查看: 2524|回復: 5
stc89c52單片機的EEPROM問題
看STC89C52的手冊關于EEPROM部分,不清楚P1是什么作用?手冊中和測試程序中的說明部分并沒有提到和ISP寄存器有什么關聯,下面是部分程序,
ID:213173 發表于 2021-1-19 17:31 | 只看該作者
P1在這個示例中是用來接LED可以直觀了解EEPROM的讀寫成功或失敗。給你一個示例比較好理解些。讀寫時間有點長。
  1. #include <reg52.h>      //52系列單片機頭文件
  2. #include <intrins.h>
  3. #include <stdlib.h>        //包含產生隨機數用到的rand()函數。
  5. #define uint unsigned int
  6. //定義ISP的操作命令
  7. #define RdCommand 0x01                //讀命令
  8. #define PrgCommand 0x02                //寫命令
  9. #define EraseCommand 0x03        //擦除命令
  10. #define WaitTime 0x01                 //定義CPU的等待時間,寫入硬件延時
  11. /*STC89系列EEPROM寄存器聲明*/
  12. sfr ISP_DATA=0xe2;                //0000,0000 EEPROM數據寄存器
  13. sfr ISP_ADDRH=0xe3;                //0000,0000 EEPROM地址高字節
  14. sfr ISP_ADDRL=0xe4;                //0000,0000 EEPROM地址第字節
  15. sfr ISP_CMD=0xe5;                //xxxx,xx00 EEPROM命令寄存器
  16. sfr ISP_TRIG=0xe6;                //0000,0000 EEPRPM命令觸發寄存器
  17. sfr ISP_CONTR=0xe7;                //0000,x000 EEPROM控制寄存器
  18. sbit LED1=P1^0;
  19. sbit LED2=P1^7;
  20. /* 測試常量數組 */
  21. uchar code table[512] =
  22. {
  23.     0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f,
  24.     0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x1a,0x1b,0x1c,0x1d,0x1e,0x1f,
  25.     0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x2a,0x2b,0x2c,0x2d,0x2e,0x2f,
  26.     0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3a,0x3b,0x3c,0x3d,0x3e,0x3f,
  27.     0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4a,0x4b,0x4c,0x4d,0x4e,0x4f,
  28.     0x50,0x51,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x5a,0x5b,0x5c,0x5d,0x5e,0x5f,
  29.     0x60,0x61,0x62,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6a,0x6b,0x6c,0x6d,0x6e,0x6f,
  30.     0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x7b,0x7c,0x7d,0x7e,0x7f,
  31.     0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f,
  32.     0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f,
  33.     0xa0,0xa1,0xa2,0xa3,0xa4,0xa5,0xa6,0xa7,0xa8,0xa9,0xaa,0xab,0xac,0xad,0xae,0xaf,
  34.     0xb0,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xbb,0xbc,0xbd,0xbe,0xbf,
  35.     0xc0,0xc1,0xc2,0xc3,0xc4,0xc5,0xc6,0xc7,0xc8,0xc9,0xca,0xcb,0xcc,0xcd,0xce,0xcf,
  36.     0xd0,0xd1,0xd2,0xd3,0xd4,0xd5,0xd6,0xd7,0xd8,0xd9,0xda,0xdb,0xdc,0xdd,0xde,0xdf,
  37.     0xe0,0xe1,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,0xe8,0xe9,0xea,0xeb,0xec,0xed,0xee,0xef,
  38.     0xf0,0xf1,0xf2,0xf3,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfe,0xff,
  39.     0xff,0xfe,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf3,0xf2,0xf1,0xf0,
  40.     0xef,0xee,0xed,0xec,0xeb,0xea,0xe9,0xe8,0xe7,0xe6,0xe5,0xe4,0xe3,0xe2,0xe1,0xe0,
