查看: 3339|回復: 0
基于STM32的IIC_OLED驅動源程序
ID:618513 發表于 2021-1-14 17:20 | 顯示全部樓層 |閱讀模式
話不多說  本人的項目中設計到了OLED顯示一些花里胡哨的東西  來和大家一起分享一下成果  (已經調試直接用)
  1. void WriteCmd(unsigned char I2C_Command)
  2. {
  3.         write_i2c(OLED_DEV_ADDR,0x00, I2C_Command);
  4. }
  5. void WriteDat(unsigned char I2C_Data)
  6. {
  7.         write_i2c(OLED_DEV_ADDR,0x40, I2C_Data);
  8. }
  9. void OLED_SetPos(unsigned char x, unsigned char y)
  10. {
  11.         WriteCmd(0xb0+y);
  12.         WriteCmd(((x&0xf0)>>4)|0x10);
  13.         WriteCmd((x&0x0f)|0x01);
  14. }
  15. void OLED_Fill(unsigned char fill_Data)
  16. {
  17.         unsigned char m,n;
  18.         for(m=0;m<8;m++)
  19.         {
  20.                 WriteCmd(0xb0+m);                //page0-page1
  21.                 WriteCmd(0x00);                //low column start address
  22.                 WriteCmd(0x10);                //high column start address
  23.                 for(n=0;n<128;n++)
  24.                         {
  25.                                 WriteDat(fill_Data);
  26.                         }
  27.         }
  28. }
  29. void OLED_CLS(void)
  30. {
  31.         OLED_Fill(0x00);
  32. }
  33. void OLED_ShowStr(unsigned char x, unsigned char y, unsigned char ch[], unsigned char TextSize)
  34. {
  35.         unsigned char c = 0,i = 0,j = 0;
  36.         switch(TextSize)
  37.         {
  38.                 case 1:
  39.                 {
  40.                         while(ch[j] != '\0')
  41.                         {
  42.                                 c = ch[j] - 32;
  43.                                 if(x > 126)
  44.                                 {
  45.                                         x = 0;
  46.                                         y++;
  47.                                 }
  48.                                 OLED_SetPos(x,y);
  49.                                 for(i=0;i<6;i++)
  50.                                         WriteDat(F6x8[c][i]);
  51.                                 x += 6;
  52.                                 j++;
  53.                         }
  54.                 }break;
  55.                 case 2:
  56.                 {
  57.                         while(ch[j] != '\0')
  58.                         {
  59.                                 c = ch[j] - 32;
  60.                                 if(x > 120)
  61.                                 {
  62.                                         x = 0;
  63.                                         y++;
  64.                                 }
  65.                                 OLED_SetPos(x,y);
  66.                                 for(i=0;i<8;i++)
  67.                                         WriteDat(F8X16[c*16+i]);
  68.                                 OLED_SetPos(x,y+1);
  69.                                 for(i=0;i<8;i++)
  70.                                         WriteDat(F8X16[c*16+i+8]);
  71.                                 x += 8;
  72.                                 j++;
  73.                         }
  74.                 }break;
  75.         }
  76. }
  77. void OLED_ShowCN(unsigned char x, unsigned char y, unsigned char N)
  78. {
  79.         unsigned char wm=0;
  80.         unsigned int  adder=32*N;
  81.         OLED_SetPos(x , y);
  82.         for(wm = 0;wm < 16;wm++)
  83.         {
  84.                 WriteDat(F16x16[adder]);
  85.                 adder += 1;
  86.         }
  87.         OLED_SetPos(x,y + 1);
  88.         for(wm = 0;wm < 16;wm++)
  89.         {
  90.                 WriteDat(F16x16[adder]);
  91.                 adder += 1;
  92.         }
  93. }
  94. void OLED_DrawBMP(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char BMP[])
  95. {
  96.         unsigned int j=0;
  97.         unsigned char x,y;
  98.   if(y1%8==0)
  99.                 y = y1/8;
  100.   else
  101.                 y = y1/8 + 1;
  102.         for(y=y0;y<y1;y++)
  103.         {
  104.                 OLED_SetPos(x0,y);
  105.     for(x=x0;x<x1;x++)
  106.                 {
  107.                         WriteDat(BMP[j++]);
  108.                 }
  109.         }
  110. }
  111. void OLED_ShowChar(u8 x, u8 y, u8 chr,u8 size)
  112. {
  113.     unsigned char c = 0, i = 0;
  114.     c = chr - ' '; //μÃμ½Æ«òÆoóμÄÖμ
  115.     if(x > 128 - 1)
  116.     {
  117.         x = 0;
  118.         y = y + 2;
  119.     }
  120.     if(size == 0)
  121.     {
  122.                         OLED_SetPos(x, y);
  123.                         for(i = 0; i < 8; i++)
  124.                                         WriteDat(F8X16[c * 16 + i]);
  125.                         OLED_SetPos(x, y + 1);
  126.                         for(i = 0; i < 8; i++)
  127.                                         WriteDat(F8X16[c * 16 + i + 8]);
  128.     }
  129.     else
  130.     {
  131.                         OLED_SetPos(x, y + 1);
  132.                         for(i = 0; i < 6; i++)
  133.                                         WriteDat(F6x8[c][i]);
  134.     }
  135. }
  136. void OLED_ShowNum(u8 x, u8 y, u32 num, u8 len, u8 size)
  137. {
  138.     u8 t,temp;
  139.     u8 enshow = 0;
  140.     for(t = 0; t < len; t++)
  141.     {
  142.         temp = ((num / oled_pow(10,len-t-1))%10);
  143.         if(enshow == 0 && t < (len - 1))
  144.         {
  145.             if(temp == 0)
  146.             {
  147.                 OLED_ShowChar(x + (size / 2)*t, y, ' ',size);
  148.                 continue;
  149.             }
  150.             else enshow = 1;
  151.         }
  152.         OLED_ShowChar(x + (size / 2)*t, y, temp + '0',size);
  153.     }
  154. }
這一個函數 :void OLED_DrawBMP(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char BMP[]); 是用來顯示圖片的
這就需要用到工具 請百度搜索下載“ 9. Image2Lcd 2.9” 和工具“ PCtoLCD2002完美版 ”
首先下載一張圖片打開將其轉化為BMP格式
打開Image2Lcd 工具導入圖片點擊保存。
打開PCtoLCD2002  配置如 416591c917aa85f27ccee2c4d04c35ae.png 然后導入BMP圖片得到字符串即可
全部資料51hei下載地址:
Hardwareddata.7z (1.55 MB, 下載次數: 35)
