查看: 3446|回復: 2
stm32超聲波程序 通過定時器4計數器值推算距離Hcsr04GetLength
ID:765425 發表于 2020-12-28 15:43 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
STM32F103C8T6超聲波程序
  1. #include "delay.h"
  2. #include "sys.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "key.h"
  6. //超聲波硬件接口定義
  7. #define HCSR04_PORT     GPIOB
  8. #define HCSR04_CLK      RCC_APB2Periph_GPIOB
  9. #define HCSR04_TRIG     GPIO_Pin_11
  10. #define HCSR04_ECHO     GPIO_Pin_10
  11. //超聲波計數
  12. u16 msHcCount = 0;
  13. //定時器4設置
  14. void hcsr04_NVIC()
  15. {
  16.         NVIC_InitTypeDef NVIC_InitStructure;
  17.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  18.
  19.         NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
  20.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  21.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  22.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  23.         NVIC_Init(&NVIC_InitStructure);
  24. }
  25. //IO口初始化 及其他初始化
  26. void Hcsr04Init()
  27. {
  28.     TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  29.     GPIO_InitTypeDef GPIO_InitStructure;
  30.     RCC_APB2PeriphClockCmd(HCSR04_CLK, ENABLE);
  31.
  32.     GPIO_InitStructure.GPIO_Pin =HCSR04_TRIG;
  33.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  34.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  35.     GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
  36.     GPIO_ResetBits(HCSR04_PORT,HCSR04_TRIG);
  37.
  38.     GPIO_InitStructure.GPIO_Pin =   HCSR04_ECHO;
  39.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  40.     GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
  41.     GPIO_ResetBits(HCSR04_PORT,HCSR04_ECHO);
  42.
  43.
  44.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
  45.
  46.     TIM_DeInit(TIM4);
  47.     TIM_TimeBaseStructure.TIM_Period = (999);
  48.     TIM_TimeBaseStructure.TIM_Prescaler =(71);
  49.     TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  50.     TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  51.     TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  52.
  53.     TIM_ClearFlag(TIM4, TIM_FLAG_Update);
  54.     TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE);
  55.     TIM_Cmd(TIM4,DISABLE);
  56. }
  57. //打開定時器4
  58. static void OpenTimerForHc()
  59. {
  60.    TIM_SetCounter(TIM4,0);
  61.    msHcCount = 0;
  62.    TIM_Cmd(TIM4, ENABLE);
  63. }
  64. //關閉定時器4
  65. static void CloseTimerForHc()
  66. {
  67.    TIM_Cmd(TIM4, DISABLE);
  68. }
  69. //定時器4終中斷
  70. void TIM4_IRQHandler(void)
  71. {
  72.    if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
  73.    {
  74.                    msHcCount++;
  75.        TIM_ClearITPendingBit(TIM4, TIM_IT_Update  );
  76.
  77.    }
  78. }
  79. //獲取定時器4計數器值
  80. u32 GetEchoTimer(void)
  81. {
  82.    u32 t = 0;
  83.    t = msHcCount*1000;
  84.    t += TIM_GetCounter(TIM4);
  85.    TIM4->CNT = 0;
  86.    delay_ms(50);
  87.    return t;
  88. }
  89. //通過定時器4計數器值推算距離
  90. float Hcsr04GetLength(void )
  91. {
  92.    u32 t = 0;
  93.    int i = 0;
  94.    float lengthTemp = 0;
  95.    float sum = 0;
  96.    while(i!=5)
  97.    {
  98.       TRIG_Send = 1;
  99.       delay_us(20);
  100.       TRIG_Send = 0;
  101.       while(ECHO_Reci == 0);
  102.       OpenTimerForHc();
  103.       i = i + 1;
  104.       while(ECHO_Reci == 1);
  105.       CloseTimerForHc();
  106.       t = GetEchoTimer();
  107.                         lengthTemp = ((float)t*0.034/2);//cm
  108.       sum = lengthTemp + sum ;
  109.
  110.     }
  111.     lengthTemp = sum/5.0;
  112.     return lengthTemp;
  113. }
  114.
  115. //測試主函數
  116. int main(void)
  117. {
  118.          float length;
  119.          delay_init();                     //延時函數初始化
  120.          //NVIC_Configuration();          //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
  121.          hcsr04_NVIC();
  122.          uart_init(9600);                 //串口初始化為9600
  123.          Hcsr04Init();
  124.          LED_Init();
  125.
  126.   // Hcsr04Init();
  127.
  128.    while(1)
  129.          {
  130.      length = Hcsr04GetLength();
  131.      printf("距離為:%.3fcm\n",length);
  132.                  if(length<30)
  133.                  {
  134.                                  GPIO_ResetBits(GPIOB,GPIO_Pin_0);
  135.                  }
  136.                  else
  137.                  {
  138.                          GPIO_SetBits(GPIOB,GPIO_Pin_0);
  139.                  }
  140.                  delay_ms(50);
  141.         }
  142. }
全部程序51hei下載地址:
超聲波(用).7z (219.34 KB, 下載次數: 135)
收藏收藏4 分享淘帖 頂 踩
ID:398975 發表于 2021-3-12 10:41 | 只看該作者
網上很多不能用,謝謝樓主!
ID:208271 發表于 2021-3-20 12:50 | 只看該作者
STM32F103C8T6核心板,可以直接用,程序很好,沒問題,容易移植。謝謝樓主。
