我被這個(gè)問(wèn)題困擾好久了 以下是在液晶模塊的第二行第一個(gè)字符的位置顯示字母“A”的程序:
RS EQU P3.0
RW EQU P3.1
E EQU P3.5
ORG 0000H
MOV P1,#00000001B ;清屏
ACALL ENABLE
MOV P1,#00111000B ;8位2行5x7點(diǎn)陣
ACALL ENABLE
MOV P1,#00001111B ;顯示器開(kāi)、光標(biāo)開(kāi)、閃爍開(kāi)
ACALL ENABLE
MOV P1,#00000110B ;文字不動(dòng),光標(biāo)自動(dòng)右移
ACALL ENABLE
MOV P1,#0C0H ;寫(xiě)入顯示起始地址(第二行第一個(gè)位置)
ACALL ENABLE
MOV P1,#01000001B ;字母A的代碼
SETB RS ;RS=1
CLR RW ;RW=0
CLR E ;E=0
ACALL DELAY
SETB E ;E=1
AJMP $
ENABLE: CLR RS ;寫(xiě)入控制命令的子程序
CLR RW
CLR E
ACALL DELAY
SETB E
RET
DELAY: MOV P1,#0FFH ;判斷液晶顯示器是否忙的子程序
CLR RS
SETB RW
CLR E
NOP
SETB E
JB P1.7,DELAY ;如果P1.7為高電平表示忙就循環(huán)等待
RET
END
這個(gè)程序就不用延時(shí)
這個(gè)程序查詢bf忙碌標(biāo)志后為啥還要延時(shí)呢 RS BIT P2.4 R_W BIT P2.5 E BIT P2.6 DB0_DB7 EQU P0 ORG 0000H LJMP MAIN ORG 0030H MAIN: MOV SP,#70H MOV A,#00111000B PUSH ACC BUSY_LOOP: CLR E SETB R_W CLR RS SETB E MOV A, DB0_DB7 CLR E JB ACC.7,BUSY_LOOP POP ACC LCALL DEL CLR E CLR R_W CLR RS SETB E MOV DB0_DB7,A CLR E MOV A,#00001110B PUSH ACC BUSY_LOOP1: CLR E SETB R_W CLR RS SETB E MOV A, DB0_DB7 CLR E JB ACC.7,BUSY_LOOP1 POP ACC LCALL DEL CLR E CLR R_W CLR RS SETB E MOV DB0_DB7,A CLR E MOV A,#00000110B PUSH ACC BUSY_LOOP2: CLR E SETB R_W CLR RS SETB E MOV A, DB0_DB7 CLR E JB ACC.7,BUSY_LOOP2 POP ACC LCALL DEL CLR E CLR R_W CLR RS SETB E MOV DB0_DB7,A CLR E MOV A,#10000000B PUSH ACC BUSY_LOOP3: CLR E SETB R_W CLR RS SETB E MOV A, DB0_DB7 CLR E JB ACC.7,BUSY_LOOP3 POP ACC LCALL DEL CLR E CLR R_W CLR RS SETB E MOV DB0_DB7,A CLR E MOV A,#41H PUSH ACC BUSY_LOOP4: CLR E SETB R_W CLR RS SETB E MOV A, DB0_DB7 CLR E JB ACC.7,BUSY_LOOP4 POP ACC LCALL DEL CLR E CLR R_W SETB RS SETB E MOV DB0_DB7,A CLR E SJMP $ DEL: MOV R6,#5 L1: MOV R7,#248 DJNZ R7,$ DJNZ R6,L1 RET END
