查看: 2719|回復: 1
STM32車載娛樂播放與儀表顯示程序 2020年計算機能力挑戰賽嵌入式
基本功能全實現了,擴張功能實現了IIC和錄音機,還實現了WIFI上傳。有問題可以提出來,供大家一起討論。圖片附件
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "key.h"
  7. #include "usmart.h"
  8. #include "malloc.h"
  9. #include "w25qxx.h"
  10. #include "sdio_sdcard.h"
  11. #include "ff.h"
  12. #include "exfuns.h"
  13. #include "fontupd.h"
  14. #include "text.h"
  15. #include "wm8978.h"
  16. #include "audioplay.h"
  17. #include "recorder.h"
  18. #include "24cxx.h"
  19. #include "dht11.h"
  20. #include "adc.h"
  21. #include "timer.h"
  22. #include "cgq.h"
  23. #include "usart2.h"
  24. #include "wifi.h"
  25. u8 volume = 32;
  26. u8 action_sign;
  27. extern u8 temperature,humidity,led_state,speed,temp1,temp2;
  28. int main(void)
  29. {
  30.         u8 key;
  31.         u8 number_table[7];
  32.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置系統中斷優先級分組2
  33.         delay_init(168);  //初始化延時函數
  34.         uart_init(115200);                //初始化串口波特率為115200
  35.         Usart3_Init(115200);
  36.         LED_Init();                                        //初始化LED
  37.          LCD_Init();                                        //LCD初始化
  38.          KEY_Init();                                        //按鍵初始化
  39.         W25QXX_Init();                                //初始化W25Q128
  40.         WM8978_Init();                                //初始化WM8978
  41.         WM8978_HPvol_Set(40,40);        //耳機音量設置
  42.         WM8978_SPKvol_Set(volume);                //喇叭音量設置
  43.         Adc_Init();
  44.
  45.         TIM5_CH1_Cap_Init(0XFFFFFFFF,84-1); //以1Mhz的頻率計數
  46.         WiFi_ResetIO_Init();
  47.         usmart_dev.init(84);                //初始化USMART
  48.         while(DHT11_Init())
  49.         {
  50.                 printf("DHT11不存在");
  51.         }
  52.
  53.         my_mem_init(SRAMIN);                //初始化內部內存池
  54.         my_mem_init(SRAMCCM);                //初始化CCM內存池
  55.         exfuns_init();                                //為fatfs相關變量申請內存
  56.           f_mount(fs[0],"0:",1);                 //掛載SD卡
  57.         POINT_COLOR=RED;
  58.         while(AT24CXX_Check())//檢測不到24c02
  59.         {
  60.                 LCD_ShowString(30,110,200,16,16,"24C02 Check Failed!");
  61.                 delay_ms(500);
  62.                 LCD_ShowString(30,110,200,16,16,"Please Check!      ");
  63.                 delay_ms(500);
  64.                 LED0=!LED0;//DS0閃爍
  65.         }
  66.         while(font_init())                         //檢查字庫
  67.         {
  68.                 LCD_ShowString(30,40,200,16,16,"Font Error!");
  69.                 delay_ms(200);
  70.                 LCD_Fill(30,40,240,66,WHITE);//清除顯示
  71.                 delay_ms(200);
  72.         }
  73.         POINT_COLOR=RED;
  74.          Show_Str(30,50,200,16,"Explorer STM32開發板",16,0);
  75.         Show_Str(30,70,200,16,"車載系統",16,0);
  76.         Show_Str(30,90,200,16,"2020年12月13日",16,0);
  77.         Show_Str(30,110,200,16,"KEY0:播放器 KEY2:錄音機",16,0);
  78.         Show_Str(30,130,200,16,"KEY1:傳感器 KEY3:調速  ",16,0);
  79.
  80.         AT24CXX_Read(0,number_table,7);
  81.         if(number_table[0] == 128)
  82.         {
  83.                 temperature = number_table[1];
  84.                 humidity                 = number_table[2];
  85.                 led_state         = number_table[3];
  86.                 speed                         = number_table[4];
  87.                 temp1                         = number_table[5];
  88.                 temp2                                = number_table[6];
  89.                 //printf("%d-%d-%d-%d-%d-%d\r\n",temperature,humidity,led_state,speed,temp1,temp2);
  90.         }
  91.         initial_interface();
  92.         TIM2_Int_Init(20000,8399);
  93.         while(1)
  94.         {
  95.                 key = KEY_Scan(0);
  96.                 switch(key)
  97.                 {
  98.                         case KEY0_PRES:audio_play();initial_interface();break;
  99.                         case KEY2_PRES:wav_recorder();initial_interface();break;
  100.                         case KEY1_PRES:cc();initial_interface();break;
  101.                         case WKUP_PRES:xgsd();initial_interface();break;
  102.                 }
  103.         }
  104. }
代碼.7z (821 KB, 下載次數: 16)
ID:871095 發表于 2020-12-30 17:15 | 只看該作者
