我想用OLED來畫出豎橫斜線。
現在畫點函數已經做好了,畫橫豎線就容易了。
- sbit SCL=P1^4; //串行時鐘
- sbit SDA=P1^3; //串行數據
- #define high 1
- #define low 0
- #define Brightness 0xCF
- #define X_WIDTH 128
- #define Y_WIDTH 64
- /*********************OLED驅動程序用的延時程序************************************/
- void delay(unsigned int z)
- unsigned int x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- //IIC Start
- void IIC_Start()
- SCL = high;
- SDA = high;
- SDA = low;
- SCL = low;
- //IIC Stop
- void IIC_Stop()
- SCL = low;
- SDA = low;
- SCL = high;
- SDA = high;
- // 通過I2C總線寫一個字節
- void Write_IIC_Byte(unsigned char IIC_Byte)
- unsigned char i;
- for(i=0;i<8;i++)
- if(IIC_Byte & 0x80)
- SDA=high;
- else
- SDA=low;
- SCL=high;
- SCL=low;
- IIC_Byte<<=1;
- SDA=1;
- SCL=1;
- SCL=0;
- /*********************OLED寫數據************************************/
- void OLED_WrDat(unsigned char IIC_Data)
- IIC_Start();
- Write_IIC_Byte(0x78);
- Write_IIC_Byte(0x40); //write data
- Write_IIC_Byte(IIC_Data);
- IIC_Stop();
- /*********************OLED寫命令************************************/
- void OLED_WrCmd(unsigned char IIC_Command)
- IIC_Start();
- Write_IIC_Byte(0x78); //Slave address,SA0=0
- Write_IIC_Byte(0x00); //write command
- Write_IIC_Byte(IIC_Command);
- IIC_Stop();
- /*********************OLED 設置坐標************************************/
- void OLED_Set_Pos(unsigned char x, unsigned char y)
- OLED_WrCmd(0xb0+y);
- OLED_WrCmd(((x&0xf0)>>4)|0x10);
- OLED_WrCmd((x&0x0f)|0x01);
- /*********************OLED全屏************************************/
- void OLED_Fill(unsigned char bmp_dat)
- unsigned char y,x;
- for(y=0;y<8;y++)
- OLED_WrCmd(0x01);
- OLED_WrCmd(0x10);
- for(x=0;x<X_WIDTH;x++)
- OLED_WrDat(bmp_dat);
- /*********************OLED復位************************************/
- void OLED_CLS(void)
- for(y=0;y<8;y++)
- OLED_WrCmd(0x01);
- OLED_WrCmd(0x10);
- OLED_WrDat(0);
- /*********************OLED初始化************************************/
- void OLED_Init(void)
- delay(500);//初始化之前的延時很重要!
- OLED_WrCmd(0xae);//--turn off oled panel
- OLED_WrCmd(0x00);//---set low column address
- OLED_WrCmd(0x10);//---set high column address
- OLED_WrCmd(0x40);//--set start line address Set Mapping RAM Display Start Line (0x00~0x3F)
- OLED_WrCmd(0x81);//--set contrast control register
- OLED_WrCmd(Brightness); // Set SEG Output Current Brightness
- OLED_WrCmd(0xa1);//--Set SEG/Column Mapping 0xa0左右反置 0xa1正常
- OLED_WrCmd(0xc8);//Set COM/Row Scan Direction 0xc0上下反置 0xc8正常
- OLED_WrCmd(0xa6);//--set normal display
- OLED_WrCmd(0xa8);//--set multiplex ratio(1 to 64)
- OLED_WrCmd(0x3f);//--1/64 duty
- OLED_WrCmd(0xd3);//-set display offset Shift Mapping RAM Counter (0x00~0x3F)
- OLED_WrCmd(0x00);//-not offset
- OLED_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency
- OLED_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec
- OLED_WrCmd(0xd9);//--set pre-charge period
