剛剛在編譯時,提示編譯成功了,但是沒有生成任何子文件,像 .o .hex .c 都沒有,我也是剛學這個單片機編程,好多不太理解,還望各位大佬幫忙指出一下,謝謝!!!!!
2020-12-28 09:43 上傳
- list p=16f887
- #include <p16f887.inc> ; processor specific variable definitions
- w_temp EQU 0x71 ; variable used for context saving
- status_temp EQU 0x72 ; variable used for context saving
- BIAN EQU 0X40 ;鍵盤顯示中間變量
- KEYFLAG EQU 0X43
- NUM EQU 0X44
- NUM4 EQU 0X48
- NUMB EQU 0X49 ;計數變量
- GE EQU 0X50
- SHI EQU 0X51
- BAI EQU 0X52
- SHANG EQU 0X53
- YUSHU EQU 0X54
- COUNTER EQU 0X55
- NUM5 EQU 0X56
- NUM6 EQU 0X57
- NUM7 EQU 0X58
- NUM8 EQU 0X59
- NUM9 EQU 0X60
- NUM10 EQU 0X61
- NUM11 EQU 0X62
- ORG 0x000 ; processor reset vector
- clrf PCLATH ; ensure page bits are cleared
- goto MAIN ; go to beginning of program
- ORG 0x004 ; interrupt vector location
- movwf w_temp ; save off current W register contents
- movf STATUS,w ; move status register into W register
- movwf status_temp ; save off contents of STATUS register
- BCF INTCON,T0IF ;清 TMR0 溢出標志位
- DECFSZ COUNTER ;循環減 1,是否為 0
- GOTO RT ;否,中斷返回
- DECF NUMB ;是,計數變量減 1
- MOVLW .20 ;循環數賦初值 20
- MOVWF COUNTER
- RT MOVLW 3DH ;50 毫秒時間常數初值
- MOVWF TMR0
- ; isr code can go here or be located as a call subroutine elsewhere
- movf status_temp,w ; retrieve copy of STATUS register
- movwf STATUS ; restore pre-isr STATUS register contents
- swapf w_temp,f
- swapf w_temp,w ; restore pre-isr W register contents
- retfie ; return from interrupt
- MAIN ;主程序
- ; remaining code goes here
- BSF STATUS,RP1 ;16F887 初始化
- BSF STATUS,RP0
- CLRF ANSEL
- CLRF ANSELH
- BCF STATUS,RP1
- BCF STATUS,RP0
- CLRF BIAN ;變量的初始化
- CLRF NUM4
- CLRF NUM
- CLRF NUM8
- CLRF NUM9
- CLRF NUM10
- MOVLW 01H ;KEYFLAG 初始化,為 1
- MOVWF KEYFLAG
- BSF STATUS,RP0 ;進入體 1
- CLRF TRISD ;RD 設為輸出
- MOVLW 07H ;分頻比為 1:256
- MOVWF OPTION_REG
- MOVLW 0C1H ;RB 的位 1,2,3,4,5 設為輸出
- MOVWF TRISB
- MOVLW 0F0H ;RD 低四位輸入,高四位輸出
- MOVWF TRISC
- MOVLW 08H ;RE 位 1,2,3 輸出
- MOVWF TRISE
- BCF STATUS,RP0 ;進入體 0
- MOVLW B'10100000' ;打開總中斷和 T0 中斷使能位
- MOVWF INTCON
