用數碼管做了數字鐘,運行沒有什么問題,但是加了流水燈之后,數碼管會閃爍,這是怎么回事?應該怎么解決?求大佬指教!
代碼如下:#include<regx51.h>
sbit s1 = P3^2;//鬧鐘開關
sbit s2 = P3^3;//設置
sbit s3 = P3^4;//小時鍵
sbit s4 = P3^5;//分
sbit s5 = P3^6;//退出鍵
sbit fs = P3^0;//蜂鳴器
sbit d = P3^1;//小燈
unsigned char m,f,s,w;//秒,分,時,計數器
uchar f_nao,s_nao;//鬧鐘分,時
bit flag_nao;//鬧鐘標志
void zuo();
void you();
void delay(uint i);
//void ledscan(uchar h,uchar m,uchar s);
void alarm();
void tiaojie();
void delay(uint i)
while(i--);
void zuo()
{unsigned char d;
unsigned char a = 0x01;
for(d = 0;d<8;d++)
P0 = ~a;
delay(1);
a = a<<1;
if(a == 0)
a = 0x01;
void ledscan(uchar h,uchar m,uchar s) reentrant
uchar LED[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uint j;
P1 = LED[s%10];
P2 = 0x7f;
for(j = 0;j<100;j++);
P2 = 0xff;
P1 = LED[s/10];
P2 = 0xbf;
P2 = 0xff;
P1 = 0x40;
P2 = 0Xdf;
P2 = 0xff;
P1 = LED[m%10];
P2 = 0xef;
P2 = 0xff;
P1 = LED[m/10];
P2 = 0xf7;
P2 = 0xff;
P1 = 0x40;
P2 = 0xfb;
P2 = 0xff;
P1 = LED[h%10];
P2 = 0xfd;
P2 = 0xff;
P1 = LED[h/10];
P2 = 0xfe;
P2 = 0xff;
void tiaojie()
if(s3 == 0)
ledscan(s,f,m);
if(s3 == 0)
if(s == 23)
s = 0;
s++;
while(!s3)ledscan(s,f,m);
else if(s4 == 0)
ledscan(s,f,m);
if(s4 == 0)
if(f == 59)
f = 0;
f++;
while(!s4)ledscan(s,f,m);
}void alarm()
//uchar a;
if(flag_nao)
if(f==f_nao&&s==s_nao)
while(m<=5&&flag_nao)
fs = ~fs;
ledscan(s,f,m);}
void t0() interrupt 1
TH0 = (65536-50000)/256;
TL0 = (65536-50000)%256;
w++;
if(w == 20)
w = 0;
m++;
if(m == 60)
f++;
m = 0;
if(f == 60)
{s++;
f = 0;
if(s == 24)
s = 0;}
}zuo();
void guan_naozhong() interrupt 0
flag_nao = ~flag_nao;
d = ~d;
while(!s1)ledscan(s,f,m);
void naozhong()interrupt 2
f_nao = f;
s_nao = s;
while(s5)
ledscan(s_nao,f_nao,0);
if(s3 == 0)
if(s3 == 0)
if(s_nao == 24)s_nao =0;
else s_nao++;
while(!s3) ledscan(s_nao,f_nao,0);
else if(s4 == 0)
if(s4 == 0)
if(f_nao == 59)f_nao =0;
else f_nao++;
while(!s4)
TMOD = 0X01;
TH0 =(65536 - 50000)/256;
TL0 =(65536 - 50000)%256;
TR0 = 1;
ET0 = 1;
IT1 = 1;
IT0 = 0;
EX1 = 1;
EX0 = 1;
PT0 = 1;
EA = 1;
f = 0;
m = 0;
fs = 0;
flag_nao = 0;
ledscan(s,f,m);
tiaojie();
alarm();
//zuo();
