查看: 2929|回復(fù): 2
STM32f103 rc522 RFID識別與操作源碼
ID:547792 發(fā)表于 2021-1-18 12:35 | 顯示全部樓層 |閱讀模式
STM32單片機寫的ic卡程序可進行扣費操作,對金額進行修改,添加
  1. #include "delay.h"
  2. #include "sys.h"
  3. #include "usart.h"
  4. #include "dht11.h"
  5. #include "gpio.h"
  6. #include "rc522_new.h"
  7. #include "oled.h"
  8. #include "stmflash.h"
  9. #include "timer.h"
  10. #include "esp8266.h"
  11. #define P5 GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_1)
  12. #define P6 GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_2)
  13. #define P7 GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_3)
  14. #define P8 GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_4)
  15. #define P1(A)  if(A){GPIO_SetBits(GPIOB,GPIO_Pin_8);}\
  16.        else{GPIO_ResetBits(GPIOB,GPIO_Pin_8);}
  17. #define P2(A)  if(A){GPIO_SetBits(GPIOB,GPIO_Pin_9);}\
  18.        else{GPIO_ResetBits(GPIOB,GPIO_Pin_9);}
  19. #define P3(A)  if(A){GPIO_SetBits(GPIOC,GPIO_Pin_13);}\
  20.        else{GPIO_ResetBits(GPIOC,GPIO_Pin_13);}
  21. #define P4(A)  if(A){GPIO_SetBits(GPIOA,GPIO_Pin_0);}\
  22.        else{GPIO_ResetBits(GPIOA,GPIO_Pin_0);}
  23. #define renti         GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_5)
  24. #define yanwu GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_6)
  25. #define CharBuffer1 0x01
  26. #define CharBuffer2 0x02
  27. #define FLASH_SAVE_ADDR  0X08007000
  28. uchar CardRevBuf[16] = { 0 };
  29. volatile uchar key_num,bz,bz1,bz2,bz3;
  30. u8 people_flag=1,people_flag_suo=0;
  31. uint money;
  32. uint money_buf;
  33. uint money_tab[5];
  34. uchar mode;
  35. extern uchar tab[20];   //接受緩存
  36. extern uchar num;  //接收數(shù)據(jù)個數(shù)
  37. uint time;  //時間累加變量
  38. uint shop_num;
  39.         u8 temperature;
  40.         u8 humidity;
  41. void KEY_Scan(void)
  42. {
  43.                 P1(1);
  44.                 P2(1);
  45.                 P3(1);
  46.                 P4(1);
  47.
  48.         if((P5==0)&&(P6==0)&&(P7==0)&&(P8==0))
  49.         {
  50.                 bz=0;
  51.                 bz3=0;
  52.                 key_num=100;
  53.         }
  54.
  55.         if(((P5!=0)||(P6!=0)||(P7!=0)||(P8!=0))&&(bz==0))
  56.         {
  57.                 bz=1;
  58.                 P1(1);
  59.                 P2(0);
  60.                 P3(0);
  61.                 P4(0);
  62.
  63.                         if(P8==1)
  64.                         {
  65.                                         key_num=14;return;
  66.                         }
  67.                         else if(P7==1)
  68.                         {
  69.                                         key_num=1;return;
  70.                         }
  71.                         else if(P6==1)
  72.                         {
  73.                                 key_num=4;return;
  74.                         }
  75.                         else if(P5==1)
  76.                         {
  77.                                 key_num=7;return;
  78.                         }
  79.
  80.
  81.                 P1(0);
  82.                 P2(1);
  83.                 P3(0);
  84.                 P4(0);
  85.                         if(P8==1)
  86.                                 {
  87.                                         key_num=0;return;
  88.                                 }
  89.                                 else if(P7==1)
  90.                                 {
  91.                                         key_num=2;return;
  92.                                 }
  93.                                 else if(P6==1)
  94.                                 {
  95.                                         key_num=5;return;
  96.                                 }
  97.                                 else if(P5==1)
  98.                                 {
  99.                                         key_num=8;return;
  100.                                 }
  101.
  102.                 P1(0);
  103.                 P2(0);
  104.                 P3(1);
  105.                 P4(0);
  106.                         if(P8==1)
  107.                         {
  108.                                 key_num=15;return;
  109.                         }
  110.                         else if(P7==1)
  111.                         {
  112.                                 key_num=3;return;
  113.                         }
  114.                         else if(P6==1)
  115.                         {
  116.                                 key_num=6;return;
  117.                         }
  118.                         else if(P5==1)
  119.                         {
  120.                                 key_num=9;return;
  121.                         }
  122.                 P1(0);
  123.                 P2(0);
  124.                 P3(0);
  125.                 P4(1);
  126.                         if(P8==1)
  127.                         {
  128.                                 key_num=16;return;
  129.                         }
  130.                         else if(P7==1)
  131.                         {
  132.                                 key_num=13;return;
  133.                         }
  134.                         else if(P6==1)
  135.                         {
  136.                                 key_num=12;return;
  137.                         }
  138.                         else if(P5==1)
  139.                         {
  140.                                 key_num=11;return;
  141.                         }
  142.                                 key_num=key_num;
  143.
