只需一步,快速開(kāi)始
查看: 4389|回復(fù): 0
51單片機(jī)智能藍(lán)牙APP定時(shí)器開(kāi)關(guān)插座喂食器藥盒程序 原理圖
電路原理圖如下:
單片機(jī)源程序如下:
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include <stdio.h>
  4. #include "delay.h"
  5. #include "ds1302.h"
  6. #include "1602.h"
  7. sbit relay = P1^3;//接口定義
  8. unsigned char dis0[16];//定義顯示區(qū)域臨時(shí)存儲(chǔ)數(shù)組
  9. unsigned char dis1[16];
  10. unsigned char dis2[16];
  11. unsigned char ReadTimeFlag= 0;//讀取時(shí)間標(biāo)志
  12. unsigned char SetFlag =0;        //時(shí)間設(shè)置標(biāo)志
  13. unsigned char i;
  14. unsigned char relayFlag=0;        //繼電器狀態(tài)標(biāo)志
  15. unsigned long times_20ms=0xaaaaaaaa;        //定時(shí)器計(jì)數(shù) 初始值可以任意值 這里隨便賦值為0xaaaaaaaa
  16. unsigned char uart_i =0;                   //串口接收計(jì)數(shù)
  17. unsigned char time_buf2[17]={20,18,4,1,12,55,00,6};//空年月日時(shí)分秒周;           //更新時(shí)間數(shù)組
  18. bit ReadTempFlag;//定義讀時(shí)間標(biāo)志
  19. unsigned char repotimes ;
  20. unsigned char disFlag ;        //更新
  21. xdata unsigned char dsHour_start_01 = 8;         //定時(shí)時(shí)分
  22. xdata unsigned char dsMin_start_01 = 0;
  23. xdata unsigned char dsHour_end_01 = 18;
  24. xdata unsigned char dsMin_end_01 = 30;
  25. //xdata unsigned char dsHour_start_01 = 8;         //A組定時(shí)時(shí)分
  26. //xdata unsigned char dsMin_start_01 = 0;
  27. //xdata unsigned char dsH02_A = 12;
  28. //xdata unsigned char dsM02_A = 30;
  29. unsigned char timeOverFlag =0;
  30. xdata unsigned char firstin =0;                          //首次接收到標(biāo)志
  31. xdata unsigned char tab[20];                                  //串口數(shù)據(jù)暫存
  32. xdata unsigned char Count=0;                                  //串口接收計(jì)數(shù)
  33. xdata unsigned char  uartbusy =0;                          //串口判忙
  34. void Init_Timer0(void);                 //函數(shù)聲明
  35. void uartSendStr(unsigned char *s,unsigned char length);
  36. void UART_Init(void);
  37. void uartSendByte(unsigned char dat);
  38. void main(void)
  39. {
  40.         Init_Timer0();        //定時(shí)器0初始化
  41.                 times_20ms = 0; //初始化對(duì)應(yīng)值
  42.         UART_Init();
  43.
  44.         relay = 0;//打開(kāi)
  45.         DelayMs(200);            //延時(shí)有助于穩(wěn)定
  46.         relay = 1;//關(guān)閉
  47.
  48.         Ds1302_Init();
  49. //         Ds1302_Write_Time();
  50.         Ds1302_Read_Time();//讀取時(shí)間參數(shù)
  51.         uartSendStr("ready ok !",10);
  52.         LCD_Init();           //初始化液晶
  53.         DelayMs(20);          //延時(shí)有助于穩(wěn)定
  54.         LCD_Clear();
  55.         LCD_Write_String(0,0,"my desiger! ");
  56.
  57.         while(1)
  58.         {
  59.