- MOVLW .20 ;送入中斷循環次數初值為 20
- MOVWF COUNTER
- MOVLW 0FFH ;RB,RD 關閉
- MOVWF PORTD
- MOVWF PORTB
- MOVLW 07H ;RE 關閉
- MOVWF PORTE
- CLRF NUM5 ;清空變量
- CLRF NUM6
- CLRF NUM7
- GOTO LOOP ;跳至大循環
- ;動態計數顯示子程序,用于倒計時數的顯示
- LOOP6 CALL CALC ;調用分解子程序
- CALL DISPLAY ;調用顯示子程序
- CALL JIANPAN ;調用鍵盤掃描子程序
- MOVLW 00H ;計數變量是否為 0
- SUBWF NUMB,W
- BTFSC STATUS,Z
- CALL LIGHT ;是,調用為 0 提示及恢復子程序
- GOTO LOOP6 ;否,返回循環
- ;提示子程序,用于計時為 0 時的提示和程序的重初始化
- LIGHT BCF INTCON,5 ;關閉 T0 使能,計時器停止工作
- CALL SHANSHU ;調用小燈閃爍子程序
- MOVWF KEYFLAG
- CLRF NUM9 ;中間變量的初始化
- CLRF NUM10
- GOTO LOOP ;跳轉至 LOOP 大循環,重新開始工作
- ;分解子程序,多位數的分解
- CALC MOVF NUMB,W ;顯示變量送入 W 寄存器
- CALL DIV10 ;調用除十子程序
- MOVWF GE ;將返回數送入 GE,用于個位顯示
- MOVF SHANG,W ;變量 SHANG 送如 W 寄存器
- MOVWF SHI ;返回數送入 SHI,用于十位的顯示
- MOVF SHANG,W ;SHANG 送入 BAI,用于百位的顯示
- MOVWF BAI
- RETURN
- ;顯示子程序
- DISPLAY MOVF GE,W ;個位數送入 W 寄存器
- CALL CHABIAO ;查表子程序
- MOVWF PORTD ;碼值送入段選
- BCF PORTB,1 ;個位位選打開
- CALL DELAY ;延時
- BSF PORTB,1 ;位選關閉
- MOVF SHI,W
- CALL CHABIAO ;十位數查表
- MOVWF PORTD ;送入段選
- BCF PORTB,2 ;十位位選打開
- CALL DELAY ;延時
- BSF PORTB,2 ;位選關閉
- MOVF BAI,W
- CALL CHABIAO ;百位數查表
- MOVWF PORTD ;送入段選
- BCF PORTB,3 ;百位位選打開
- CALL DELAY ;延時
- BSF PORTB,3 ;位選關閉
- RETURN
- ;除十子程序
- DIV10 MOVWF YUSHU ;將值送入 YUSHU
- CLRF SHANG ;清空 SHANG
- MOVLW .10
- DIVLOOP SUBWF YUSHU,F ;YUSHU 減 10
- INCF SHANG,F ;SHANG 加 1
- BTFSC STATUS,C ;是否借位
- GOTO DIVLOOP ;無,返回繼續判斷
- DECF SHANG,F ;是,SHANG 減 1
- ADDWF YUSHU,W ;YUSHU 加 10 放入 W 返回
- RETURN
- ;鍵盤掃描及顯示大循環,用于鍵入數的顯示
- LOOP CALL JIANPAN ;調用鍵盤掃描子程序
- BTFSC KEYFLAG,1 ;是否第一次鍵
- CALL XIANSHI1 ;是,調用顯示 1 子程序
- BTFSC KEYFLAG,2 ;是否第二次鍵入
- CALL XIANSHI2 ;是,調用顯示 2 子程序
- BTFSC KEYFLAG,3 ;是否第三次鍵入
- CALL XIANSHI3 ;是,調用顯示 3 子程序
- BTFSC KEYFLAG,4 ;是否第四次按下
- CALL FLAGINI ;是,調用鍵入次數循環子程序
- GOTO LOOP ;返回大循環
- ;鍵入次數循環子程序
- FLAGINI MOVLW 02H ;KEYFLAG 恢復初始值
- MOVWF KEYFLAG
- RETURN
- ;查表子程序
- CHABIAO ADDWF PCL,F
- RETLW0XC0
- RETLW0XF9
- RETLW0XA4
- RETLW0XB0
- RETLW0X99
- RETLW0X92
- RETLW0X82
- RETLW0XF8
- RETLW0X80
- RETLW0X90
- ;鍵盤顯示 1 子程序
- XIANSHI1 BCF PORTB,1 ;位選打開
