查看: 2276|回復: 3
基于stc89c52單片機的8*8迷宮電腦鼠 求大神修正我的代碼
ID:871733 發表于 2021-1-2 17:27 | 顯示全部樓層 |閱讀模式
我遇到一個問題 就是 delay函數有重復定義,不知道怎么修改了
  1. #include<reg52.h>
  2. #include<intrins.h>
  3. #include<mouse.h>
  4. #define unchar unsigned char;
  5. #define unint unsigned int;
  6. sbit beef=P3^7;
  7. unchar i,j;
  8. unchar code LM[8]={0x11,0x33,0x22,0x66,0x44,0xcc,0x88,0x99};
  9. unchar code RM[8]={0x11,0x99,0x88,0xcc,0x44,0x66,0x22,0x33};
  10. unchar code forward[8]={0x11,0x93,0x82,0xc6,0x44,0x6c,0x28,0x39};
  11. void delay_ms(unsigned int z)
  12. {
  13.         unsigned char i,j;
  14.         while(--z){
  15.                 _nop_();
  16.                 i=2;
  17.                 j=199;
  18.                 do{
  19.                         while(--j);
  20.                 }
  21.                 while(--i);
  22.         }
  23. }
  24. void runLM(bit f){
  25.         if(f){
  26.                 for(j=0;j<55;j++){
  27.                         for(i=0;i<8;i++){
  28.                                 P1=(RM[i]);
  29.                                 delay_ms(3);
  30.                         }
  31.                 }
  32.         }
  33. }
  34. void runRM(bit f){
  35.         if(f){
  36.                 for(j=0;j<55;j++){
  37.                         for(i=0;i<8;i++){
  38.                                 P1=(LM[i]);
  39.                                 delay_ms(3);
  40.                         }
  41.                 }
  42.         }
  43. }
  44. void turnOff(bit f){
  45.         if(f){
  46.                 for(j=0;j<110;j++){
  47.                         for(i=0;i<8;i++){
  48.                                 P1=(LM[i]);
  49.                                 delay_ms(3);
  50.                         }
  51.                 }
  52.         }
  53. }
  54. void Lxz(bit f){
  55.         if(f){
  56.                 for(j=0;j<8;j++){
  57.                         for(i=0;i<8;i++){
  58.                                 P1=(RM[i]|0x0f);
  59.                                 delay_ms(3);
  60.                         }
  61.                 }
  62.         }
  63. }
  64.
  65. void Rxz(bit f){
  66.         if(f){
  67.                 for(j=0;j<8;j++){
  68.                         for(i=0;i<8;i++){
  69.                                 P1=(LM[i]|0xf0);
  70.                                 delay_ms(3);
  71.                         }
  72.                 }
  73.         }
  74. }
  75.
  76. void Go(bit f){
  77.         if(f){
  78.                 for(j=0;j<101;j++){
  79.                         for(i=0;i<8;i++){
  80.                                 P1=(forward[i]);
  81.                                 delay_ms(3);
  82.                         }
  83.                         if(irRU==1&&irC==0&irR==1){
  84.                                 Lxz(1);
  85.                         }
  86.                         if(irLU==1&&irC==0&&irL==1){
  87.                                 Rxz(1);
  88.                         }
  89.                 }
  90.         }
  91. }
  92.
  93. void Control(){
  94.         if(irC==0&&irL==1&&irR==1){
  95.                 Go(1);
  96.                 delay_ms(800);
  97.         }
  98.         if(irC==1&&irR==1&&irL==0){
  99.                 runLM(1);
  100.                 delay_ms(800);
  101.                 Go(1);
  102.         }
  103.         if(irC==1&&irR==0&&irL==1){
  104.                 runRM(1);
  105.                 delay_ms(800);
  106.                 Go(1);
  107.         }
  108.         if(irC==1&&irR==0&&irL==0){
  109.                 runRM(1);
  110.                 delay_ms(800);
  111.                 Go(1);
  112.         }
  113.         if(irC==0&&irR==0&&irL==0){
  114.                 runRM(1);
  115.                 delay_ms(800);
  116.                 Go(1);
  117.         }
  118.         if(irC==1&irL==1&irR==1){
  119.                 turnOff(1);
  120.                 delay_ms(800);
  121.                 Go(1);
  122.         }
  123. }
  124.
  125. void setTime2(unsigned int us){
  126.         TH2=(65536-us)/256;
  127.         RCAP2H=(65536-us)/256;
  128.         TL2=(65536-us)%256;
  129.         RCAP2L=(65536-us)%256;
  130. }
  131. void intTime2(){
  132.         EA=1;
  133.         ET2=1;
  134.         setTime2(5000);
  135.         TR2=1;
  136. }
  137. void time2()interrupt 5{
  138.         static bit ir=0;
  139.         TF2=0;
  140.         if(!ir)
  141.                 MOUSE_IR_ON(i);
  142.         else{
  143.                         switch(i++){
  144.                                 case 0:{if(irR1){irC=0;}
  145.                                 else{irC=1;}}break;
  146.                                 case 1:{if(irR2){irL=0;}
  147.                                 else{irL=1;}}break;
  148.                                 case 2:{if(irR3){irR=0;}
  149.                                 else{irR=1;}}break;
  150.                                 case 3:{if(irR4){irLU=0;}
  151.                                 else{irLU=1;}}break;
  152.                                 case 4:{if(irR5){irRU=0;}
  153.                                 else{irRU=1;}}break;
  154.                         }if(i==5) i=0;
  155.                 }ir=~ir;
  156.         }
  157.         void main(){
  158.                 setTime2();
  159.                 delay_ms(1000);
  160.                 while(1){
  161.                         Control();
  162.                         delay_ms(800);
  163.                 }
  164. }
電路圖:http://m.raoushi.com/bbs/dpj-200855-1.html
ID:328014 發表于 2021-1-2 22:48 | 顯示全部樓層
你的代碼應該沒問題吧?149行  MOUSE_IR_ON(i); 這個括號是怎么回事?
ID:871733 發表于 2021-1-3 13:39 | 顯示全部樓層
51hei團團 發表于 2021-1-2 22:48
這是我定義的一個頭文件的函數,就是控制紅外的發射和接收
ID:275826 發表于 2021-1-4 18:07 | 顯示全部樓層
要看你的MOUSE.H頭文件有沒有DELAY()定義
