查看: 4273|回復: 3
基于單片機+TM1637的數碼管顯示程序
ID:675856 發表于 2021-3-24 17:45 | 顯示全部樓層 |閱讀模式
  1. #include <STC8G.h>
  2. #include <intrins.h>
  3. #define u8 unsigned char
  4. #define u16 unsigned int
  5. sbit DIO = P1^0;
  6. sbit CLK = P1^1;
  7. //u8 num[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7f,0x6F};
  8. u8 num[10]={0xBF,0x86,0xDB,0xCF,0xE6,0xED,0xFD,0x87,0xFf,0xEF};
  9. u16 ms,second,min,hour;
  10. void Delay2us()                //@11.0592MHz
  11. {
  12.         unsigned char i;
  13.         _nop_();
  14.         i = 5;
  15.         while (--i);
  16. }
  17. void Delay3us()                //@11.0592MHz
  18. {
  19.         unsigned char i;
  20.         i = 9;
  21.         while (--i);
  22. }
  23. void Delay5us()                //@11.0592MHz
  24. {
  25.         unsigned char i;
  26.         _nop_();
  27.         i = 16;
  28.         while (--i);
  29. }
  30. void I2CStart()
  31. {
  32.         CLK = 1;
  33.         DIO = 1;
  34.         Delay2us();
  35.         DIO = 0;
  36. }
  37. void I2CAsk()
  38. {
  39.         CLK = 0;
  40.         Delay5us();
  41.         while(DIO);
  42.         CLK = 1;
  43.         Delay2us();
  44.         CLK = 0;
  45. }
  46. void I2CStop()
  47. {
  48.         CLK = 0;
  49.         Delay2us();
  50.         DIO = 0;
  51.         Delay2us();
  52.         CLK = 1;
  53.         Delay2us();
  54.         DIO = 1;
  55. }
  56. void I2CWriteByte(u8 dat)
  57. {
  58.         u8 i;
  59.         for(i=0;i<8;i++)
  60.         {
  61.                 CLK = 0;
  62.                 if(dat&0x01)
  63.                 {
  64.                         DIO = 1;
  65.                 }
  66.                 else
  67.                 {
  68.                         DIO = 0;
  69.                 }
  70.                 Delay3us();
  71.                 dat>>=1;
  72.                 CLK = 1;
  73.                 Delay3us();
  74.         }
  75. }
  76. void Display(u8 m,u8 s)
  77. {
  78.         I2CStart();
  79.         I2CWriteByte(0x40);
  80.         I2CAsk();
  81.         I2CStop();
  82.         I2CStart();
  83.         I2CWriteByte(0xC0);
  84.         I2CAsk();
  85.         I2CWriteByte(num[m/10]);
  86.         I2CAsk();
  87.         I2CWriteByte(num[m%10]);
  88.         I2CAsk();
  89.         I2CWriteByte(num[s/10]);
  90.         I2CAsk();
  91.         I2CWriteByte(num[s%10]);
  92.         I2CAsk();
  93.         I2CWriteByte(0xFF);
  94.         I2CAsk();
  95.         I2CWriteByte(0xFF);
  96.         I2CAsk();
  97.         I2CStop();
  98.         I2CStart();
  99.         I2CWriteByte(0x8F);
  100.         I2CAsk();
  101.         I2CStop();
  102. }
  103. void Timer0Init(void)                //1毫秒@11.0592MHz
  104. {
  105.         AUXR |= 0x80;
  106.         TMOD &= 0xF0;
  107.         TL0 = 0xCD;
  108.         TH0 = 0xD4;
  109.         ET0 = 1;
  110.         EA = 1;
  111.         TF0 = 0;
  112.         TR0 = 1;
  113. }
  114. void TM0_Isr() interrupt 1
  115. {
  116.         ms++;
  117.         if(ms==1000)
  118.         {
  119.                 ms=0;
  120.                 second++;
  121.                 if(second==60)
  122.                 {
  123.                         second=0;
  124.                         min++;
  125.                         if(min==60)
  126.                         {
  127.                                 min=0;
  128.                                 hour++;
  129.                                 if(hour==24)
  130.                                 {
  131.                                         hour=0;
  132.                                 }
  133.                         }
  134.                 }
  135.         }
  136. }
  137. void main()
  138. {
  139.         P1M0 = 0x00;
  140.         P1M1 = 0x00;
  141.         Timer0Init();
  142.         while(1)
  143.         {
  144.                 Display(min,second);
  145.         }
  146. }
所有代碼51hei提供下載:
四位數碼管顯示.rar (40.4 KB, 下載次數: 58)
參與人數 2黑幣 +60 收起 理由
lzh085 + 10 贊一個!
ID:229641 發表于 2021-3-30 23:15 來自觸屏版 | 顯示全部樓層
樓主有8g1k08a的例程嗎?
ID:923440 發表于 2021-6-10 14:41 | 顯示全部樓層
觸景情傷 發表于 2021-3-30 23:15
樓主有8g1k08a的例程嗎?
同求,有嘛
ID:230742 發表于 2021-6-18 02:06 | 顯示全部樓層
這個不就是8G的嗎。
