實驗C8051F410的ADC,使用串口輸出電壓值,但是輸出與實際的誤差隨實際電壓增大而增大,達到參考電壓時串口發送出去的值與實際電壓相差0.3V;
相關程序:
void ADC0_ISR (void) interrupt 10
static unsigned long accumulator = 0; // accumulator for averaging
static unsigned int measurements = 2048; // measurement counter
unsigned long result=0;
unsigned long mV; // measured voltage in mV
static unsigned int RH;
AD0INT = 0; // clear ADC0 conv. complete flag
accumulator += ADC0;
measurements--;
m=1;
if(measurements == 0)
result = accumulator / 2048;
accumulator=0;
mV = result * 220 / 4095;
RI0=0;
TI0=0;
SBUF0=mV;
void UART0_Interrupt (void) interrupt 4
Delay_ms (2);
if (TI0==!0)
TI0=0;
else if(RI0==!0)
RI0=0;
主程序是死循環;參考電壓是2.2V,因為串口輸出只能顯示16位二進制,最大255,所以在計算時乘的220而不是2200。有沒有大佬幫忙看一下?
