查看: 4340|回復: 4
有錯誤 51單片機按摩器 步進電機定時+加減速+正反轉+LCD顯示轉速Proteus仿真程序
#include "reg52.h"
#include<lcd1602.h>
#include "delay.h"
#include "motor4B.h"
sbit K7 = P3^1;//定時
sbit K1 = P3^2;//加速
sbit K2 = P3^3;//減速
sbit K3 = P3^4;//正傳
sbit K4 = P3^5;//反轉
sbit K5 = P3^6;//啟動
sbit K6 = P3^7;//停止
void DelayMS(uint ms)
         uchar i;
        while(ms--)
                 for(i=0;i<120;i++);
void SETP_MOTOR_FFW(uchar n)
         uchar i,j;
        for(i=0;i<5*n;i++)
                 for(j=0;j<8;j++)
                         if(K2 == K3 == 0)        break;
                        DelayMS(25);
void main( )
        uchar N = 3;
        bit         fangxiang         =                 1;//0是逆時針
        bit         kaiqi                         =                 0;//0是停止
        int          sudu                                =                4;//每次步進間隔時間為 1ms * sudu,也就是最快每秒25轉
        char str_buff[] = { "00.00" };
        int speed = 0;
        init_lcd();
        lcd( 0, 0, "LCD_INIT" );
        delay( 100 );
        lcd( 0, 0, "        " );
        Init_Motor();
        Set_Motor(kaiqi, fangxiang, sudu);
        lcd( 1, 0, "    reversal    " );
        lcd( 0, 0, "Speed: " );
        lcd( 0, 12, "r/s" );
        speed = 1000 / ( 1.0 * 8.0 * sudu ) * 1000;
        str_buff[0] = speed / 10000 % 10 + '0';
        str_buff[1] = speed / 1000 % 10 + '0';
        str_buff[3] = speed / 100 % 10 + '0';
        str_buff[4] = speed % 10 + '0';
        lcd( 0, 6, str_buff );
                //////////////////////////////////////////////////////////////////////加速
                if( K1 == 0 )
                        delay( 50 );
                        if( K1 == 0 )
                                sudu--;
                                if( sudu <= 3 )
                                        sudu = 4;
//                                while( K1 == 0 );
                //////////////////////////////////////////////////////////////////////減速
                if( K2 == 0 )
                        delay( 50 );
                        if( K2 == 0 )
                                sudu++;
                                if( sudu >= 60000 )
                                        sudu = 60000;
                //////////////////////////////////////////////////////////////////////正
                if( K3 == 0 )
                        delay( 50 );
                        if( K3 == 0 )
                                fangxiang = 1;
                                lcd( 1, 0, "Forward rotation" );
                                while( K3 == 0 );
                //////////////////////////////////////////////////////////////////////反
                if( K4 == 0 )
                        delay( 50 );
                        if( K4 == 0 )
                                fangxiang = 0;
                                while( K4 == 0 );
                //////////////////////////////////////////////////////////////////////啟
                if( K5 == 0 )
                        delay( 50 );
                        if( K5 == 0 )
                                kaiqi = 1;
                                while( K6 == 0 );
                //////////////////////////////////////////////////////////////////////停
                if( K6 == 0 )
                        delay( 50 );
                        if( K6 == 0 )
                                kaiqi = 0;
                                while( K6 == 0 );
                ///////////////////////////////////////////////////////////////////////定時
          if( K7 == 0 )
                        SETP_MOTOR_FFW(N);
                        if( K6 == 0) break;
不能運行求指導:
基于單片機的微小型按摩器系統設計.zip (122.49 KB, 下載次數: 210)
收藏收藏2 分享淘帖 頂 踩
ID:89286 發表于 2021-1-22 09:48 | 只看該作者
thanks for sharing
ID:578423 發表于 2021-1-22 13:09 | 只看該作者
KEIL軟件打開當S了,什么原因?
ID:578423 發表于 2021-1-22 13:54 | 只看該作者
重新換個版本可以了
ID:1068569 發表于 2023-3-27 16:09 | 只看該作者
為什么,下載的源程序和你發的這個界面的源程序不一樣,而且用不了
