/********************51單片機(jī)第五課*******************/
/********************數(shù)碼管計(jì)數(shù)器*******************/
/******************** 運(yùn)用中斷控制 *******************/
/********************By Max.Zhang *******************/
#include <reg52.h>
typedef unsigned char uint8; //定義參數(shù)類型,規(guī)范書寫格式
typedef unsigned int uint16;
typedef unsigned long uint32;
uint16 i;
uint8 cnt;
uint8 num;
uint32 a;
uint8 n;
/******** 38譯碼器引腳對(duì)應(yīng)P1位置*********/
sbit ADDR0 =P1^0;
sbit ADDR1 =P1^1;
sbit ADDR2 =P1^2;
sbit ADDR3 =P1^3;
sbit ENLED =P1^4;
/******** 數(shù)碼管真值表 *********/
uint8 code DS[16]={ //code 表示把數(shù)據(jù)存到flash,不占用內(nèi)部存儲(chǔ)
0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
0x80, 0x90};
uint8 buff[6];
/************** 38譯碼器設(shè)置*************/
ADDR3 =1;
ENLED =0;
/************** 中斷初始化 *************/
TMOD = 01;
TH0 =0xFC; //計(jì)算1ms的計(jì)數(shù)初值
TL0 =0x66;
TR0 =1;
EA =1;
ET0 =1;
while(1);
void timer0_interrupt() interrupt 1
static i=0;
static a=0;
static cnt=0;
TL0 =0x66;
TF0 =0;
cnt++;
if(cnt>=1000) //計(jì)數(shù)1000次,延時(shí)1s
cnt=0;
a++;
buff[0]=a%10;
buff[1]=a/10%10;
buff[2]=a/100%10;
buff[3]=a/1000%10;
buff[4]=a/10000%10;
buff[5]=a/100000%10;
P0=0xFF;
switch(i) //放到中斷里面 1ms刷新一次數(shù)碼管段選
case 0:ADDR2=0;ADDR1=0;ADDR0=0;i++;P0=DS[buff[0]];break;
case 1:ADDR2=0;ADDR1=0;ADDR0=1;i++;P0=DS[buff[1]];break;
case 2:ADDR2=0;ADDR1=1;ADDR0=0;i++;P0=DS[buff[2]];break;
case 3:ADDR2=0;ADDR1=1;ADDR0=1;i++;P0=DS[buff[3]];break;
case 4:ADDR2=1;ADDR1=0;ADDR0=0;i++;P0=DS[buff[4]];break;
case 5:ADDR2=1;ADDR1=0;ADDR0=1;i=0;P0=DS[buff[5]];break;
default:break;