  41.     0xdf,0xde,0xdd,0xdc,0xdb,0xda,0xd9,0xd8,0xd7,0xd6,0xd5,0xd4,0xd3,0xd2,0xd1,0xd0,
  42.     0xcf,0xce,0xcd,0xcc,0xcb,0xca,0xc9,0xc8,0xc7,0xc6,0xc5,0xc4,0xc3,0xc2,0xc1,0xc0,
  43.     0xbf,0xbe,0xbd,0xbc,0xbb,0xba,0xb9,0xb8,0xb7,0xb6,0xb5,0xb4,0xb3,0xb2,0xb1,0xb0,
  44.     0xaf,0xae,0xad,0xac,0xab,0xaa,0xa9,0xa8,0xa7,0xa6,0xa5,0xa4,0xa3,0xa2,0xa1,0xa0,
  45.     0x9f,0x9e,0x9d,0x9c,0x9b,0x9a,0x99,0x98,0x97,0x96,0x95,0x94,0x93,0x92,0x91,0x90,
  46.     0x8f,0x8e,0x8d,0x8c,0x8b,0x8a,0x89,0x88,0x87,0x86,0x85,0x84,0x83,0x82,0x81,0x80,
  47.     0x7f,0x7e,0x7d,0x7c,0x7b,0x7a,0x79,0x78,0x77,0x76,0x75,0x74,0x73,0x72,0x71,0x70,
  48.     0x6f,0x6e,0x6d,0x6c,0x6b,0x6a,0x69,0x68,0x67,0x66,0x65,0x64,0x63,0x62,0x61,0x60,
  49.     0x5f,0x5e,0x5d,0x5c,0x5b,0x5a,0x59,0x58,0x57,0x56,0x55,0x54,0x53,0x52,0x51,0x50,
  50.     0x4f,0x4e,0x4d,0x4c,0x4b,0x4a,0x49,0x48,0x47,0x46,0x45,0x44,0x43,0x42,0x41,0x40,
  51.     0x3f,0x3e,0x3d,0x3c,0x3b,0x3a,0x39,0x38,0x33,0x36,0x35,0x34,0x33,0x32,0x31,0x30,
  52.     0x2f,0x2e,0x2d,0x2c,0x2b,0x2a,0x29,0x28,0x27,0x26,0x25,0x24,0x23,0x22,0x21,0x20,
  53.     0x1f,0x1e,0x1d,0x1c,0x1b,0x1a,0x19,0x18,0x17,0x16,0x15,0x14,0x13,0x12,0x11,0x10,
  54.     0x0f,0x0e,0x0d,0x0c,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01,0x00
  55. };
  56. uint code table1[]={0x2000,0x2200,0x2400,0x2600,0x2800,0x2a00};//STC89C52RC EEPROM 扇區地址
  57. //uint code table1[]={0x4000,0x4200,0x4400,0x4600,0x4800,0x4a00};//STC89C54 EEPROM 扇區地址
  58. uint Random;//隨機數變量
  59. /* ================ 打開 ISP,IAP 功能 ================= */
  60. void ISP_IAP_enable(void)
  61. {
  62.         EA = 0;       /* 關中斷   */
  63.         ISP_CONTR = ISP_CONTR & 0x18;       /* 0001,1000 */
  64.         ISP_CONTR = ISP_CONTR | WaitTime; /* 寫入硬件延時 */
  65.         ISP_CONTR = ISP_CONTR | 0x80;       /* ISPEN=1  */
  66. }
  67. /* =============== 關閉 ISP,IAP 功能 ================== */
  68. void ISP_IAP_disable(void)
  69. {
  70.         ISP_CONTR = ISP_CONTR & 0x7f; /* ISPEN = 0 */
  71.         ISP_TRIG = 0x00;
  72.         EA   =   1;   /* 開中斷 */
  73. }
  74. /* ================ 公用的觸發代碼 ==================== */
  75. void ISPgoon(void)
  76. {
  77.         ISP_IAP_enable();   /* 打開 ISP,IAP 功能 */
  78.         ISP_TRIG = 0x46;  /* 觸發ISP_IAP命令字節1 */
  79.         ISP_TRIG = 0xb9;  /* 觸發ISP_IAP命令字節2 */
  80.         _nop_();
  81. }
  82. /* ==================== 字節讀 ======================== */
  83. uchar byte_read(uint byte_addr)
  84. {
  85.         ISP_ADDRH = (uchar)(byte_addr >> 8);/* 地址賦值 */
  86.         ISP_ADDRL = (uchar)(byte_addr & 0x00ff);
  87.         ISP_CMD   = ISP_CMD & 0xf8;   /* 清除低3位  */