- MOVF BIAN,W ;送入鍵入數段選
- MOVWF PORTD
- MOVWF NUM ;段選復制到 NUM 里,為后來使用
- BSF PORTB,1 ;關閉位選
- MOVF NUM8,W ;將加入數送入 NUM5
- MOVWF NUM5
- MOVWF NUMB ;同時送入顯示變量
- MOVWF NUM11 ;為顯示 3 子程序所用
- RETURN
- ;鍵盤顯示 2 子程序,用于 2 位數的鍵入顯示
- XIANSHI2 BCF PORTB,1 ;個位位選打開
- MOVF BIAN,W ;送入段選
- MOVWF PORTD
- MOVWF NUM4 ;同時復制到 NUM4,為 3 位顯示所用
- CALL DELAY ;延時
- BSF PORTB,1 ;個位位選關閉
- MOVF NUM,W ;送入段選
- MOVWF PORTD
- CALL DELAY ;延時
- BSF PORTB,2 ;位選關閉
- ;2 個數組合成十進制兩位數
- MOVF NUM8,W ;將 NUM8 放入 NUM6,為送數所用
- MOVWF NUM6
- MOVLW 00H ;十位是否為 0
- SUBWF NUM5,F
- BTFSS STATUS,Z
- CALL JIASHI1 ;否,調用加十 1 子程序
- MOVF NUM9,W ;將 NUM9 與 NUM6 相加
- ADDWF NUM6,W
- MOVWF NUMB ;放入顯示變量里
- RETURN
- ;加十 1 子程序
- JIASHI1 MOVLW .10 ;NUM9 加十
- ADDWF NUM9,F
- DECF NUM5,F ;NUM5 減 1
- BTFSS STATUS,Z ;判斷是否為 0
- GOTO JIASHI1 ;否,繼續加十
- RETURN ;是,返回
- ;鍵盤顯示 3 子程序,用于鍵入 3 位數的顯示
- XIANSHI3 BCF PORTB,1 ;個位位選打開
- MOVF BIAN,W ;送入個位段選
- MOVWF PORTD
- CALL DELAY ;調用短時間延時子程序
- BSF PORTB,1 ;關閉個位位選
- BCF PORTB,2 ;打開十位位選
- MOVF NUM4,W ;送入十位段選
- MOVWF PORTD
- CALL DELAY ;延時
- BSF PORTB,2 ;關閉位選
- BCF PORTB,3 ;打開百位位選
- MOVF NUM,W ;送入百位段選
- MOVWF PORTD
- CALL DELAY ;延時
- BSF PORTB,3 ;關閉位選
- ;進行三個數到十進制三位數的轉換
- MOVF NUM8,W ;將 NUM8 復制到 MUM7
- MOVWF NUM7
- MOVLW 00H ;判斷百位數是否為 0
- SUBWF NUM11,F
- BTFSS STATUS,Z
- CALL JIABAI ;不為 0,調用加百子程序
- MOVLW 00H ;為 0,繼續判斷十位數是否為 0
- SUBWF NUM6,F
- BTFSS STATUS,Z
- CALL JIASHI2 ;不為 0,調用加十 2 子程序
- MOVF NUM10,W ;將個位數與 NUM10 相加
- ADDWF NUM7,W
- MOVWF NUMB ;組成的數放入顯示變量 NUMB
- RETURN
- ;加百子程序
- JIABAI MOVLW .100 ;NUM10 加 100
- ADDWF NUM10,F
- DECF NUM11,F ;NUM11 減 1
- GOTO JIABAI ;不為 0,返回加百
- RETURN ;為 0,返回
- ;加十 2 子程序
- JIASHI2 MOVLW .10 ;NUM10 加 10
- ADDWF NUM10,F
- DECF NUM6,F ;NUM6 減 1
- BTFSS STATUS,Z ;是否為 0
- GOTO JIASHI2 ;否,繼續加十
- RETURN ;是,返回
- ;鍵盤子程序,用于判斷是否鍵入和鍵入何鍵,并實現相應功能
- JIANPAN MOVLW 00H ;RC 口低四位輸出低電平
- MOVWF PORTC
- MOVLW 0F0H
- ANDWF PORTC,W ;屏蔽低四位
- SUBLW 0F0H
- BTFSC STATUS,Z ;判斷高四位是否為全 1
- RETURN ;是,無鍵輸入,返回繼續判斷
- CALL DELAY10MS ;否,有可能有鍵輸入,延時 20 毫秒
- CALL DELAY10MS
- MOVLW 0F0H ;再判斷一次是否鍵入
- ANDWF PORTC,W
