查看: 2854|回復: 0
單片機計分器Proteus仿真程序 兩個按鍵,每按下一次對應的計分器加1
兩個按鍵,每按下一次對應的計分器加1
#include<reg51.h>
#define dat P0
code uchar d[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uint second=0,minter=0,hour=0;
uint mge,mshi,hshi,hge;
static char court=0;
            sbit q1=P2^0;
                        sbit q2=P2^1;
                        sbit q3=P2^2;
                        sbit q4=P2^3;
                        sbit q5=P2^4;
                        sbit q6=P2^5;
                        sbit q7=P2^6;
                        sbit q8=P2^7;
                        sbit key1=P3^2;
                        sbit key2=P3^3;
void delay(uint number)
     uchar i,j;
         for(i=0;i<number;i++)
           for(j=0;j<200;j++);
void int11() interrupt 1 using 2
TH0=0x5c;
TL0=0xb0;
//court++;
void int0() interrupt 0 using 1          minter++;
  if(minter==99)
    minter=0;
void int1() interrupt 2 using 1
hour++;
if(hour==99)
hour=0;
TMOD=0X01;
TH0=0x5c;
TL0=0xb0;
ET0=1;
EX0=1;
EX1=1;
IT0=1;
IT1=1;
EA=1;
TR0=1;
mshi=minter/10;
mge=minter%10;
hshi=hour/10;
hge=hour%10;
dat=d[mge];
q8=1;
delay(2);
q8=0;
dat=d[mshi];
q7=1;
delay(2);
q7=0;
dat=0xbf;
q6=1;
delay(2);
q6=0;
dat=0xbf;
q5=1;
delay(2);
q5=0;
dat=0xbf;
q4=1;
delay(2);
q4=0;
dat=0xbf;
q3=1;
delay(2);
q3=0;
dat=d[hge];
q2=1;
delay(2);
q2=0;
dat=d[hshi];
q1=1;
delay(2);
q1=0;
if(court==20)
   {court=0;
        minter++;
        if(minter==99)
            {minter=0;
                hour++;
                if(hour==99)
                hour=0;
全部資料51hei下載地址:
計分器3.rar (61.05 KB, 下載次數: 9)