  88.         ISP_CMD   = ISP_CMD | RdCommand; /* 寫入讀命令 */
  89.         ISPgoon();       /* 觸發執行  */
  90.         ISP_IAP_disable();    /* 關閉ISP,IAP功能 */
  91.         return (ISP_DATA);    /* 返回讀到的數據 */
  92. }
  93. /* ================== 扇區擦除 ======================== */
  94. void SectorErase(uint sector_addr)
  95. {
  96.         uint iSectorAddr;
  97.         iSectorAddr = (sector_addr & 0xfe00); /* 取扇區地址 */
  98.         ISP_ADDRH = (uchar)(iSectorAddr >> 8);
  99.         ISP_ADDRL = 0x00;
  100.         ISP_CMD = ISP_CMD & 0xf8;   /* 清空低3位  */
  101.         ISP_CMD = ISP_CMD | EraseCommand; /* 擦除命令3  */
  102.         ISPgoon();       /* 觸發執行  */
  103.         ISP_IAP_disable();    /* 關閉ISP,IAP功能 */
  104. }
  105. /* ==================== 字節寫 ======================== */
  106. void byte_write(uint byte_addr, uchar original_data)
  107. {
  108.         ISP_ADDRH = (uchar)(byte_addr >> 8);  /* 取地址  */
  109.         ISP_ADDRL = (uchar)(byte_addr & 0x00ff);
  110.         ISP_CMD  = ISP_CMD & 0xf8;    /* 清低3位 */
  111.         ISP_CMD  = ISP_CMD | PrgCommand;  /* 寫命令2 */
  112.         ISP_DATA = original_data;   /* 寫入數據準備 */
  113.         ISPgoon();       /* 觸發執行  */
  114.         ISP_IAP_disable();     /* 關閉IAP功能 */
  115. }
  116. void main()
  117. {
  118.         uchar i;
  119.         uint j,k;
  120.         LED2=0;//LED2亮
  121.         k=50000;
  122.         while(k--);//延時等待系統穩定
  123.         LED2=1;//LED2滅
  124.         for(i=0;i<6;i++)//循環寫6個扇區
  125.         {
  126.                 SectorErase(table1[i]);//擦除扇區
  127.                 for(j=0;j<512;j++)//循環寫512個字節
  128.                 {
  129.                         byte_write(table1[i]+j,table[j]);//寫入數據
  130.                         if(byte_read(table1[i]+j)!= table[j])//比較對錯
  131.                         {
  132.                                 LED1=0;//錯誤LED1亮
  133.                                 k=50000;
  134.                                 while(k--);//延時便于觀察
  135.                                 LED1=1;//LED1滅
  136.                         }
  137.                 }
  138.         }
  139.         Random=rand()/64;//生成0~511隨機數
  140.         if(byte_read(table1[Random%6]+Random)==table[Random])//隨機在6個扇區的隨機地址抽樣比對
  141.                 LED2=0;//正確LED2亮
  142.         else LED1=0;//錯誤LED1亮
  143.         while(1);
  144. }
ID:825883 發表于 2021-1-19 17:40 | 只看該作者
好像是用于指示操作是否完成的。為什么在STC-isp界面右側的EEPROM文件選項卡中,沒有數據呢?
ID:390416 發表于 2021-1-19 18:57 | 只看該作者
STC所指的EEPROM文件 跟我們自己寫的程序沒有絕對關系,它只是一個EEPROM文件
ID:825883 發表于 2021-1-21 08:28 | 只看該作者
wulin 發表于 2021-1-19 17:31
P1在這個示例中是用來接LED可以直觀了解EEPROM的讀寫成功或失敗。給你一個示例比較好理解些。讀寫時間有點 ...
謝謝你
ID:825883 發表于 2021-1-21 08:49 | 只看該作者
人人學會單片機 發表于 2021-1-19 18:57
