查看: 1219|回復: 1
哪位大佬可以幫忙看一下這個怎么解決嗎C(33)實際參數太少,C(33)不同的參數長度。謝謝
ID:870438 發表于 2020-12-29 18:00 | 顯示全部樓層 |閱讀模式
本帖最后由 1529689548 于 2020-12-29 18:09 編輯
#include<reg52.h>
sbit key1=P3^4;
sbit key2=P3^5;
sbit key3=P3^6;
sbit key4=P3^7;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7c,0x07,0x7f,0x67};
uchar code table2[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfc,0x87,0xff,0xe7};
void delayms(uint);
void display(uchar,uchar,uchar,uchar);
void keyscan();
uchar num1,num2,bai,shi,ge;
uint num;
TMOD=0x11;
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
TH1=(65536-45872)/256;
TL1=(65536-45872)%256;
EA=1;
ET0=1;
ET1=0;
keyscan();
bai=num/100;
shi=(num-100*bai)/10;
ge=num-100*bai-shi*10;
display(bai,shi,ge);
void display(uchar bai,uchar shi,uchar ge)
     P1=0xfe;
     P2=table[bai];
     delayms(10);
     P1=0xff;
     P1=0xfd;
     P2=table2[shi];
     delayms(10);
     P1=0xff;
     P1=0xfb;
     P2=table[ge];
     delayms(10);
     P1=0xff;
     void delayms(uint xms)
     uint i,j;
     for(i=xms;i>0;i--)
           for(j=110;j>0;j--);
void keyscan()
  if(key1==0)
           delayms(10);
           if(key1==0)
                         while(!key1)
                                 TR1=1;
                                 num=0;
                                 TR1=0;
  if(key2==0)
           delayms(10);
           if(key2==0)
                         while(!key2);
                                 TR0=0;
                                 TR1=~TR1;
      if(key3==0)
                while(!key3);
                TR0=0;
                TR1=1;
                num=999;
                TR1=0;
                TR0=~TR0;//TR0=1;
void T0_time()interrupt 1
{TH0=(65536-45872)/256;
     num2++;
     if(num2==2)
        {  num2=0;
           num1++;
     if(num1==10)
     num1=0;
     if(num==0)
     num=999;
         num--;
void T1_time()interrupt 3
{    TH1=(65536-45872)/256;
     num2++;
     if(num2==2)
        {  num2=0;
           num1++;
        if(num1==10)
           num1=0;
           num++;
        if(num==999);
         num=0;
ID:213173 發表于 2020-12-29 20:11 | 顯示全部樓層
void display(uchar,uchar,uchar,uchar);聲明函數有4個參數
void display(uchar bai,uchar shi,uchar ge)函數體只有3個參數
