51單片機溫度計LCD1602顯示成功,于是又挑戰了OLED顯示
main.c
#include"oled.h"
#include"ds18b20_1.h"
void Timer0Init(void);
//void Gao_Wen(void);
//void GaoDiInit(void);
sbit Deng=P1^0; //LED燈
sbit FengMing=P1^1; //蜂鳴器
sbit GD=P3^0; //兩個功能:高限溫減小,關閉LED燈
sbit GF=P3^1; //兩個功能:低限溫增加,關閉蜂鳴器
sbit GW=P3^2; //高限溫增加
sbit DW=P3^3; //低限溫減小
//unsigned char GaoWen_Y[]={"GW:"}; //高限溫顯示
//unsigned char DiWen_Y[]={"DW:"}; //低限溫顯示
int GaoWen=40; //高限溫
int DiWen=-20; //低限溫
char flag=0; //一秒標志位
char b=0; //定時器內部標志位;
/*******************************主程序區域********************************/
int main()
bit ack;
bit k=1; //決定超出限溫后,關閉燈和蜂鳴器后不再響,而低于限溫后再次超出限溫后,依然能響標志位;
int Zhen=0,Xiao=0;
unsigned char temp[10];
char len=0;
int wenDu=0; //接收溫度
// LCD_Init();
Deng=0; //LCD初始化
OLED_Init();
Start18B20(); //溫度傳感器初始化
Timer0Init(); //T0定時器初始化
Delay10ms();
// LCD_WeiZhi(1,0);
// LCD_XianShi(GaoWen_Y);
// LCD_WeiZhi(1,9);
// LCD_XianShi(DiWen_Y);
// GaoDiInit();
OLED_ShowChinese(0,0,10,16);
OLED_ShowChinese(18,0,13,16);
OLED_ShowChar(36,0,':',16);
OLED_ShowChinese(0,2,8,16);
OLED_ShowChinese(18,2,10,16);
OLED_ShowChinese(36,2,11,16);
OLED_ShowChinese(54,2,12,16);
OLED_ShowChar(70,2,':',16);
OLED_ShowChinese(0,4,9,16);
OLED_ShowChinese(18,4,10,16);
OLED_ShowChinese(36,4,11,16);
OLED_ShowChinese(54,4,12,16);
OLED_ShowChar(70,4,':',16);
// OLED_ShowString(0,2,"GW:",16);
// OLED_ShowString(64,2,"DW:",16);
OLED_Num(78,2,GaoWen,3,16);
OLED_Num(78,4,DiWen,3,16);
if(flag==1) //1秒刷新溫度
flag=0;
ack=Read18B20(&wenDu);
if(ack)
Zhen=wenDu>>4;
Xiao=wenDu&0x0f;
len=OLED_Xian_Zheng(Zhen,temp);
temp[len++]='.';
Xiao=(Xiao*100)*0.0625;
temp[len++]=Xiao/10+'0';
// temp[len++]=Xiao%10+'0';
while(len<5)
temp[len++]=' ';
temp[len]='\0';
// LCD_WeiZhi(0,0);
// LCD_XianShi(temp);
OLED_ShowString(44,0,temp,16);
Start18B20();
if((Zhen>=GaoWen||Zhen<=DiWen)&&k)
Deng=1;
FengMing=0;
if(Zhen>DiWen&&Zhen<GaoWen)
Deng=0;
FengMing=1;
k=1;
if(GD==0)
Delay10ms();
if(GD==0)
if(Deng==0)
GaoWen--;
// Delay400ms();
// GaoDiInit();
// OLED_Num(20,2,GaoWen,3,16);
// Delay400ms();
Deng=0;
k=0;
if(GF==0)
Delay10ms();
if(GF==0)
if(FengMing==1)
DiWen++;
// Delay400ms();
// GaoDiInit();
// OLED_Num(84,2,DiWen,3,16);
// Delay400ms();
FengMing=1;
k=0;
/********************************定時器初始化******************************/
void Timer0Init(void) //50毫秒@12.000MHz
EA=1;
ET0=1;
EX0=1;
EX1=1;
IT0=1;
IT1=1;
IP=0;
PT0=1;
TMOD &= 0xF0; //設置定時器模式
TMOD |= 0x01; //設置定時器模式
TL0 = 0x00; //設置定時初值
TH0 = 0x4C; //設置定時初值
TF0 = 0; //清除TF0標志
TR0 = 1; //定時器0開始計時
/******************************T0中斷**********************************/
void IT0_1(void) interrupt 1
b++;
if(b>=20)
b=0;
flag=1;
/***************************高限溫增加*************************************/
void Gao(void) interrupt 0
GaoWen++;
if(GaoWen>128)
GaoWen=128;
FengMing=0;
Delay100ms();
FengMing=1;
// GaoDiInit();
/*******************************低限溫減小********************************/
void Di(void) interrupt 2
DiWen--;
if(DiWen<-55)
DiWen=-55;
FengMing=0;
Delay100ms();
FengMing=1;
// GaoDiInit();
// OLED_Num(84,2,GaoWen,3,16);
程序.zip
2021-1-4 15:10 上傳
下載積分: 黑幣 -5
145.76 KB, 下載次數: 149, 下載積分: 黑幣 -5
