查看: 1551|回復: 0
15單片機的NRF24L01通信
ID:880501 發表于 2021-1-28 20:44 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/*  發送程序 */
unsigned char num_1 = 0,num_2 = 0;
unsigned char TxDate[5];
void NRF24L01 ()
        if (Vary == 1)
                num_1 = 1;
                num_2 = 0;
                num_1 = 0;
                num_2 = 1;
        TxDate[0] = num_1;
        TxDate[1] = num_2;
        TxDate[2] = 0;
        TxDate[3] = 0;
        TxDate[4]=112;
        if (num_1 == 1)
                LED_red = 1;
                NRFSetTxMode(TxDate);//發送數據
                while(CheckACK());
                if (a==1)
                        LED_green = 0;
        if (num_2 == 1)
                LED_red = 0;
void main ()
        Timer0Init ();
        NRF24L01Int();
        while (1)
                NRF24L01 ();
/* 接收程序 */
void main ()
        NRF24L01Int();
        Delay_1 (600);
        for (ii=0;ii<100;ii++)
                NRFSetRXMode();//設置為接收模式
                GetDate();//開始接受數據
                M_0 = RevTempDate[0];
                M_1 = RevTempDate[1];
                M_2 = RevTempDate[2];
                M_3 = RevTempDate[3];
        while (1)
                GetDate();//開始接受數
                M_4 = RevTempDate[4];
                Mode_1 = RevTempDate[0];
                Mode_2 = RevTempDate[1];
                if (Mode_1 == 1)
                        LED_yellow = 1;
                if (Mode_2 == 1)
                        LED_yellow = 0;
收藏收藏 分享淘帖 頂 踩1