- OLED_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
- OLED_WrCmd(0xda);//--set com pins hardware configuration
- OLED_WrCmd(0x12);
- OLED_WrCmd(0xdb);//--set vcomh
- OLED_WrCmd(0x40);//Set VCOM Deselect Level
- OLED_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)
- OLED_WrCmd(0x02);//
- OLED_WrCmd(0x8d);//--set Charge Pump enable/disable
- OLED_WrCmd(0x14);//--set(0x10) disable
- OLED_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5)
- OLED_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7)
- OLED_WrCmd(0xaf);//--turn on oled panel
- OLED_Fill(0x00); //初始清屏
- OLED_Set_Pos(0,0);
- /***************功能描述:顯示6*8一組標準ASCII字符串 顯示的坐標(x,y),y為頁范圍0~7****************/
- void OLED_P6x8Str(unsigned char x, y,unsigned char ch[])
- unsigned char c=0,i=0,j=0;
- while (ch[j]!='\0')
- c =ch[j]-32;
- if(x>126){x=0;y++;}
- OLED_Set_Pos(x,y);
- for(i=0;i<6;i++)
- OLED_WrDat(F6x8[c][i]);
- x+=6;
- j++;
- /*******************功能描述:顯示8*16一組標準ASCII字符串 顯示的坐標(x,y),y為頁范圍0~7****************/
- void OLED_P8x16Str(unsigned char x, y,unsigned char ch[])
- c =ch[j]-32;
- if(x>120){x=0;y++;}
- for(i=0;i<8;i++)
- OLED_WrDat(F8X16[c*16+i]);
- OLED_Set_Pos(x,y+1);
- for(i=0;i<8;i++)
- OLED_WrDat(F8X16[c*16+i+8]);
- x+=8;
- j++;
- /*****************功能描述:顯示16*16點陣 顯示的坐標(x,y),y為頁范圍0~7****************************/
- void OLED_P16x16Ch(unsigned char x, y, N)
- unsigned char wm=0;
- unsigned int adder=32*N;
- OLED_Set_Pos(x , y);
- for(wm = 0;wm < 16;wm++)
- OLED_WrDat(F16x16[adder]);
- adder += 1;
- OLED_Set_Pos(x,y + 1);
- adder += 1;
- /***********功能描述:顯示顯示BMP圖片128×64起始點坐標(x,y),x的范圍0~127,y為頁的范圍0~7*****************/
- void Draw_BMP(unsigned char x0, y0,x1, y1,unsigned char BMP[])
- unsigned int j=0;
- unsigned char x,y;
- if(y1%8==0) y=y1/8;
- else y=y1/8+1;
- for(y=y0;y<y1;y++)
- OLED_Set_Pos(x0,y);
- for(x=x0;x<x1;x++)
- OLED_WrDat(BMP[j++]);
- void OLED_Point(unsigned char x, y)
- switch(y)
- case(0):OLED_Set_Pos(x,0);OLED_WrDat(0x01);break;
- case(1):OLED_Set_Pos(x,0);OLED_WrDat(0x02);break;
- case(2):OLED_Set_Pos(x,0);OLED_WrDat(0x04);break;
- case(3):OLED_Set_Pos(x,0);OLED_WrDat(0x08);break;
- case(4):OLED_Set_Pos(x,0);OLED_WrDat(0x10);break;
- case(5):OLED_Set_Pos(x,0);OLED_WrDat(0x20);break;
- case(6):OLED_Set_Pos(x,0);OLED_WrDat(0x40);break;
- case(7):OLED_Set_Pos(x,0);OLED_WrDat(0x80);break;
- case(8):OLED_Set_Pos(x,1);OLED_WrDat(0x01);break;
- case(9):OLED_Set_Pos(x,1);OLED_WrDat(0x02);break;
- case(10):OLED_Set_Pos(x,1);OLED_WrDat(0x04);break;
- case(11):OLED_Set_Pos(x,1);OLED_WrDat(0x08);break;
- case(12):OLED_Set_Pos(x,1);OLED_WrDat(0x10);break;
- case(13):OLED_Set_Pos(x,1);OLED_WrDat(0x20);break;
- case(14):OLED_Set_Pos(x,1);OLED_WrDat(0x40);break;
- case(15):OLED_Set_Pos(x,1);OLED_WrDat(0x80);break;
- case(16):OLED_Set_Pos(x,2);OLED_WrDat(0x01);break;
- case(17):OLED_Set_Pos(x,2);OLED_WrDat(0x02);break;
- case(18):OLED_Set_Pos(x,2);OLED_WrDat(0x04);break;
