查看: 4201|回復: 0
STM32用RTS引腳來自動驅動RS485的接收
ID:373388 發表于 2021-2-5 20:27 | 顯示全部樓層 |閱讀模式
STM32F有一些型號,可以直接驅動RS485的;在網上搜索了好多,沒有現成的實例;好多提問,最佳答案是否定的,不能自動切換,需要用普通IO做RE 和 DE的驅動。本人使用GD32F330 實驗,用RTS引腳實現自動切換;初始化代碼分享出來供參考。這顆MCU和STM32F030和051系列管腳兼容,寄存器兼容。
* File:   USART.h
* Author: hai
* Created on November 22, 2020, 11:35 PM
#ifndef USART_H
#define        USART_H
#include "gd32f3x0.h"
/* definition for COM 1, connected to USART0 */
#define INVERTERCOM       USART1
#define INVERTERCOM_CLK   RCU_USART1
#define INVERTERCOM_TX_PIN  GPIO_PIN_2
#define INVERTERCOM_RX_PIN  GPIO_PIN_3
#define INVERTERCOM_RTS_PIN GPIO_PIN_1
#define INVERTERCOM_GPIO_PORT        GPIOA
#define INVERTERCOM_GPIO_CLK        RCU_GPIOA
#define INVERTERCOM_AF                        GPIO_AF_1
#define INVERTERCOM_BPS                38400U
#ifdef        __cplusplus
extern "C" {
#endif
void com_init(uint32_t COM);
#ifdef        __cplusplus
#endif
#endif        /* USART_H */
#include "usart.h"
#include <stdio.h>
                /* enable GPIO clock */
    rcu_periph_clock_enable(INVERTERCOM_GPIO_CLK);
    /* enable USART clock */
    rcu_periph_clock_enable(INVERTERCOM_CLK);
    /* connect port to USARTx_Tx_RTS */
    gpio_af_set(INVERTERCOM_GPIO_PORT, INVERTERCOM_AF, INVERTERCOM_RTS_PIN|INVERTERCOM_TX_PIN|INVERTERCOM_RX_PIN);
                /* configure USART Tx as alternate function push-pull */
                gpio_mode_set(INVERTERCOM_GPIO_PORT,GPIO_MODE_AF,GPIO_PUPD_PULLUP,INVERTERCOM_RTS_PIN);
                gpio_output_options_set(INVERTERCOM_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ,INVERTERCOM_RTS_PIN);
    gpio_mode_set(INVERTERCOM_GPIO_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP,INVERTERCOM_TX_PIN);
    gpio_output_options_set(INVERTERCOM_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ,INVERTERCOM_TX_PIN);
    /* configure USART Rx as alternate function push-pull */
    gpio_mode_set(INVERTERCOM_GPIO_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP,INVERTERCOM_RX_PIN);
    gpio_output_options_set(INVERTERCOM_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ,INVERTERCOM_RX_PIN);
    /* USART configure */
    usart_deinit(COM);
    usart_baudrate_set(COM,INVERTERCOM_BPS);
                usart_rs485_driver_enable(COM);   //驅動使能
                usart_driver_deassertime_config(COM,0x1F);  // DE (驅動使能)信號的置位與第一個字節的起始位之間的時間間隔0-0x1F
                usart_driver_assertime_config(COM,0x1F);    //定義一個發送信息最后一個字節的停止位與置低 DE(驅動使能)信號之間的時間間隔
                usart_depolarity_config(COM,USART_DEP_LOW); //DE極性,根據硬件選擇,這里硬件用三極管反向了
    usart_transmit_config(COM, USART_TRANSMIT_ENABLE);
    usart_receive_config(COM, USART_RECEIVE_ENABLE);
    usart_enable(COM);
