查看: 1996|回復: 0
STM32F107_ST7756驅動程序
實驗成功能夠顯示字符,程序源碼如下
  1. #include <stm32f10x.h>
  2. #include "stm_systick.h"
  3. #include "hem12864.h"
  4. #include "stm_gpio_init.h"
  5. #include "FONT.H"
  6. //#define HEM12864_RS PDout(10)
  7. //#define HEM12864_RST PDout(9)
  8. //#define HEM12864_CS  PDout(8)
  9. //u8 charA[] ={0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00};/*"B",0*/
  10. //u8 chartemp[] = {0x10,0x60,0x02,0x8C,0x00,0x00,0xFE,0x92,0x92,0x92,0x92,0x92,0xFE,0x00,0x00,0x00,0x04,0x04,0x7E,0x01,0x40,0x7E,0x42,0x42,0x7E,0x42,0x7E,0x42,0x42,0x7E,0x40,0x00};/*"?",0*/
  11. void hem12864_gpio_init(void)
  12. {
  13. RCC->APB2ENR |= 1 << 5;//開GPIOD時鐘
  14. GPIOD->CRH &= 0xFFFF0000;
  15. GPIOD->CRH |= 0x00002222;//GPIOD0~11推挽輸出
  16. GPIOD->ODR |= 0x7 << 8;
  17. GPIOD->ODR &= 0 << 11;
  18. RCC->APB2ENR |= 1 << 3;//開GPIOB時鐘
  19. GPIOB->CRH &= 0x0F0FFFFF;
  20. GPIOB->CRH |= 0x20200000;//PB13/PB15推挽輸出
  21. GPIOB->ODR |= 1 << 13;//PB13上拉
  22. GPIOB->ODR |= 1 << 15;//PB15上拉
  23. }
  24. /*
  25. void HEM12864_SPI_Init(void)
  26. {
  27. RCC->APB2ENR |= 1 << 3;//開GPIOB時鐘
  28. RCC->APB1ENR |= 1 << 14;//開SPI2時鐘
  29. GPIOB->CRH &= 0x0F0FFFFF;
  30. GPIOB->CRH |= 0xB0B00000;//PB13/PB15復用
  31. GPIOB->ODR |= 1 << 13;//PB13上拉
  32. GPIOB->ODR |= 1 << 15;//PB15上拉
  33. SPI2->CR1 |= 0 << 10;//全雙工模式
  34. SPI2->CR1 |= 1 << 9;//軟件NSS管理
  35. SPI2->CR1 |= 1 << 8;
  36. SPI2->CR1 |= 1 << 2;//SPI主機
  37. SPI2->CR1 |= 0 << 11;//8Bit數據格式
  38. SPI2->CR1 |= 1 << 1;//空閑模式下SCK為1 CPOL=1
  39. SPI2->CR1 |= 1 << 0 ;//數據采樣從第二個時鐘邊沿開始,CPHA=1
  40. //對SPI2屬于APB1的外設,時鐘頻率最大為36M。
  41. SPI2->CR1 |= 4 << 3;        //FSCK = Fpclk1/32
  42. SPI2->CR1 |= 0 << 7;//MSB first
  43. SPI2->CR1 |= 1 << 6;//SPI設備使能
  44.
  45. }
  46. u8 SPI2_ReadWriteByte(u8 TxData)
  47. {
  48.         u16 retry=0;
  49.         while((SPI2->SR&1<<1)==0)                //等待發送區空
  50.         {
  51.                 retry++;
  52.                 if(retry>=0XFFFE)return 0;         //超時退出
  53.         }
  54.         SPI2->DR=TxData;                                   //發送一個Byte
  55.         retry=0;
  56.
  57. }
  58. */
  59. /*
  60. void HEM12864_Init(void)
  61. {
  62.         HEM12864_RST = 0;
  63. Delay_us(40000);
  64.         HEM12864_RST = 1;
  65.         HEM12864_CS = 0;
  66.         HEM12864_RS = 0;
  67.         SPI2_ReadWriteByte(0x30);
  68.         Delay_us(120);
  69.         SPI2_ReadWriteByte(0X30);
  70.         Delay_us(40);
  71.         SPI2_ReadWriteByte(0X0F);
  72.         Delay_us(120);
  73.         SPI2_ReadWriteByte(0X01);
  74.         Delay_us(10000);
  75.         SPI2_ReadWriteByte(0X06);
  76.
  77. }
  78. */
  79. //=========================LCD??????======================
  80. #define LCDA0 PDout(10)
  81. #define LCDRS PDout(9)
  82. #define HEM12864_CS  PDout(8)
  83. #define LCDSK  PBout(13)
  84. #define LCDSI  PBout(15)
  85. /*
  86. sbit LCDA0=P2^5;  //????
  87. sbit LCDSK=P2^6;  //????
  88. sbit LCDSI=P2^7;  //????
  89. sbit LCDRS=P2^4;  //????
  90. */
  91. //=========================????=============================
  92. void LCDInit();        //?????
  93. void LCDWritecom(char com);  //??????,????/????(0??,1??)
  94. void LCDShiftWrite(char dat);  //???????
  95. void LCDSetXY(char x, char y); //??????
