000 0000
        P3M0 = 0x00;
void Timer0_init(void)
         AUXR &= 0x7f;//12t
         TMOD &= 0xf0;
         TMOD |= 0x01;//mode 1  16bit
         TH0 = 0xf8;
         TL0 = 0x30;
         TR0 = 1;
         TF0 = 0;
void PORT_init(void)
void SendByteData_164(unsigned char temp)
        unsigned char i;
        for (i = 0; i < 8; i++ )
                if (temp & 0x80 ){//′ó¸ßλ¿aê¼·¢Ëí
                                DATA_164 = 1;
                else{
                                DATA_164 = 0;
                        CLK_164 = 0;
                        CLK_164 = 1;
                  temp = temp << 1;
        CLK_164  = 0;        //êí·Å×üÏß
        DATA_164 = 0;
void  Timer0_isr (void) interrupt 1
        static unsigned int t=0;
        TH0 = 0xf8;  //12 2ms
        TL0 = 0x30;
        led_flag = ~led_flag;
        GRID1 = 1;
        GRID2 = 1;
  if(sec < 10){
                Cnt[0] = sec%10;
                Cnt[1] = 10;
        }else if(sec < 100){
                Cnt[1] = sec/10;
                Cnt[0] = sec%10;
        }else{
                sec = 0;
                SendByteData_164(Led_data[Cnt[led_flag]]);
                if(led_flag )
                        GRID1 = 0;
                }else {
                                        GRID2 = 0;
        if(t++ >= 500)//2ms*500=1000ms
                sec++;
                LED_Flash = !LED_Flash;
                t = 0;
                if(sec >= 100)
                        sec = 0;
void main (void)
        IO_Mode_Setup ();
        Timer0_init();
        SendByteData_164(Led_data[0]);
        MR_164 = 1;  //164 pin9 master resert
//  GRID1 = 0;         //¿aÆôλ1
//        GRID2 = 0;
        Relay = 0;        //S8550 11Ø±Õ 0 ¿aÆô
        P3 &= 0x80;
        LED_Flash = 0;
        ET0 = 1;
        EA = 1;
//                SendByteData_164(Led_data[Cnt[led_flag]]);
//這個函數放到這里 秒表就顯示兩個8.8. 不能正常顯示走動走時了 但是放到中斷函數里是正常顯示秒表的
        }//end while(1)
}//end main()
ID:332214 發表于 2021-4-23 17:40 | 顯示全部樓層
放在主函數里 是因為被定時器中斷搶占了 Cnt[led_flag], 這個變量在改變。
這就相當于 兩個線程共用一個變量,一個線程在賦值,另一個在取值,這中間不加個互斥鎖,會報錯的。
但單片機的中斷和系統上的線程還是有差異的,中斷執行時,主函數程序是暫停的。
解決辦法:就是在主程序調用這個變量的時候 不被定時器中斷打斷去改變這個值。
