- /*z地址定義
- 50 x+前進
- 51 x-
- 52 y+
- 53 y-
- 54/55 字寬
- 56 前進步
- 57 激光開關
- 58/59 激光強度
- 60 x軸速度
- 61 y軸速度
- 62 開始打印0,57
- 63 暫停
- 64 停止標志
- 65 bmp灰度圖標志位
- 100開始時灰度圖數據
- #include <reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define N z[60] //X速度
- #define M z[61] //Y速度
- sbit a=P1^0;//步進電機接線定義
- sbit a_=P1^1;
- sbit b=P1^2;
- sbit b_=P1^3;
- sbit xa=P0^0;
- sbit xa_=P0^1;
- sbit xb=P0^2;
- sbit xb_=P0^3;
- sbit jg=P2^0;
- sbit led=P2^1;//指示燈
- uchar xdata z[500]={0};//緩存
- uchar buff[3];//串口緩存
- uchar x1,x0,y1,y0,cont2=0;
- uchar xfb=4,yfb=4;//走步標志位
- uchar x,i,k,temp,jishu;//變量定義,有些沒有用
- uint h=0,jiguang;
- unsigned char HighRH = 0; //高電平重載值的高字節
- unsigned char HighRL = 0; //高電平重載值的低字節
- unsigned char LowRH = 0; //低電平重載值的高字節
- unsigned char LowRL = 0; //低電平重載值的低字節
- void delayms(uint xms)
- uint i,j;
- for(i=xms;i>0;i--) //i=xms即延時約xms毫秒
- for(j=110;j>0;j--);
- /* 配置并啟動PWM,fr-頻率,dc-占空比 */
- void ConfigPWM(unsigned int fr, unsigned char dc)
- unsigned int high, low;
- unsigned long tmp;
- tmp = (11059200/12) / fr; //計算一個周期所需的計數值
- high = (tmp*dc) / 100; //計算高電平所需的計數值
- low = tmp - high; //計算低電平所需的計數值
- high = 65536 - high + 12; //計算高電平的重載值并補償中斷延時
- low = 65536 - low + 12; //計算低電平的重載值并補償中斷延時
- HighRH = (unsigned char)(high>>8); //高電平重載值拆分為高低字節
- HighRL = (unsigned char)high;
- LowRH = (unsigned char)(low>>8); //低電平重載值拆分為高低字節
- LowRL = (unsigned char)low;
- TMOD &= 0xF0; //清零T0的控制位
- TMOD |= 0x01; //配置T0為模式1
- TH0 = HighRH; //加載T0重載值
- TL0 = HighRL;
- ET0 = 1; //使能T0中斷
- TR0 = 1; //啟動T0
- jg = 0; //輸出低電平,關閉激光
- /* 關閉PWM */
- void ClosePWM()
- TR0 = 0; //停止定時器0
- ET0 = 0; //禁止定時器0中斷
- /* T0中斷服務函數,產生PWM輸出 */
- void InterruptTimer0() interrupt 1
- if (jg == 0) //當前輸出為低電平時,裝載高電平值并輸出高電平
- TH0 = LowRH;
- TL0 = LowRL;
- jg = 1;
- else //當前輸出為高電平時,裝載低電平值并輸出低電平
- TH0 = HighRH;
- TL0 = HighRL;
- jg = 0;
- void xfor(uint i) //x軸前進函數,前進多少步
- while(1)
- if(xfb==4)
- xa=xb=1;
- xb_=xa_=0;
- xfb=1;
- i--;
- delayms(N);
- if(i==0){xa=xb=0; break;}
- if(xfb==1)
- xb=xa_=1;
- xa=xb_=0;
- xfb=2;
- i--;
- delayms(N);
- if(i==0){xa_=xb=0; break;}
- if(xfb==2)
- xa_=xb_=1;
- xb=xa=0;
- xfb=3; //走步標志位
- i--;
- delayms(N);
- if(i==0){xa_=xb_=0; break;}
- if(xfb==3)
- xa_=xb=0;
- xb_=xa=1;
- xfb=4;
- i--;
- delayms(N);
- if(i==0){xa=xb_=0; break;}
- void xbac(uint i) //xxx后退函數
- while(1)
- if(xfb==1)
- xa_=xb=0;
- xb_=xa=1;
- xfb=4;
- i--; //走步標志位
- delayms(N);
- if(xfb==4)
- xa_=xb_=1;