  60.                 if(SetFlag==1)     //如果接收到串口信息則更新時(shí)鐘
  61.                 {
  62.                         for(i=0;i<8;i++)
  63.                         {
  64.                                 time_buf1[i]=time_buf2[2*i]*10+time_buf2[2*i+1];//數(shù)據(jù)整合,如2個(gè)數(shù) 1和5整合成15
  65.                         }
  66.                         Ds1302_Write_Time();//接收更新的時(shí)間然后寫(xiě)入ds1302
  67.                         SetFlag=0;          //時(shí)鐘信息更新后標(biāo)志位清零
  68.                 }
  69.                 if(disFlag == 1) //定時(shí)讀取ds1302 定時(shí)時(shí)間到 則標(biāo)志位置1,處理過(guò)時(shí)間參數(shù)標(biāo)志位清零
  70.                 {
  71.                         disFlag=0;  //標(biāo)志位清零
  72.                         Ds1302_Read_Time();//讀取時(shí)間參數(shù)
  73.                         if((time_buf1[4]>=dsHour_start_01)&&(time_buf1[4]<=dsHour_end_01))  //對(duì)比時(shí)間段1
  74.                         {
  75.                                 if((dsHour_start_01 != dsHour_end_01))  //設(shè)置起止時(shí)不再同一小時(shí)
  76.                                 {
  77.                                         if((time_buf1[4]>dsHour_start_01)&&(time_buf1[4]<dsHour_end_01))        //兩個(gè)時(shí) 范圍內(nèi)
  78.                                         {
  79.                                                 timeOverFlag = 1;//打開(kāi)
  80.                                         }
  81.                                         else if((time_buf1[4] == dsHour_start_01) && (time_buf1[5]>=dsMin_start_01))  //啟停不在一個(gè)小時(shí)內(nèi) 當(dāng)前時(shí)間在啟動(dòng)時(shí)內(nèi)
  82.                                         {
  83.                                                  timeOverFlag = 1;//打開(kāi)
  84.                                         }
  85.                                         else if((time_buf1[4] == dsHour_end_01) && (time_buf1[5]<dsMin_end_01)) //啟停不在一個(gè)小時(shí)內(nèi) 當(dāng)前時(shí)間在停止時(shí)內(nèi)
  86.                                         {
  87.                                                  timeOverFlag = 1;//打開(kāi)
  88.                                         }
  89.                                         else
  90.                                         {timeOverFlag = 0;}
  91.                                 }
  92.                                 else if((dsHour_end_01==dsHour_start_01))  //同一個(gè)小時(shí)內(nèi)
  93.                                 {
  94.                                         if((time_buf1[5]>=dsMin_start_01) && (time_buf1[5]<dsMin_end_01)) //統(tǒng)一小時(shí)分鐘范圍內(nèi)
  95.                                         {timeOverFlag = 1;}//打開(kāi)
  96.                                         else
  97.                                         {timeOverFlag = 0;}          //關(guān)閉
  98.                                 }
  99.                         }
  100.                         else
  101.                         {
  102.                                 timeOverFlag = 0;          //關(guān)閉
  103.                         }
  104.                         if(timeOverFlag == 1){relay = 0;}//打開(kāi) 繼電器控制
  105.                         else {relay =1 ;}//關(guān)閉
  106.
  107.                         sprintf(dis0,"%02d-%02d-%02d-%d",(int)time_buf1[1],(int)time_buf1[2],(int)time_buf1[3],(int)time_buf1[7]);//年月日周 步數(shù)
  108.                         LCD_Write_String(0,0,dis0); //顯示數(shù)據(jù)
  109.                         sprintf(dis0,"s%02d:%02d",(int)dsHour_start_01,(int)dsMin_start_01);//起始時(shí)間
  110.                         LCD_Write_String(10,0,dis0); //顯示數(shù)據(jù)
  111.
  112.                         sprintf(dis1,"%02d:%02d:%02d  ",(int)time_buf1[4],(int)time_buf1[5],(int)time_buf1[6]);//時(shí)分秒
  113.                         LCD_Write_String(0,1,dis1); //顯示數(shù)據(jù)
  114.
  115.                         sprintf(dis1," e%02d:%02d",(int)dsHour_end_01,(int)dsMin_end_01);//結(jié)束時(shí)間
  116.                         LCD_Write_String(9,1,dis1); //顯示數(shù)據(jù)
  117.                         repotimes++;
  118.                         if(repotimes >= 8)          //定時(shí)上報(bào)
  119.                         {
  120.                                 repotimes = 0;//上報(bào)時(shí)間
  121.
  122.                                 sprintf(dis0,"*D20%02d%02d%02d#",(int)time_buf1[1],(int)time_buf1[2],(int)time_buf1[3],(int)time_buf1[7]);//年月日周
  123.                                 uartSendStr(dis0,11); //發(fā)送數(shù)據(jù)
  124.                                 uartSendStr("\r\n",2);
  125.
  126.                                 sprintf(dis1,"*T%02d%02d%02d#",(int)time_buf1[4],(int)time_buf1[5],(int)time_buf1[6]);//時(shí)分秒
  127.                                 uartSendStr(dis1,9); //發(fā)送數(shù)據(jù)
  128.                                 uartSendStr("\r\n",2);
  129.
