查看: 4268|回復: 4
請問單片機大佬們,keil5的debug中如何顯示數組中的值?
ID:609281 發表于 2021-2-1 21:26 | 顯示全部樓層 |閱讀模式
       以下是小弟C51單片機顯示交通燈的代碼,個人覺得邏輯上沒問題,編譯也沒錯誤沒警告,但是程序跑起來是徹底亂套,于是想通過debug觀察其中每一個變量的值,特別是 uchar xianshi[8]  這一個數組中的值,于是我在主函數的第一條語句設置了斷點以后,設置了watch1,但是始終沒有顯示uchar xianshi[8] 中的內容,而是
  D:0x0B xianshi[] "" 是什么意思?
以下是小弟我的單片機交通燈代碼:
# include "reg52.h"
typedef unsigned int uint;
typedef unsigned char uchar;
sbit traffic = P1;
sbit duanxuan = P0;
sbit LSA = P2^2;
sbit LSB = P2^3;
sbit LSC = P2^4;
sbit bao_ren_hong = P1^0;
sbit bao_ren_lv = P1^1;
sbit bao_ma_hong = P1^2;
sbit bao_ma_huang = P1^3;
sbit bao_ma_lv = P1^4;
sbit qian_ma_hong = P1^5;
sbit qian_ma_huang = P1^6;
sbit qian_ma_lv = P1^7;
sbit qian_ren_hong = P3^0;
sbit qian_ren_lv = P3^1;
uchar num = 0;
code uchar smgdx[16] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};  //共陰
uchar xianshi[8] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
void delay(uint i)
          while(i--);
void Timer0() interrupt 1
          static uint a;
    TH0 = 0xfc;
          TL0 = 0x18;
          a++;
          if(a==1000)        //定時一秒
                    num++;
                          a = 0;
void display()
    uchar j;
          for(j=0;j<8;j++)
              switch(j)
                                          //case 0: LSA=0,LSB=0,LSC=0;break;
                              //case 1: LSA=1,LSB=0,LSC=0;break;
                              case 2: LSA=0,LSB=1,LSC=0;break;
                              case 3: LSA=1,LSB=1,LSC=0;break;
                              //case 4: LSA=0,LSB=0,LSC=1;break;
                              //case 5: LSA=1,LSB=0,LSC=1;break;
                              case 6: LSA=0,LSB=1,LSC=1;break;
                              case 7: LSA=1,LSB=1,LSC=1;break;
                                if(num<31)
                                    xianshi[0] = 0x00;
                                          xianshi[1] = 0x00;
                                          xianshi[2] = smgdx[(30-num)/10];
                                          xianshi[3] = smgdx[(30-num)%10];
                                          xianshi[4] = 0x00;
                                          xianshi[5] = 0x00;
                                          xianshi[6] = smgdx[(30-num)/10];
                                          xianshi[7] = smgdx[(30-num)%10];
                                          duanxuan = xianshi[j];
                                    delay(50);
                                    duanxuan = 0x00;
                                if((31<=num)&&(num<36))
                                    xianshi[0] = 0x00;
                                          xianshi[1] = 0x00;
                                          xianshi[2] = smgdx[(35-num)/10];
                                          xianshi[3] = smgdx[(35-num)%10];
                                          xianshi[4] = 0x00;
                                          xianshi[5] = 0x00;
                                          xianshi[6] = smgdx[(35-num)/10];
                                          xianshi[7] = smgdx[(35-num)%10];
                                    delay(50);
                                    duanxuan = 0x00;
         if((36<=num)&&(num<66))
                                    xianshi[0] = 0x00;
                                          xianshi[1] = 0x00;
                                          xianshi[2] = smgdx[(66-num)/10];
                                          xianshi[3] = smgdx[(66-num)%10];
                                          xianshi[4] = 0x00;
                                          xianshi[5] = 0x00;
                                          xianshi[6] = smgdx[(66-num)/10];
                                          xianshi[7] = smgdx[(66-num)%10];
                                    delay(50);
                                    duanxuan = 0x00;
                                 if((num<=66)&&(num<71))
                                    xianshi[0] = 0x00;
                                          xianshi[1] = 0x00;
                                          xianshi[2] = smgdx[(71-num)/10];
                                          xianshi[3] = smgdx[(71-num)%10];
                                          xianshi[4] = 0x00;
                                          xianshi[5] = 0x00;
                                          xianshi[6] = smgdx[(71-num)/10];
                                          xianshi[7] = smgdx[(71-num)%10];
                                    delay(50);
                                    duanxuan = 0x00;
void Timer0_open()
    TMOD = 0x01;
          EA = 1;
          ET0 = 1;
          TR0 = 1;
          TH0 = 0xfc;      //定時1ms
          TL0 = 0x18;
    Timer0_open();
              if(num<31)
            traffic = 0xff;              //先讓全部交通燈熄滅
                                          bao_ren_hong = 0;
            bao_ma_hong = 0;
            qian_ma_lv = 0;
            qian_ren_lv = 0;
                                          display();
                                          bao_ren_hong = 0;
            bao_ma_hong = 0;
            qian_ma_huang = 0;
            qian_ren_lv = 0;
                                          display();
            bao_ren_lv = 0;
            bao_ma_lv = 0;
            qian_ma_hong = 0;
            qian_ren_hong = 0;
                                          display();
            bao_ren_lv = 0;
            bao_ma_huang = 0;
            qian_ma_hong = 0;
            qian_ren_hong = 0;
                                          display();
                                if(num==70)
                                          num = 0;
小弟我就想問一下keil 5 的debug中如何顯示一個數組的值,是需要手動輸入數組的初值嗎?  watch 1中顯示的D:0x0B xianshi[] ""  是什么意思呢?謝謝各位大佬!
ID:235200 發表于 2021-2-2 09:22 | 顯示全部樓層
D:0x0B xianshi[] "" 是什么意思?這個意思是數組分配的地址在內存0x0B開始的存儲單元,要看到數據,只需要通過菜單打開:VIEW→MEMORY WINDOWS→MEMORY1, 然后在彈昢的窗口中輸入d:0x0B 就可以看到連續8個存儲單元的值是該數組的值
ID:196216 發表于 2021-2-2 16:16 | 顯示全部樓層
左側小加號可以展開的啊
ID:609281 發表于 2021-2-2 23:51 | 顯示全部樓層
csmyldl 發表于 2021-2-2 09:22
D:0x0B xianshi[] "" 是什么意思?這個意思是數組分配的地址在內存0x0B開始的存儲單元,要看到數據,只需要 ...
感謝您的解答!可我按照您的操作,view→memory windows→memory 1操作以后,出現這個界面:C:\Users\11587\Desktop ,我點擊單步執行,xianshi[] 的寄存器中值一直都沒有變?
ID:882291 發表于 2021-2-3 09:10 | 顯示全部樓層
把“+”號點開就行了
