同時(shí)啟用定時(shí)器0和1 定時(shí)1用于串口中斷 ,定時(shí)0用于定時(shí)1MS中斷 求助前輩們指導(dǎo)指導(dǎo)一下 是怎么回事呢?把我給搞蒙了
單片機(jī)源程序如下:
void ConfigSUART(unsigned int baud)
ACC = P_SW1;
ACC &= ~(S1_S0 | S1_S1); //S1_S0=0 S1_S1=0
//ACC |= S1_S1; //(P1.6/RxD_3, P1.7/TxD_3)
//ACC |= S1_S0; //(P3.6/RxD_2, P3.7/TxD_2)
P_SW1 = ACC; //(P3.0/RxD, P3.1/TxD)
SCON = 0x50; //8位可變波特率
AUXR |= 0x40; //定時(shí)器1為1T模式
AUXR &= 0xFE;
TMOD &= 0x80; //定時(shí)器1為模式0(16位自動(dòng)重載)
TL1 = (65536 - (FOSC/4/BAUD)); //設(shè)置波特率重裝值
TH1 = (65536 - (FOSC/4/BAUD))>>8;
TR1 = 1; //定時(shí)器1開(kāi)始啟動(dòng)
ET1=1;
TI = 1; //在串口使用printf的時(shí)候,需要將T1=1;
ES = 1; //使能串口中斷
printf("\n 串口初始化\n");
/* 配置并啟動(dòng)T0,ms-T0定時(shí)時(shí)間 */
void ConfigTimer0(unsigned int ms)
unsigned long tmp; //臨時(shí)變量
tmp = 11059200 / 12; //定時(shí)器計(jì)數(shù)頻率
tmp = (tmp * ms) / 1000; //計(jì)算所需的計(jì)數(shù)值
tmp = 65536 - tmp; //計(jì)算定時(shí)器重載值
tmp = tmp + 33; //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
//AUXR |= 0x80; //定時(shí)器0為1T模式
AUXR &= 0xFE; //定時(shí)器0為12T模式
TMOD &= 0xF8; //設(shè)置定時(shí)器為模式0(16位自動(dòng)重裝載)
TH0 = (unsigned char)(tmp>>8); //定時(shí)器重載值拆分為高低字節(jié)
TL0 = (unsigned char)tmp;
ET0 = 1; //使能T0中斷
TR0 = 1; //啟動(dòng)T0
P0M1 = 0; P0M0 = 0; //設(shè)置為準(zhǔn)雙向口
P1M1 = 0; P1M0 = 0; //設(shè)置為準(zhǔn)雙向口
P2M1 = 0; P2M0 = 0; //設(shè)置為準(zhǔn)雙向口
P3M1 = 0; P3M0 = 0; //設(shè)置為準(zhǔn)雙向口
P4M1 = 0; P4M0 = 0; //設(shè)置為準(zhǔn)雙向口
P5M1 = 0; P5M0 = 0; //設(shè)置為準(zhǔn)雙向口
P6M1 = 0; P6M0 = 0; //設(shè)置為準(zhǔn)雙向口
P7M1 = 0; P7M0 = 0; //設(shè)置為準(zhǔn)雙向口
//上面這些是必要的,除非用到PWM
ConfigSUART(115200);
ConfigTimer0(1); //配置T0定時(shí)1ms
EA = 1; //開(kāi)總中斷
while (1)
