查看: 4239|回復(fù): 1
基于51單片機的定時鬧鐘設(shè)計 Proteus仿真程序
ID:687158 發(fā)表于 2021-3-29 10:16 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
基于單片機的定時鬧鐘設(shè)計仿真圖
程序設(shè)計:
  1. #include "reg52.h"
  2. #include "intrins.h"
  3. #include <stdio.h>
  4. sbit j=P3^0;
  5. sbit s1=P3^2;
  6. sbit s2=P3^3;
  7. sbit s3=P3^4;
  8. sbit s4=P3^5;
  9. void Timer0Init();
  10. void Delay10ms();
  11. void shumaguan();
  12. void shijianxianshi();
  13. void naozhongxianshi();
  14. void bao();
  15. void tiao();
  16. unsigned char code xu[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0xbf};
  17. unsigned char zhongjian[]={0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
  18. int i,shi,fen,miao,n,nmia,nshi=0,nfen=0,nmiao=10,t,a;
  19. void main()
  20. {
  21.         Timer0Init();
  22. while(1)
  23. {
  24. shumaguan();
  25.         tiao();
  26.         if(t==0) shijianxianshi();
  27.         if(t==1) naozhongxianshi();
  28.         bao();
  29. }
  30. }
  31. void tiao()
  32. {
  33. if(s1==0)
  34. {
  35. Delay10ms();
  36.         if(s1==0)
  37.         {
  38.         t++;
  39.                 if(t==2) t=0;
  40.         }
  41.         while(!s1);
  42. }
  43. if(s2==0)
  44. {
  45. Delay10ms();
  46.         if(s2==0)
  47.         {
  48.         a++;
  49.                 if(a>2) a=0;
  50.         }
  51.         while(!s2);
  52. }
  53. if(s3==0)
  54. {
  55. Delay10ms();
  56.         if(s3==0)
  57.         {
  58.         if(a==0)
  59.         {
  60.         nmiao++;
  61.                 if(nmiao>59) nmiao=0;
  62.         }
  63.         if(a==1)
  64.         {
  65.         nfen++;
  66.                 if(nfen>59) nfen=0;
  67.         }
  68.         if(a==2)
  69.         {
  70.         nshi++;
  71.                 if(nshi>23) nshi=0;
  72.         }
  73.         }
  74.         while(!s3);
  75. }
  76. if(s4==0)
  77. {
  78. Delay10ms();
  79.         if(s4==0)
  80.         {
  81.         if(a==0)
  82.         {
  83.         nmiao--;
  84.                 if(nmiao<0) nmiao=59;
  85.         }
  86.         if(a==1)
  87.         {
  88.         nfen--;
  89.                 if(nfen<0) nfen=59;
  90.         }
  91.         if(a==2)
  92.         {
  93.         nshi--;
  94.                 if(nshi<0) nshi=23;
  95.         }
  96.         }
  97.         while(!s4);
  98. }
  99. }
  100. void bao()
  101. {
  102.         nmia=nmiao+1;
  103. if(shi==nfen&fen==nfen&miao==nmiao)  j=0;
  104. if(shi==nfen&fen==nfen&miao==nmia)   j=1;
  105. }
  106. void naozhongxianshi()
  107. {
  108.   zhongjian[0]=xu[nshi/10];
  109.         zhongjian[1]=xu[nshi%10];
  110.         zhongjian[2]=0xbf;
  111.         zhongjian[3]=xu[nfen/10];
  112.         zhongjian[4]=xu[nfen%10];
  113.         zhongjian[5]=0xbf;
  114.         zhongjian[6]=xu[nmiao/10];
  115.         zhongjian[7]=xu[nmiao%10];
  116. }
  117. void shijianxianshi()
  118. {
  119.   zhongjian[0]=xu[shi/10];
  120.         zhongjian[1]=xu[shi%10];
  121.         zhongjian[2]=0xbf;
  122.         zhongjian[3]=xu[fen/10];
  123.         zhongjian[4]=xu[fen%10];
  124.         zhongjian[5]=0xbf;
  125.         zhongjian[6]=xu[miao/10];
  126.         zhongjian[7]=xu[miao%10];
  127. }
  128. void Timer0Init()                //5毫秒@11.0592MHz
  129. {
  130.         TMOD &= 0xF0;                //設(shè)置定時器模式
  131.         TL0 = 0x00;                //設(shè)置定時初值
  132.         TH0 = 0x28;                //設(shè)置定時初值
  133.         TF0 = 0;                //清除TF0標志
  134.         TR0 = 1;                //定時器0開始計時
  135.         EA=1;ET0=1;
  136. }
  137. void Timer0() interrupt 1
  138. {
  139. n++;
  140.         if(n>200)
  141.         {
  142.         miao++;
  143.                 n=0;
  144.         }
  145.         if(miao>59)
  146.         {
  147.         fen++;
  148.                 miao=0;
  149.         }
  150.         if(fen>59)
  151.         {
  152.         shi++;
  153.                 fen=0;
  154.         }
  155.         if(shi>23)
  156.         {
  157.         shi=0;
  158.         }
  159. }
  160. void shumaguan()
  161. {
  162.           P2=0x00;
  163.            P1=0xff;
  164.           P2=1<<i;
  165.            P1=zhongjian[i];
  166.                 i++;
  167.         if(i>7)
  168.                 i=0;
  169. }
  170. void Delay10ms()                //@11.0592MHz
  171. {
  172.         unsigned char i, j;
  173.         i = 108;
  174.         j = 145;
  175.         do
  176.         {
  177.                 while (--j);
  178.         } while (--i);
  179. }
基于單片機的定時鬧鐘設(shè)計.zip (76.42 KB, 下載次數(shù): 102)
收藏收藏4 分享淘帖 頂 踩
ID:535849 發(fā)表于 2022-7-5 13:44 來自觸屏版 | 只看該作者
http://m.raoushi.com/bbs/dpj-199506-1.html