  96. //void LCDcls(char);  //????,????????value
  97. //***************************????*******************************
  98. /*
  99. extern unsigned char code hzcode[][128]; //
  100. extern unsigned char code gbcode[][32];  //
  101. extern unsigned char code asc816code[][16]; //
  102. extern unsigned char code asc1832code[][64];  //
  103. extern unsigned char code arrow[]; //
  104. */
  105. void lcd12864_display_on(void) //顯示開
  106. {
  107. LCDWritecom(0xaf);
  108. }
  109. void lcd12864_display_off(void)//顯示關
  110. {
  111. LCDWritecom(0xae);
  112. }
  113. void lcd12864_display_normal(void)  //正常顯示
  114. {
  115. LCDWritecom(0xa6);
  116. }
  117. void lcd12864_display_reverse(void)  //反白顯示
  118. {
  119. LCDWritecom(0xa7);
  120. }
  121. void lcd12864_display_all_point_off(void) //全屏正常顯示
  122. {
  123. LCDWritecom(0xa4);
  124. }
  125. void lcd12864_display_all_point_on(void) //全屏點亮
  126. {
  127. LCDWritecom(0xa5);
  128. }
  129. void lcd12864_rst(void)
  130. {
  131.          LCDRS=0;       //LCD 復位有效(L)
  132.          Delay_us(1000); // 延時1ms , Datasheet 要求至少大于1us
  133.          LCDRS = 1;     //LCD 復位無效(H)
  134.          Delay_us(1000); //硬件復位
  135.          LCDWritecom(0xe2);                  //寄存器復位
  136.          Delay_us(1000);
  137. }
  138. //========================?????????=================================
  139. void LCDInit()
  140. {
  141.                HEM12864_CS = 0;
  142.          LCDRS=0;       //LCD 復位有效(L)
  143.          Delay_us(1000); // 延時1ms , Datasheet 要求至少大于1us
  144.          LCDRS = 1;     //LCD 復位無效(H)
  145.          Delay_us(1000); //硬件復位
  146.          LCDWritecom(0xe2);                  //寄存器復位
  147.          Delay_us(1000);
  148. //  電源管理初始
  149.          lcd12864_display_on();                   //0xaf顯示器開,0xae顯示器關
  150.          LCDWritecom(0x2f);                  ///0x2f升壓電路,電壓管理電路,
  151.                                           //電壓跟隨電路均開(0x28-0x2f為設置上電控制模式)
  152.          LCDWritecom(0x25);                   //0x20-0x27為V5電壓內部電阻調整設置
  153.          LCDWritecom(0x81);                  //電量設置模式
  154.          LCDWritecom(0x0f);                  //0x01-0x3f電量寄存器設置模式
  155.
  156.           // 根據屏的方向初始化安裝方向(復位后默認下面配置)
  157.          LCDWritecom(0xa0);                  //0xa0為Segment正向,0xa1 為Segment反向
  158. //(0xa0-0xa1為ADC方向選擇)
  159.          LCDWritecom(0xc8);                   //0xc0正向掃描,0xc8反射掃描
  160. // 顯示管理初始(復位后默認下面配置)
  161.          lcd12864_display_normal();                    //0xa6正向顯示,0xa7反向顯示
  162.          lcd12864_display_all_point_off();                 //0xa4正常顯示,0xa5全屏點亮
  163. // 指示器設置
  164. LCDWritecom(0xac);                  //
  165. LCDWritecom(0x00);                  //
  166. //背壓比設置
  167. LCDWritecom(0xf8);                  //
  168. LCDWritecom(0x00);                  //
  169.       //   LCDcls(0);                             //????????,????0
  170.
  171. }
  172. //========================?????(???????)=============================
  173. void LCDWritecom(char com)
  174. {
  175. //                 LCDCS = 0;                         //CS=0.?:??????CS,???????.
  176.
  177.
  178.                  LCDA0 = 0;                           //A0=0,????
  179.                  LCDShiftWrite(com);
  180. }
  181. void LCDWritedata(char data)
  182.          {
  183.                  LCDA0 = 1;                          //A0=1,????
  184.                  LCDShiftWrite(data);
  185.
  186. //        LCDCS = 1;                                 //CS=1.?:??????CS,???????.
  187. }
  188. //===========================??(??)??????================================
  189. void LCDShiftWrite(char dat)
  190. {
  191.      unsigned char i;                                      //??????
  192.      unsigned char Series,Temp;                           //??????
  193.
  194.      LCDSK = 0;                                           //SCL=0
  195.      Series = dat;
  196.      for(i=0; i<8; i++)
  197.      {
  198.                  LCDSK = 0;                              //SCL=0
  199.                  Temp=Series & 0x80;                    //???7?
  200.                  if(Temp)                               //??Temp=1,??SI=1.??Temp+0,??SI=0
  201.                  {
  202.                          LCDSI = 1;                    //SI=1
  203.                  }
  204.                  else
  205.                  {
  206.                          LCDSI = 0;                   //SI=0
  207.                  }
  208.                  LCDSK = 1;                          //SCL=1????
  209.                  Series = Series << 1;               //??1?
  210.
  211.      }
  212. }
  213. void LCD12864_Pos(u8 x,u8 y)
  214. {
  215.         u8  pos;
  216.         if (x==1)                   {x=0x80;}
  217.         else if (x==2)         {x=0x90;}
  218.         else if (x==3)         {x=0x88;}
  219.         else if (x==4)   {x=0x98;}
  220.         else x=0x80;
  221. ……………………
  222. …………限于本文篇幅 余下代碼請從51黑下載附件…………
ST7567.zip (3.6 KB, 下載次數: 4)
