有沒有大佬能幫忙看下
2021-3-16 19:06 上傳
#include <reg52.h>
#include<absacc.h>
#define DATA P1
#define PA XBYTE[0xBcFF]
#define PB XBYTE[0xBdFF]
#define PC XBYTE[0xBeFF]
#define COM XBYTE[0xBFFF]
sbit OE = P2^5;
sbit EOC = P3^3;
sbit ST = P2^7;
sbit C1 = P3^0;
sbit C2 = P3^1;
sbit C3 = P3^2;
uint display_data = 0; /*顯示數據*/
uchar code LEDData[]=
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
void DelayMS(uint ms)
uchar i;
while(ms--)
for(i=0;i<120;i++);
void Display_Result(uint d)
P2 = 0xf7;
PB = LEDData[d%10];
DelayMS(5);
P2 = 0xfb;
PB = LEDData[d%100/10];
DelayMS(5);
P2 = 0xfd;
PB = (LEDData[d%1000/100]| 0x80);
DelayMS(5);
P2 = 0xfe;
PC = LEDData[d/1000];
DelayMS(5);
COM =0X80;
C1 = 1;
C2 = 1;
C3 = 0;
ST = 0;
ST = 1;
ST = 0;
while(EOC == 0);
OE = 1;
display_data = ((8.0/255) * DATA) * 1000;
Display_Result(display_data);
OE = 0;
圖里面的開關本來是想要控制PB口的,全為1就輸出,否則就不輸出(但還沒寫程序)。
目的是做一個數模轉換的C語言顯示,必須要用8255驅動數碼管,所以這有點迷茫。
1123.rar
2021-3-16 19:07 上傳
30.48 KB, 下載次數: 4