- SUBLW 0F0H
- BTFSC STATUS,Z
- RETURN ;虛假輸入,返回
- BCF PORTB,5 ;確實有鍵輸入,蜂鳴器鳴叫
- MOVLW 0FEH ;逐行判斷哪個鍵輸入,首先 RC0=0
- MOVWF PORTC
- BTFSS PORTC,4 ;判斷鍵 0
- GOTO JIAN0 ;是,跳至鍵 0 功能子程序
- BTFSS PORTC,5 ;判斷鍵 1
- GOTO JIAN1 ;是,跳至鍵 1 功能子程序
- BTFSS PORTC,6 ;判斷鍵 2
- GOTO JIAN2 ;是,跳至鍵 2 功能子程序
- BTFSS PORTC,7 ;判斷鍵 3
- GOTO JIAN3 ;是,跳至鍵 3 功能子程序
- MOVLW 0FDH ;RC1=0
- MOVWF PORTC
- BTFSS PORTC,4 ;判斷鍵 4
- GOTO JIAN4 ;是,跳至鍵 4 功能子程序
- BTFSS PORTC,5 ;判斷鍵 5
- GOTO JIAN5 ;是,跳至鍵 5 功能子程序
- BTFSS PORTC,6 ;判斷鍵 6
- GOTO JIAN6 ;是,跳至鍵 6 功能子程序
- BTFSS PORTC,7 ;判斷鍵 7
- GOTO JIAN7 ;是,跳至鍵 7 功能子程序
- MOVLW 0FBH ;RC2=0
- MOVWF PORTC
- BTFSS PORTC,4 ;判斷鍵 8
- GOTO JIAN8 ;是,跳至鍵 8 功能子程序
- BTFSS PORTC,5 ;判斷鍵 9
- GOTO JIAN9 ;是,跳至鍵 9 功能子程序
- BTFSS PORTC,6 ;判斷鍵 A
- GOTO JIANA ;是,跳至鍵 A 功能子程序
- BTFSS PORTC,7 ;判斷鍵 B
- GOTO JIANB ;是,跳至鍵 B 功能子程序
- MOVLW 0F7H ;RC3=0
- MOVWF PORTC
- BTFSS PORTC,4 ;判斷鍵 C
- GOTO JIANC ;是,跳至鍵 C 功能子程序
- BTFSS PORTC,5 ;判斷鍵 D
- GOTO JIAND ;是,跳至鍵 D 功能子程序
- BTFSS PORTC,6 ;判斷鍵 E
- GOTO JIANE ;是,跳至鍵 E 功能子程序
- BTFSS PORTC,7 ;判斷鍵 F
- GOTO JIANF ;是,跳至鍵 F 功能子程序
- RETURN
- ;0 到 9 按鍵,用于鍵入數字
- JIAN0 CALL SFANG ;釋放
- MOVLW 00H ;將 0 放入 W 寄存器
- MOVWF NUM8 ;NUM8 帶 0 返回
- CALL CHABIAO ;調用查表子程序
- MOVWF BIAN ;BIAN 帶 0 顯示碼返回
- RLF KEYFLAG,1 ;鍵按下一次,KEYFLAG 左移一位
- RETURN
- JIAN1 CALL SFANG ;釋放
- MOVLW 01H ;將 1 放入 W 寄存器
- MOVWF NUM8 ;NUM8 帶 1 返回
- MOVWF BIAN ;BIAN 帶 1 顯示碼返回
- RETURN
- JIAN2 CALL SFANG ;釋放
- MOVLW 02H ;將 2 放入 W 寄存器
- MOVWF NUM8 ;NUM8 帶 2 返回
- MOVWF BIAN ;BIAN 帶 2 顯示碼返回
- RETURN
- JIAN3 CALL SFANG ;釋放
- MOVLW 03H ;將 3 放入 W 寄存器
- MOVWF NUM8 ;NUM8 帶 3 返回
- MOVWF BIAN ;BIAN 帶 3 顯示碼返回
- RETURN
- JIAN4 CALL SFANG ;釋放
- MOVLW 04H ;將 4 放入 W 寄存器
- MOVWF NUM8 ;NUM8 帶 4 返回
- MOVWF BIAN ;BIAN 帶 4 顯示碼返回
- RETURN
- JIAN5 CALL SFANG ;釋放
- MOVLW 05H ;將 5 放入 W 寄存器
- MOVWF NUM8 ;NUM8 帶 5 返回
- MOVWF BIAN ;BIAN 帶 5 顯示碼返回
- RETURN
- JIAN6 CALL SFANG ;釋放
- MOVLW 06H ;將 6 放入 W 寄存器
- MOVWF NUM8 ;NUM8 帶 6 返回
- MOVWF BIAN ;BIAN 帶 6 顯示碼返回
- RETURN
- JIAN7 CALL SFANG ;釋放
- MOVLW 07H ;將 7 放入 W 寄存器
- MOVWF NUM8 ;NUM8 帶 7 返回
