查看: 2436|回復(fù): 0
菜鳥新手:求助Proteus仿真時(shí)lcd1602出現(xiàn)錯(cuò)誤controler received command whilst
ID:904947 發(fā)表于 2021-4-13 12:22 | 顯示全部樓層 |閱讀模式
1602程序:不知道怎么改
  1. #include "1602.h"
  2. #include "delay.h"
  3. #include <intrins.h>
  5. #define uint unsigned int
  6. #define _NOP() _nop_()
  7. sbit RS = P2^4;
  8. sbit RW = P2^5;
  9. sbit EN = P2^6;
  10. #define DataPort    P0
  11. #define DataPIN     P0
  12. #define CLR_RS (RS=0)
  13. #define SET_RS (RS=1)
  14. #define CLR_RW (RW=0)
  15. #define SET_RW (RW=1)
  16. #define CLR_EN (EN=0)
  17. #define SET_EN (EN=1)
  18. void DispStr(uchar x,uchar y,uchar *ptr)
  19. {
  20.     uchar *temp;
  21.     uchar i,n = 0;
  22.     temp = ptr;
  23.     while(*ptr++ != '\0')   n++;
  24.     for (i=0;i<n;i++)
  25.     {
  26.         Disp1Char(x++,y,temp[i]);
  27.         if (x == 0x10)
  28.         {
  29.             break;
  30.         }
  31.     }
  32. }
  33. void LocateXY(uchar x,uchar y)
  34. {
  35.     uchar temp;
  36.     temp = x&0x0f;
  37.     y &= 0x01;
  38.     if(y)   temp |= 0x40;
  39.     temp |= 0x80;
  40.     LcdWriteCommand(temp,1);
  41. }
  42. void Disp1Char(uchar x,uchar y,uchar data1)
  43. {
  44.     LocateXY( x, y );
  45.     LcdWriteData( data1 );
  46. }
  47. void LcdReset(void)
  48. {
  49. //    DataDir  = 0xFF;
  50.     LcdWriteCommand(0x38, 0);
  51.     DelayMs(5);
  52.     LcdWriteCommand(0x38, 0);
  53.     DelayMs(5);
  54.     LcdWriteCommand(0x38, 0);
  55.     DelayMs(5);
  56.     LcdWriteCommand(0x38, 1);
  57.     LcdWriteCommand(0x08, 1);
  58.     LcdWriteCommand(0x01, 1);
  59.     LcdWriteCommand(0x06, 1);
  60.     LcdWriteCommand(0x0c, 1);
  61. }
  62. void LcdClear(void)
  63. {
  64.         LcdWriteCommand(0x01,1);
  65.         DelayMs(5);
  66. }
  67. void LcdWriteCommand(uchar cmd,uchar chk)
  68. {
  69.     if (chk) WaitForEnable();
  70.     CLR_RS;
  71.     CLR_RW;
  72.     _NOP();
  73.     DataPort = cmd;
  74.     _NOP();
  75.     SET_EN;
  76.     _NOP();
  77.     _NOP();
  78.     CLR_EN;
  79. }
  80. void LcdWriteData( uchar data1 )
  81. {
  82.     WaitForEnable();
  83.     SET_RS;
  84.     CLR_RW;
  85.     SET_EN;
  86.
  87.         _NOP();
  88.     DataPort = data1;
  89.     _NOP();
  90.
  91.     _NOP();
  92.     _NOP();
  93.     CLR_EN;
  94. }
  95. void WaitForEnable(void)
  96. {
  97.           unsigned int later=0;
  98.         DataPort=0xff;
  99.     CLR_RS;
  100.     SET_RW;
  101.     _NOP();
  102.     SET_EN;
  103.     _NOP();
  104.     _NOP();
  105. //    while((DataPIN&Busy)!=0);
  106.     while(((DataPIN&0x80)!=0)&&(later<1000))
  107.     {
  108.       DelayUs2x(2);
  109.       later++;
  110.     }
  111.     CLR_EN;
  112. //    DataDir|=0xFF;
  113. }
接線圖
接線圖
