查看: 1436|回復: 0
單片機定時器LCD1602液晶顯示
ID:872202 發表于 2021-1-2 15:37 | 顯示全部樓層 |閱讀模式
程序:
  1. #include<reg52.h>
  3. sbit rd=P2^6;
  4. sbit wr=P2^5;
  5. sbit lcde=P2^7;
  6. sbit k1=P3^2;
  7. sbit k2=P3^3;
  8. sbit k4=P3^4;
  9. sbit k8=P3^5;
  10. uchar code table1[]=" 2020-12-21 SAT";
  11. uchar code table2[]="00:00:00";
  12. uchar t,s1num;
  13. char shi,fen,miao;
  14. void delay(uchar z) //延遲zms函數
  15. {
  16. uchar x,y;
  17. for(x=z;x>0;x--)
  18. for(y=110;y>0;y--);
  19. }
  20. void write_com(uchar com) //液晶寫指令操作
  21. {
  22. rd=0;
  23. wr=0;
  24. delay(5);
  25. lcde=1;
  26. P0=com;
  27. lcde=0;
  28. }
  29. void write_date(uchar date) //液晶寫數據操作
  30. {
  31. rd=1;
  32. wr=0;
  33. delay(5);
  34. lcde=1;
  35. P0=date;
  36. lcde=0;
  37. }
  38. void write_sfm(uchar add,uchar date) //更新時分秒
  39. {
  40. uchar shi,ge;
  41. shi=date/10;
  42. ge=date;
  43. write_com(0x80+0x40+add);
  44. write_date(0x30+shi);
  45. write_date(0x30+ge);
  46. }
  47. void init() //初始化函數
  48. {
  49. uchar i;
  50. write_com(0x38);
  51. write_com(0x0c);
  52. write_com(0x06);
  53. write_com(0x01);
  54. write_com(0x80+0x00);
  55. for(i=0;i<15;i++)
  56. write_date(table1[i]);
  57. write_com(0x80+0x46);
  58. for(i=0;i<8;i++)
  59. write_date(table2[i]);
  60. TMOD=0x01; //定時器工作方式
  61. TH0=(65536-50000)/256; //設定定時器初值
  62. TL0=(65536-50000)%6; //12M晶振時ms數為
  63. EA=1;
  64. ET0=1;
  65. TR0=1;
  66. }
  67. void keyscan() //鍵盤掃描函數
  68. {
  69. if(k1==0) //按下k1鍵確定調時分秒
  70. {
  71. delay(5);
  72. if(k1==0)
  73. {
  74. s1num++;
  75. while(!k1)
  76. ;
  77. delay(5);
  78. while(!k1);
  79. if(s1num==1)
  80. {
  81. TR0=0; //暫停計時器
  82. write_com(0x80+0x4d); //光標在秒的位置閃爍
  83. write_com(0x0f);
  84. }
  85. if(s1num==2) //光標在分的位置
  86. {
  87. TR0=0;
  88. write_com(0x80+0x4a);
  89. write_com(0x0f);
  90. }
  91. if(s1num==3)
  92. {
  93. TR0=0;
  94. write_com(0x80+0x47);
  95. write_com(0x0f);
  96. }
  97. if(s1num==4) //按下第四下時接著走時
  98. {
  99. s1num=0;
  100. write_com(0x0c);
  101. TR0=1;
  102. }
  103. }
  104. }
  105. if(s1num!=0)
  106. {
  107. if(s1num==1)
  108. {
  109. if(k2==0) //按k2鍵秒加
  110. {
  111. delay(5);
  112. if(k2==0)
  113. {
  114. while(!k2);
  115. delay(5);
  116. while(!k2);
  117. miao++;
  118. if(miao==60)
  119. miao=0;
  120. write_sfm(0x0c,miao);
  121. write_com(0x80+0x4d);
  122. }
  123. }
  124. }
  125. if(s1num==2)
  126. {
  127. if(k2==0) //分加
  128. {
  129. delay(5);
  130. if(k2==0)
  131. {
  132. while(!k2);
  133. delay(5);
  134. while(!k2);
  135. fen++;
  136. if(fen==60)
  137. fen=0;
  138. write_sfm(0x09,fen);
  139. write_com(0x80+0x4a);
  140. }
  141. }
  142. }
  143. if(s1num==3)
  144. {
  145. if(k2==0) //時加
  146. {
  147. delay(5);
  148. if(k2==0)
  149. {
  150. while(!k2);
  151. delay(5);
  152. while(!k2);
  153. shi++;
  154. if(shi==24)
  155. shi=0;
  156. write_sfm(0x06,shi);
  157. write_com(0x80+0x47);
  158. }
  159. }
  160. }
  161. if(k4==0) //判斷k3是否被按下
  162. {
  163. delay(5);
  164. if(k4==0)
  165. {
  166. while(!k4);
  167. delay(5);
  168. while(!k4);
  169. if(s1num==1)
  170. {
  171. miao--; //秒減
  172. if(miao==-1)
  173. miao=59;
  174. write_sfm(0x0c,miao);
  175. write_com(0x80+0x4d);
  176. }
  177. if(s1num==2)
  178. {
  179. fen--; //分減
  180. if(fen==-1)
  181. fen=59;
  182. write_sfm(0x09,fen);
  183. write_com(0x80+0x4a);
  184. }
  185. if(s1num==3)
  186. {
  187. shi--; //時減
  188. if(shi==-1)
  189. shi=23;
  190. write_sfm(0x06,shi);
  191. write_com(0x80+0x47);
  192. }
  193. }
  194. }
  195. }
  196. if(k8==0) // 按下k8退出調時
  197. {
  198. delay(5);
  199. if(k8==0)
  200. {
  201. while(!k8);
  202. delay(5);
  203. while(!k8);
  204. s1num=0;
  205. write_com(0x0c);
  206. TR0=1;
  207. }
  208. }
  209. }
  210. void main()
  211. {
  212. init();
  213. while(1)
  214. {
  215. keyscan();
  216. }
  217. }
  218. void timer0() interrupt 1 //中斷服務程序
  219. {
  220. TH0=(65536-50000)/256;
  221. TL0=(65536-50000)%6; //重新設定定時器初值
  222. t++;
  223. if(t==20) //定時器中斷次為秒
  224. {
  225. t=0;
  226. miao++;
  227. if(miao==60)
  228. {
  229. miao=0;
  230. fen++;
  231. if(fen==60)
  232. {
  233. fen=0;
  234. shi++;
  235. if(shi==24)
  236. {
  237. shi=0;
  238. }
  239. write_sfm(0x06,shi); //顯示時
  240. }
  241. write_sfm(0x09,fen); //顯示分
  242. }
  243. write_sfm(0x0c,miao); //顯示秒
  244. }
  245. }