- MOVWF BIAN ;BIAN 帶 7 顯示碼返回
- RETURN
- JIAN8 CALL SFANG ;釋放
- MOVLW 08H ;將 8 放入 W 寄存器
- MOVWF NUM8 ;NUM8 帶 8 返回
- MOVWF BIAN ;BIAN 帶 8 顯示碼返回
- RETURN
- JIAN9 CALL SFANG ;釋放
- MOVLW 09H ;NUM8 帶 9 返回
- MOVWF NUM8 ;將 9 放入 W 寄存器
- MOVWF BIAN ;BIAN 帶 9 顯示碼返回
- RETURN
- ;A 鍵,用于倒計時的開始
- JIANA CALL SFANG ;釋放
- BSF INTCON,5 ;T0 使能打開,為定時器開啟做準備
- MOVLW 3DH ;為定時器送初值,定時開始
- MOVWF TMR0
- GOTO LOOP6 ;進入倒計時顯示大循環
- RETURN
- ;B 鍵,用于計數暫停
- JIANB CALL SFANG ;釋放
- BCF INTCON,5 ;T0 使能關閉,計數停止
- RETURN
- ;C 鍵,用于計數繼續
- JIANC CALL SFANG ;釋放
- BSF INTCON,5 ;T0 使能打開,計數繼續
- RETURN
- ;D 鍵,用于計數加一
- JIAND CALL SFANG ;釋放
- INCF NUMB ;顯示變量加一
- RETURN
- ;E 鍵,用于計數減一
- JIANE CALL SFANG ;釋放
- DECF NUMB ;顯示變量減一
- RETURN
- ;F 鍵,用于清零和重新開始
- JIANF CALL SFANG ;調用釋放子程序
- BCF INTCON,5 ;T0 使能關閉,停止計時
- MOVLW 01H ;鍵盤次數判斷恢復初始值
- MOVWF KEYFLAG
- CLRF NUM10
- ;釋放子程序
- SFANG MOVLW 00H ;RC 口低四位輸出賦低電平
- MOVWF PORTC
- MOVLW 0F0H ;屏蔽低四位
- ANDWF PORTC,W
- SUBLW 0F0H
- BTFSS STATUS,Z ;判斷高四位是否有低電平
- GOTO SFANG ;有低電平,未釋放,返回繼續判斷
- CALL DELAY10MS ;無低電平,延時 10 毫秒
- MOVLW 0F0H ;再次確認
- ANDWF PORTC,W
- SUBLW 0F0H
- BTFSS STATUS,Z ;再次判斷
- GOTO SFANG ;虛假釋放,返回繼續判斷
- BSF PORTB,5 ;已釋放,蜂鳴器停止鳴叫
- RETURN ;返回
- ;10 毫秒延時子程序
- DELAY10MS
- MOVLW 0DH
- MOVWF 23H
- LOOP4 MOVLW 0FFH
- MOVWF 24H
- LOOP5 DECFSZ 24H
- GOTO LOOP5
- DECFSZ 23H
- GOTO LOOP4
- RETURN
- ;短時間延時子程序
- DELAY DECFSZ 0X30,F
- GOTO DELAY
- RETURN
- ;小燈閃爍子程序,3 種顏色的小燈每隔 1 秒交替亮滅 1 秒
- SHANSHU BCF PORTE,0 ;燈 0 亮
- BCF PORTB,5 ;蜂鳴器開
- CALL DELAY1S
- MOVLW 0FFH ;燈 0 滅
- BSF PORTB,5 ;蜂鳴器關
- MOVWF PORTE
- CALL DELAY1S
- BCF PORTE,1 ;燈 1 亮
- BCF PORTB,5 ;蜂鳴器開
- CALL DELAY1S
- MOVLW 0FFH ;燈 1 滅
- BSF PORTB,5 ;蜂鳴器關
- MOVWF PORTE
- CALL DELAY1S
- BCF PORTE,2 ;燈 2 亮
- BCF PORTB,5 ;蜂鳴器開
- CALL DELAY1S
- MOVLW 0FFH ;燈 2 滅
- BSF PORTB,5 ;蜂鳴器關
- MOVWF PORTE
- CALL DELAY1S
- RETURN
- ;1 秒延時子程序
- DELAY1S MOVLW 06H
- MOVWF 20H
- LOOP1 MOVLW 0EBH
- MOVWF 21H
- LOOP2 MOVLW 0ECH
- MOVWF 22H
- LOOP3 DECFSZ 22H
- GOTO LOOP3
- DECFSZ 21H
- GOTO LOOP2
- DECFSZ 20H
- GOTO LOOP1
- RETURN
- END
