為啥iic的寫入和讀取之間要加延時,沒加延時讀取不正常-----------------------------------------------
以下程序用郭天祥例程改的-------------------------------------
#include<reg52.h>
bit write=0; //寫24C02的標志;
sbit sda=P2^0;
sbit scl=P2^1;
void delay()
void delay1ms(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void start() //開始信號
sda=1;
delay();
scl=1;
delay();
sda=0;
delay();
void stop() //停止
sda=0;
delay();
scl=1;
delay();
sda=1;
delay();
void respons() //應答
uchar i;
scl=1;
delay();
while((sda==1)&&(i<250))i++;
scl=0;
delay();
void init()
sda=1;
delay();
scl=1;
delay();
void write_byte(uchar date)
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
temp=temp<<1;
scl=0;
delay();
sda=CY;
delay();
scl=1;
delay();
scl=0;
delay();
sda=1;
delay();
uchar read_byte()
uchar i,k;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i++)
scl=1;
delay();
k=(k<<1)|sda;
scl=0;
delay();
return k;
void write_add(uchar address,uchar date)
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar read_add(uchar address)
uchar date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
stop();
return date;
init();
delay1ms(12);
delay1ms(1);
write_add(2,0xa1);
delay1ms(1);
P1=read_add(2);
while(1);
源碼用郭天祥例程改的