- xb=xa=0;
- xfb=3;
- i--;
- delayms(N);
- if(xfb==3)
- xb=xa_=1;
- xa=xb_=0;
- xfb=2; //走步標志位
- i--;
- delayms(N);
- if(xfb==2)
- xa=xb=1;
- xb_=xa_=0;
- xfb=1;
- i--;
- delayms(N);
- void yfor(uint i) //y軸前進函數
- while(1)
- switch(yfb)
- case 4:{a=b=1; b_=a_=0; yfb=1; i--; delayms(M); if(i==0){a=b=0;break;}}
- case 1:{b=a_=1; a=b_=0; yfb=2; i--; delayms(M); if(i==0){a_=b=0;break;}}
- case 2:{a_=b_=1; b=a=0; yfb=3; i--; delayms(M); if(i==0){a_=b_=0;break;}}
- case 3:{b_=a=1; a_=b=0; yfb=4; i--; delayms(M); if(i==0){a=b_=0;break;}}
- if(i==0) break;
- void ybac(uint i) //yy后退函數
- while(1)
- switch(yfb)
- case 1:{a=b_=1; b=a_=0; yfb=4; i--; delayms(M); if(i==0){a=b_=0;break;}}
- case 4:{b_=a_=1; a=b=0; yfb=3; i--; delayms(M); if(i==0){a_=b_=0;break;}}
- case 3:{a_=b=1; b_=a=0; yfb=2; i--; delayms(M); if(i==0){a_=b=0;break;}}
- case 2:{b=a=1; a_=b_=0; yfb=1; i--; delayms(M); if(i==0){a=b=0;break;}}
- if(i==0) break;
- void dazi(uint zik,uchar bu)//打印函數 ******打印函數已更改******
- uint x;
- uint s;
- jg=0;
- bu=1;
- for(x=0;x<zik;x++)//執行zik個循環,x軸右移zik步
- while(z[63]);//暫停等待
- if(z[64]==1) break;//停止標志 跳出循環
- s=z[99+x]*(z[58]*256+z[59])/100;
- jg=1;//開激光
- delayms(s);
- jg=0; //關閉激光
- if(z[66]==1)
- xbac(bu);
- else
- xfor(bu);
- if(z[64]==1) z[64]=0; //停止標志 跳出循環
- else{yfor(bu);}//x軸退回行開始,y軸進一行
- /* 串口配置函數,baud-通信波特率 */
- void ConfigUART(unsigned int baud)
- SCON = 0x50; //配置串口為模式1
- TMOD &= 0x0F; //清零T1的控制位
- TMOD |= 0x20; //配置T1為模式2
- TH1 = 256 - (11059200/12/32)/baud; //計算T1重載值
- TL1 = TH1; //初值等于重載值
- ET1 = 0; //禁止T1中斷
- ES = 1; //使能串口中斷
- TR1 = 1; //啟動T1
- void chuanlo() interrupt 4
- if(RI)
- buff[cont2]=SBUF;//每次3字節,地址高,地址低,數據,,
- cont2++;
- if(cont2==3)//每收3個字節,把數據寫入地址中
- z[(buff[0]*256)+buff[1]]=buff[2];
- cont2=0;
- RI=0;
- main()
- EA=1;
- P0=0xff;
- ConfigUART(9600) ;
- z[60]=15;//默認的參數
- z[61]=50;
- z[56]=1;
- z[62]=0;
- jg=0;
- cont2=0;
- while(1)
- if(z[57]==100) // *****此處已更改******
- { ConfigPWM(100, 98); delayms(10);} //上位機指令處理,打開弱光定位,頻率100Hz,占空比98%
- if(z[57]==0)
- {ClosePWM();delayms(10);}
- if(cont2!=0) led=0; else led=1;//指示通信是否可用
- if(z[50]>0){xfor(z[50]);z[50]=0;}//x前進
- if(z[51]>0){xbac(z[51]);z[51]=0;}
- if(z[52]>0){yfor(z[52]);z[52]=0;}
- if(z[53]>0){ybac(z[53]);z[53]=0;}
- if(z[62])//開始打印標志
- dazi(z[54]*256+z[55],z[56]);
- z[62]=0;//一行打印完成
- SBUF=1;//發送信息,表示打印完成
- while(!TI);
- TI=0;
激光雕刻.rar
2021-1-4 22:11 上傳
下載積分: 黑幣 -5
639.05 KB, 下載次數: 15, 下載積分: 黑幣 -5