  144.         }
  145. }
  146. void ctrl( void )
  147. {
  148.         if( PcdRequest( PICC_REQIDL, &CardRevBuf[0] ) != MI_OK )//??????????????,?????? 2??
  149.         {
  150.                 if( PcdRequest( PICC_REQIDL, &CardRevBuf[0] ) != MI_OK )//??????????????,?????? 2??
  151.                 {
  152.                         CardRevBuf[2]=0;
  153.                         CardRevBuf[3]=0;
  154.                         bz1=0;
  155.                         return;
  156.                 }
  157.         }
  158.         if( PcdAnticoll( &CardRevBuf[2] ) != MI_OK ) //???,??????? 4??
  159.         {
  160.                         CardRevBuf[2]=0;
  161.                         CardRevBuf[3]=0;
  162.                         bz1=0;
  163.                 return;
  164.         }
  165.         if( PcdSelect( &CardRevBuf[2] ) != MI_OK )//?? ?????,4??
  166.         {
  167.                         CardRevBuf[2]=0;
  168.                         CardRevBuf[3]=0;
  169.                         bz1=0;
  170.                 return;
  171.         }
  172. }
  173. void xianshi()
  174. {
  175.         if(mode==0)
  176.         {
  177.                 OLED_ShowString(0,2,"Crad:");
  178.
  179.                 OLED_ShowChar(40,2,CardRevBuf[2]/100%10+'0');
  180.                 OLED_ShowChar(40+8,2,CardRevBuf[2]/10%10+'0');
  181.                 OLED_ShowChar(40+8*2,2,CardRevBuf[2]/1%10+'0');
  182.
  183.                 OLED_ShowString(0,0,"temp:");
  184.                 OLED_ShowChar(40,0,temperature/10%10+'0');
  185.                 OLED_ShowChar(40+8,0,temperature/1%10+'0');
  186.
  187.                 OLED_ShowString(40+8*3,0,"humi:");
  188.                 OLED_ShowChar(40+8*8,0,humidity/10%10+'0');
  189.                 OLED_ShowChar(40+8*9,0,humidity/1%10+'0');
  190.
  191.                 OLED_ShowString(0,4,"money:");
  192.                 OLED_ShowChar(48,4,money/1000%10+'0');
  193.                 OLED_ShowChar(48+8,4,money/100%10+'0');
  194.                 OLED_ShowChar(48+8*2,4,money/10%10+'0');
  195.                 OLED_ShowChar(48+8*3,4,'.');
  196.                 OLED_ShowChar(48+8*4,4,money/1%10+'0');
  197.                 OLED_ShowString(48+8*5,4,"     ");
  198.
  199.                 OLED_ShowString(0,6,"shop:");
  200.                 OLED_ShowChar(48,6,shop_num/1000%10+'0');
  201.                 OLED_ShowChar(48+8,6,shop_num/100%10+'0');
  202.                 OLED_ShowChar(48+8*2,6,shop_num/10%10+'0');
  203.                 OLED_ShowChar(48+8*3,6,'.');
  204.                 OLED_ShowChar(48+8*4,6,shop_num/1%10+'0');
  205.
  206. #if 0
  207.                 OLED_ShowString(48,6,"shop:");
  208.                 OLED_ShowChar(48+40,6,shop_num/100%10+'0');
  209.                 OLED_ShowChar(48+40+8,6,shop_num/10%10+'0');
  210.                 OLED_ShowChar(48+40+8*2,6,'.');
  211.                 OLED_ShowChar(48+40+8*3,6,shop_num/1%10+'0');
  212.
  213.                 OLED_ShowString(0,6,"Peo:");
  214.                 if(renti==0){OLED_ShowChar(32,6,'N');}
  215.                 if((renti==1)&&(bz2==0)){bz2=1;OLED_ShowChar(32,6,'Y');mode=4;OLED_Clear();}
  216. #endif
  217.
  218.         }
  219.
  220.         if(mode==1)
  221. ……………………
  222. …………限于本文篇幅 余下代碼請從51黑下載附件…………
源碼.7z (230.07 KB, 下載次數(shù): 64)
ID:423533 發(fā)表于 2021-1-26 18:08 | 顯示全部樓層
謝謝樓主分享代碼,,感謝
ID:81138 發(fā)表于 2021-1-27 13:29 | 顯示全部樓層
能用在STM8s103F3上嗎
