查看: 2165|回復: 1
arduino溫濕度傳感器代碼問題
ID:855142 發表于 2021-1-16 17:19 | 顯示全部樓層 |閱讀模式
有沒有哪位大神幫我看看我這個代碼哪里有問題 dht11函數庫也導入了 代碼在下面:
#include<dht11.h>
dht11 DHT11;
#define DHT11PIN 2
double dewPiont(double celsius, double humidity)
  double A0 = 373.15 / (273.15 + celsius);
  double SUM = -7.90298 * (A0 - 1);
  SUM += 5.02808 * log10(A0);
  SUM += -1.3816e-7 * (pow(10, (11.344 * (1 - 1 / A0))) - 1);
  SUM += 8.1328e-3 * (pow(10, (-3.49149 * (A0 - 1))) - 1);
  SUM += log10(1013.246);
  double VP = pow(10, SUM - 3) * humidity;
  double T = log(VP / 0.61078);
  return (241.88 * T) / (17.558 - T);
double dewPointFast(double celsius, double humidity)
  double a = 17.271;
  double b = 237.7;
  double temp = (a * celsius) / (b + celsius) + log(humidity / 100);
  double Td = (b * temp) / (a - temp);
  return Td;
void loop()
  if (DHT11.temperature >= 40 || hc == 'w')
    for (int i = 0; i < 5; i++)
      digitalWrite(SC, HIGH);
      Serial.println("Warning For Temperature");
      delay(5000);
      digitalWrite(SC, LOW);
      delay(5000);
  if (DHT11.humidity <= 20 || hc == 'r')
      digitalWrite(RED, HIGH);
      Serial.println("Warning For Humidity");
      delay(3000);
      digitalWrite(RED, LOW);
      delay(3000);
ID:235954 發表于 2021-1-19 16:30 | 顯示全部樓層
管理庫文件里面可以添加DHT11的庫