  130.                                 sprintf(dis2,"*S%02d:%02d~%02d:%02d#",(int)dsHour_start_01,(int)dsMin_start_01,(int)dsHour_end_01,(int)dsMin_end_01);//打印
  131.                                 uartSendStr(dis2,14); //發(fā)送數(shù)據(jù)
  132.                                 uartSendStr("\r\n",2);
  133.                         }
  134.                 }
  135.         }
  136. }
  137. void Init_Timer0(void)
  138. {
  139. //**All notes can be deleted and modified**//
  140.   TMOD |= 0x10;          //使用模式1,16位定時(shí)器,使用"|"符號(hào)可以在使用多個(gè)定時(shí)器時(shí)不受影響
  141.         TH0=(65536-20000)/256;                  //重新賦值 20ms
  142.         TL0=(65536-20000)%256;
  143.         EA=1;            //總中斷打開(kāi)
  144.         ET0=1;           //定時(shí)器中斷打開(kāi)
  145.         TR0=1;           //定時(shí)器開(kāi)關(guān)打開(kāi)
  146. }
  147. void Timer0_isr(void) interrupt 1
  148. {
  149.         TH0=(65536-20000)/256;                  //重新賦值 20ms
  150.         TL0=(65536-20000)%256;
  151.         times_20ms++;  //計(jì)時(shí)++
  152.         if(times_20ms%5==0)
  153.         {
  154.                 disFlag=1;          //定時(shí)更新顯示 100ms
  155.         }
  156.         if(uartbusy>0)           //串口數(shù)據(jù)采集處理
  157.         {uartbusy--;} //串口一定時(shí)間內(nèi)接收到數(shù)據(jù)
  158.         else
  159.         {
  160.                 firstin =0; //重新賦值接收數(shù)據(jù)
  161.                 Count=0;//接收計(jì)數(shù)
  162.         }
  163. }
  164. void UART_Init(void)
  165. {
  166.     SCON  = 0x50;                        // SCON: 模式 1, 8-bit UART, 使能接收
  167.     TMOD |= 0x20;               // TMOD: timer 1, mode 2, 8-bit 重裝
  168.     TH1   = 0xFD;               // TH1:  重裝值 9600 波特率 晶振 11.0592MHz
  169.         TL1 = TH1;
  170.     TR1   = 1;                  // TR1:  timer 1 打開(kāi)
  171.     EA    = 1;                  //打開(kāi)總中斷
  172.     ES    = 1;                  //打開(kāi)串口中斷
  173. }
  174. void uartSendByte(unsigned char dat)
  175. {
  176.         unsigned char time_out;
  177.         time_out=0x00;
  178.         SBUF = dat;                          //將數(shù)據(jù)放入SBUF中
  179.         while((!TI)&&(time_out<100))  //檢測(cè)是否發(fā)送出去
  180.         {time_out++;DelayUs2x(10);}        //未發(fā)送出去 進(jìn)行短暫延時(shí)
  181.         TI = 0;                                                //清除ti標(biāo)志
  182. }
  183. void uartSendStr(unsigned char *s,unsigned char length)
  184. {
  185.         unsigned char NUM;
  186.         NUM=0x00;
  187.         while(NUM<length)        //發(fā)送長(zhǎng)度對(duì)比
  188.         {
  189.                 uartSendByte(*s);  //放松單字節(jié)數(shù)據(jù)
  190.                 s++;                  //指針++
  191.                 NUM++;                  //下一個(gè)++
  192.            }
  193. }
  194. void UART_SER (void) interrupt 4         //串行中斷服務(wù)程序
  195. {
  196.         unsigned char r_buf;
  197.         if(RI)                        //判斷是接收中斷產(chǎn)生
  198.         {
  199.                 RI=0;                      //標(biāo)志位清零
  200.                 r_buf = SBUF;
  201.                 uartbusy = 20;
  202.                 if(r_buf=='*')                //接收到起始標(biāo)志
  203.                 {
  204.                         firstin = 1; //接收標(biāo)志成功
  205.                         Count = 0;
  206.                         tab[Count++]=r_buf;
  207.                 }
  208.                 else if(firstin == 1)          //接收到其實(shí)標(biāo)志成功
  209.                 {
  210.                         tab[Count++]=r_buf;
  211.                         if((Count>=18)&&(tab[17] == '#')) //接收到設(shè)置時(shí)間命令
  212.                         {
  213.                                 for(i=0;i<16;i++)
  214.                                 {
  215.                                          time_buf2[i]=tab[1+i]&0x0F; //提取設(shè)置值
  216.                                 }
  217.                                 SetFlag=1 ;                 //設(shè)置時(shí)間標(biāo)志置位
  218.                                 firstin =0;
  219.                                 Count=0;
  220.                         }
  221.                         else if((Count>=14)&&(tab[13] == '#')) //接收到設(shè)置時(shí)間段//**All notes can be deleted and modified**//
  222.                         {
  223.                                 if(tab[2] == 'T')
  224.                                 {
  225.                                         dsHour_start_01 =( tab[3] - '0'        )*10 + (tab[4]-'0');  //起始時(shí)間提取
  226.                                         dsMin_start_01 =( tab[5] - '0'        )*10 + (tab[6]-'0');
  227.                                         dsHour_end_01 =( tab[8] - '0'        )*10 + (tab[9]-'0'); //結(jié)束時(shí)間提取
  228.                                         dsMin_end_01 =( tab[10] - '0'        )*10 + (tab[11]-'0');
  229.                                 }
  230.                                 firstin =0;
  231.                                 Count=0;
  232.                         }
  233.                         else if(Count>=20) //接收數(shù)據(jù)很長(zhǎng) 但是不是所需要的
  234.                         {
  235.                                 firstin =0;
  236.                                 Count=0;
  237.                         }
  238.                 }
  239.         }
  240.         if(TI)  //如果是發(fā)送標(biāo)志位,清零
  241.         TI=0;
  242. }
代碼: 51-162、程序-單片機(jī)源碼.zip (90.66 KB, 下載次數(shù): 48)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
收藏收藏6 分享淘帖 頂 踩