- case(19):OLED_Set_Pos(x,2);OLED_WrDat(0x08);break;
- case(20):OLED_Set_Pos(x,2);OLED_WrDat(0x10);break;
- case(21):OLED_Set_Pos(x,2);OLED_WrDat(0x20);break;
- case(22):OLED_Set_Pos(x,2);OLED_WrDat(0x40);break;
- case(23):OLED_Set_Pos(x,2);OLED_WrDat(0x80);break;
- case(24):OLED_Set_Pos(x,3);OLED_WrDat(0x01);break;
- case(25):OLED_Set_Pos(x,3);OLED_WrDat(0x02);break;
- case(26):OLED_Set_Pos(x,3);OLED_WrDat(0x04);break;
- case(27):OLED_Set_Pos(x,3);OLED_WrDat(0x08);break;
- case(28):OLED_Set_Pos(x,3);OLED_WrDat(0x10);break;
- case(29):OLED_Set_Pos(x,3);OLED_WrDat(0x20);break;
- case(30):OLED_Set_Pos(x,3);OLED_WrDat(0x40);break;
- case(31):OLED_Set_Pos(x,3);OLED_WrDat(0x80);break;
- case(32):OLED_Set_Pos(x,4);OLED_WrDat(0x01);break;
- case(33):OLED_Set_Pos(x,4);OLED_WrDat(0x02);break;
- case(34):OLED_Set_Pos(x,4);OLED_WrDat(0x04);break;
- case(35):OLED_Set_Pos(x,4);OLED_WrDat(0x08);break;
- case(36):OLED_Set_Pos(x,4);OLED_WrDat(0x10);break;
- case(37):OLED_Set_Pos(x,4);OLED_WrDat(0x20);break;
- case(38):OLED_Set_Pos(x,4);OLED_WrDat(0x40);break;
- case(39):OLED_Set_Pos(x,4);OLED_WrDat(0x80);break;
- case(40):OLED_Set_Pos(x,5);OLED_WrDat(0x01);break;
- case(41):OLED_Set_Pos(x,5);OLED_WrDat(0x02);break;
- case(42):OLED_Set_Pos(x,5);OLED_WrDat(0x04);break;
- case(43):OLED_Set_Pos(x,5);OLED_WrDat(0x08);break;
- case(44):OLED_Set_Pos(x,5);OLED_WrDat(0x10);break;
- case(45):OLED_Set_Pos(x,5);OLED_WrDat(0x20);break;
- case(46):OLED_Set_Pos(x,5);OLED_WrDat(0x40);break;
- case(47):OLED_Set_Pos(x,5);OLED_WrDat(0x80);break;
- case(48):OLED_Set_Pos(x,6);OLED_WrDat(0x01);break;
- case(49):OLED_Set_Pos(x,6);OLED_WrDat(0x02);break;
- case(50):OLED_Set_Pos(x,6);OLED_WrDat(0x04);break;
- case(51):OLED_Set_Pos(x,6);OLED_WrDat(0x08);break;
- case(52):OLED_Set_Pos(x,6);OLED_WrDat(0x10);break;
- case(53):OLED_Set_Pos(x,6);OLED_WrDat(0x20);break;
- case(54):OLED_Set_Pos(x,6);OLED_WrDat(0x40);break;
- case(55):OLED_Set_Pos(x,6);OLED_WrDat(0x80);break;
- case(56):OLED_Set_Pos(x,7);OLED_WrDat(0x01);break;
- case(57):OLED_Set_Pos(x,7);OLED_WrDat(0x02);break;
- case(58):OLED_Set_Pos(x,7);OLED_WrDat(0x04);break;
- case(59):OLED_Set_Pos(x,7);OLED_WrDat(0x08);break;
- case(60):OLED_Set_Pos(x,7);OLED_WrDat(0x10);break;
- case(61):OLED_Set_Pos(x,7);OLED_WrDat(0x20);break;
- case(62):OLED_Set_Pos(x,7);OLED_WrDat(0x40);break;
- case(63):OLED_Set_Pos(x,7);OLED_WrDat(0x80);break;
- void OLED_XLine(unsigned char x0, y0,x1)
- unsigned char z;
- if(x0<=x1)
- OLED_Point(x0, y0);
- for(z=x0;z<x1;z++)
- OLED_Point(z, y0);
- if(x0>=x1)
- for(z=x0;z<=x1;z--) //z=16 z=0 z--
復制代碼 但不知道為什么,畫點函數有些地方就不能一起顯示(表達能力有限,可以自己試下)!
例如:
- OLED_Point(0, 0);
- OLED_Point(1, 1);
復制代碼 大家可以在自己的屏幕上試試看。
還有,畫豎線函數我編好后下載到屏幕上卻花屏。
源碼:- void OLED_YLine(unsigned char y0, x0,y1)
- unsigned char z;
- if(y0<=y1)
- for(z=y0;z<y1;z++)
- OLED_Point(x0, z);
- if(y0>=y1)
- for(z=y0;z<=y1;z--) //z=16 z=0 z--
復制代碼 現在求助各位大神,給我解釋以下這怎么回事!
