查看: 3056|回復: 0
我的stm32f405rgt6的dma串口通信代碼
ID:889554 發表于 2021-3-8 15:14 | 顯示全部樓層 |閱讀模式
這是我前幾天寫的dma串口發送數據的代碼,已經與上位機通信驗證過正確性,可以直接使用。我提供.c和.h代碼
歡迎大家使用。
  1. #include "main.h"
  2. char SendToPC_Buff[6];
  3. int i;
  4. void vUart4Config(void)
  5. {
  6.         USART_InitTypeDef uart4;
  7.         GPIO_InitTypeDef  gpio;
  8.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
  9.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4,ENABLE);
  10.         GPIO_PinAFConfig(GPIOC,GPIO_PinSource10,GPIO_AF_UART4);
  11.         GPIO_PinAFConfig(GPIOC,GPIO_PinSource11,GPIO_AF_UART4);
  12.         /* all AF_PP? */
  13.         gpio.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11;
  14.         gpio.GPIO_Mode = GPIO_Mode_AF;
  15.         gpio.GPIO_OType = GPIO_OType_PP;
  16.         gpio.GPIO_Speed = GPIO_Speed_100MHz;
  17.         gpio.GPIO_PuPd = GPIO_PuPd_NOPULL;
  18.         GPIO_Init(GPIOC,&gpio);
  19.         uart4.USART_BaudRate = 115200;
  20.         uart4.USART_WordLength = USART_WordLength_8b;
  21.         uart4.USART_StopBits = USART_StopBits_1;
  22.         uart4.USART_Parity = USART_Parity_No;
  23.         uart4.USART_Mode = USART_Mode_Tx|USART_Mode_Rx;
  24.         uart4.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  25.         USART_Init(UART4,&uart4);
  26.
  27.         USART_ITConfig(UART4,USART_IT_IDLE,ENABLE);
  28.
  29.         USART_Cmd(UART4,ENABLE);
  30.         USART_DMACmd(UART4,USART_DMAReq_Rx,ENABLE);
  31.         USART_DMACmd(UART4,USART_DMAReq_Tx,ENABLE);
  32.
  33.
  34.         { /* send dma */
  35.                 DMA_InitTypeDef dma;
  36.                 RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1,ENABLE);
  37.                 DMA_DeInit(DMA1_Stream4);
  38.                 dma.DMA_Channel= DMA_Channel_4;
  39.                 dma.DMA_PeripheralBaseAddr = (uint32_t)&(UART4->DR);
  40.                 dma.DMA_Memory0BaseAddr = (uint32_t)SendToPC_Buff;
  41.                 dma.DMA_DIR = DMA_DIR_MemoryToPeripheral;
  42.                 dma.DMA_BufferSize = 6;
  43.                 dma.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  44.                 dma.DMA_MemoryInc = DMA_MemoryInc_Enable;
  45.                 dma.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  46.                 dma.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  47.                 dma.DMA_Mode = DMA_Mode_Circular;
  48.                 dma.DMA_Priority = DMA_Priority_VeryHigh;
  49.                 dma.DMA_FIFOMode = DMA_FIFOMode_Disable;
  50.                 dma.DMA_FIFOThreshold = DMA_FIFOThreshold_1QuarterFull;
  51.                 dma.DMA_MemoryBurst = DMA_Mode_Normal;
  52.                 dma.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  53.                 DMA_Init(DMA1_Stream4,&dma);
  54.                 DMA_ITConfig(DMA1_Stream4,DMA_IT_TC,ENABLE);
  55.                 DMA_Cmd(DMA1_Stream4,DISABLE);
  56.         }
  57. }
  58. void UART4_IRQHandler(void)
  59. {
  60.         if (USART_GetITStatus(UART4, USART_IT_IDLE) != RESET)
  61.         {
  62.     (void)UART4->SR;
  63.                 (void)UART4->DR;
  64.   }
  65. }
  66. /* UART4 send interrupt for PC */
  67. void DMA1_Stream4_IRQHandler(void)
  68. {
  69.         if(DMA_GetFlagStatus(DMA1_Stream4, DMA_IT_TCIF4) == SET)
  70.         {
  71.                 DMA_Cmd(DMA1_Stream4, DISABLE);
  72.                 DMA_SetCurrDataCounter(DMA1_Stream4, 6);
  73.                 DMA_ClearFlag(DMA1_Stream4, DMA_FLAG_TCIF4);
  74.                 DMA_ClearITPendingBit(DMA1_Stream4, DMA_IT_TCIF4);
  75.         }
  76. }
  77. void SendData(void)
  78. {
  79.         SendToPC_Buff[0]=0x01;
  80.   SendToPC_Buff[1]=0x02;
  81.   SendToPC_Buff[2]=0x03;
  82.         SendToPC_Buff[3]=0x04;
  83.         SendToPC_Buff[4]=0x05;
  84.         SendToPC_Buff[5]=0x06;
  85.         DMA_Cmd(DMA1_Stream4, ENABLE);
  86. }
  87. int main()
  88. {
  89.
  90.         vUart4Config();
  91.
  92.         while(1)
  93.         {
  94.                 i++;
  95.           SendData();
  96.         }
  97.
  98.
  99. }
以上資料51hei提供下載:
User.7z (1.21 KB, 下載次數: 27)
